Fusion Knife edge coupling issue
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> Fusion Knife edge coupling issue
Page: [1]
Login
Fusion Knife edge coupling issue - 6/28/2009 4:14 PM
Raysun
Score: 100
Last Login: 9/1/2009
Status: offline
Hi Everyone,
I have the 52" (?) Fusion profile. In KE, it couples to the canopy very strongly...is this normal and should I just mix it out? Motor is OS 46AX, 12x5 apc prop.
Ray, BRCM
Oakville Ont.
Hide Signatures
       Post #: 1
RE: Fusion Knife edge coupling issue - 6/29/2009 12:41 AM
AFSalmon
Score: 100
Last Login: 11/6/2009
Status: offline
quote:
ORIGINAL: Raysun
Hi Everyone,
I have the 52'' (?) Fusion profile. In KE, it couples to the canopy very strongly...is this normal and should I just mix it out? Motor is OS 46AX, 12x5 apc prop.
Ray, BRCM
Oakville Ont.
Not normal at all. The Fusions are vitually zero coupling and one of the best KE planes to have. You have something really wrong. Check you CG and also make sure your ailerons are totally nuetral at center. If the plane is setup really nose heavy then you are probably carrying some significant up trim and thus the pull to the canopy on KE.
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes
Hide Signatures
(in reply to Raysun)
       Post #: 2
RE: Fusion Knife edge coupling issue - 6/29/2009 6:53 PM
Raysun
Score: 100
Status: offline
Thanks, I do carry some up ele, where should CG be? In inverted, ineed a fair bit of push stick, so I'm likely nose heavy.
Ray
Hide Signatures
(in reply to AFSalmon)
       Post #: 3
RE: Fusion Knife edge coupling issue - 6/30/2009 12:59 PM
AFSalmon
Score: 100
Status: offline
quote:
ORIGINAL: Raysun
Ray
Correct, if you are carrying up elevator then it is most likely because you are nose heavy to begin with. And you need to push down elevator a lot when inverted then you are definately nose heavy. So when you are on KE then the up elevator is pulling the plane to the canopy. Get your CG fixed and the coupling will go away.
Ohio Model Planes
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
