pitts muffler exhaust nipple
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Airfoilz Katana NX - Kit
Seller:  Furyflyer2
Details:   $59.99   |  11/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> pitts muffler exhaust nipple
Page: [1]
Login
pitts muffler exhaust nipple - 6/29/2009 12:33 AM
hulio516
Score: 125
Last Login: 10/4/2009
Status: offline
The nipple on my pitts muffler is 1/8 inch out facing my firewall. Do I run the muffler exhaust line from the nipple back through the firewall and then back out of the firewall to my tank or what?
And also, do they have any L-shaped nipples to fit the pitts muffler?
I'd like to know.
Hide Signatures
       Post #: 1
RE: pitts muffler exhaust nipple - 6/29/2009 12:54 AM
ChuckW
Score: 125
Last Login: 11/8/2009
Status: offline
Did a search on tower and found a couple 90 degree fittings. Not sure if they will work but worth a look: http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=pressure+fitting&search=Go
You could also run the line through your firewall to your tank.
Hide Signatures
(in reply to hulio516)
       Post #: 2
RE: pitts muffler exhaust nipple - 6/29/2009 2:25 AM
Trax540
Score: 100
Status: offline
quote:
ORIGINAL: hulio516
Why would you have to run it through the firewall a second time??
If the nipple is facing the firewall from the engine side, Is your fuel tank located also with the engine?? It should only have to run from where it is, Through the firewall to the tanks pressure line.
Or am i misunderstanding what your explaining
Hide Signatures
       Post #: 3
RE: pitts muffler exhaust nipple - 6/29/2009 2:58 AM
hulio516
Score: 125
Status: offline
Nipple pic.....
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Trax540)
       Post #: 4
RE: pitts muffler exhaust nipple - 6/29/2009 4:25 AM
Trax540
Score: 100
Status: offline
I do see...
Yes you could run it the way you had said, Or you could try that 90deg.
The only other thing that i have personally done is relocate the pressure nipple completley.
Ive had the original fitting strip threads badly so i plugged the hole with Alumiweld drilled and retapped new threads. I used a red gel gaskit maker instead of the original gaskit, and ive had no problems with it at all.
Cant tell by the pic whether you have room on the top of the pitts to relocate there. You might be able to use JB weld to plug the hole im not sure on that ive never used the product.
Hide Signatures
       Post #: 5
RE: pitts muffler exhaust nipple - 6/29/2009 2:11 PM
PilotFighter
Score: 115
Last Login: 8/16/2009
Status: offline
I have had this problem before. I put a bolt in the old nipple hole and drilled a new hole at the bottom of the header, opposite of the engine. The metal is thick there and you can drill and tape without a problem.
_____________________________
turn left, your other left
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.423RCU1
