Is this battery big enough?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> Is this battery big enough? Page: [1]
Login
Is this battery big enough? - 6/23/2003 10:58:51 AM
zope_pope
Status: offline
Hey everyone.
I am about to maiden my DP ultimate and just checking to see i have all the wrinkles ironed out. I am running 4 futaba 3004 servos in the ailerons, one hitec mini servo for the throttle, a very hi torque digital for the elevators, and a 1/4 scale servo for the rudder. Dave Patrick suggested using a 600 mah battery for this setup, does this seem a little bit small for this airplane? The help would be greatly appreciated. Thanks
_____________________________
If you choose not to make a decision, you have still made a decision.
       Post #: 1
Is this battery big enough? - 6/23/2003 11:07:41 AM
RCLIVIN
Status: offline
I wouldn't use less than a 1100 mah battery for this, If it were mine it would have a 1650 mah nimh battery in it
Gil
MARRIAGE IS OPTIONAL, FLYING IS A
''NECESSITY''
(in reply to zope_pope)
       Post #: 2
Is this battery big enough? - 6/23/2003 11:09:20 AM
zope_pope
Status: offline
How much weight do you think a 1100 or 1650 mah batt would add?
       Post #: 3
Is this battery big enough? - 6/23/2003 11:16:39 AM
RCLIVIN
Status: offline
The nimh battery's are about the same weight or a little lighter than the 600 mah nicad.
Gil
''NECESSITY''
       Post #: 4
Is this battery big enough? - 6/23/2003 4:59:51 PM
Luke 3D
Status: offline
Can they cope with the current?
any drawbacks?
Luke
Fly Pete Tindal's Airplanes.
They are very good
       Post #: 5
Is this battery big enough? - 6/23/2003 5:05:54 PM
geoff_nwt
Status: offline
Hi
I have used 1650...1700...& 1750 4.8 volt NMH for years
with no problems at all
Your best of with a fast charger with the higher capacity battery packs instead of a trickle charger
***The Sky Is Not The Limit***
       Post #: 6
Is this battery big enough? - 6/23/2003 7:58:05 PM
JohnVH
Status: offline
Just make sure you have a charger that will charge NIMH, I use all Nicad in all my planes, 33% to jets.
---AIR VH---*FURY FLYER* www.3DFoamy.com
       Post #: 7
Is this battery big enough? - 6/23/2003 8:44:09 PM
zope_pope
Status: offline
I will stick to Nicads for now just for the sake of saving money (my ulty has used most of it). I think i will have to go bigger. my voltwatch goes to the yellow when i move all the control surfaces, so it cant handle the current. Phew, good thing i didnt fly this. Thanks for all your help. Do you think 1100mah is big enough its almost double, but i may go bigger just to be safe.
       Post #: 8
Is this battery big enough? - 6/23/2003 11:37:11 PM
JohnVH
Status: offline
Personally Id go 1100 minimum. The more MAH the more you can fly between charges. Can it take the weight of a 1800 pack?
       Post #: 9
Is this battery big enough? - 6/23/2003 11:45:31 PM
zope_pope
Status: offline
What is the weight difference between a 1800 and a 600? Aobut 3 times as much? I want to keep the plane around 12 lbs. Its 12lbs 3 oz, with the current battery. Thanks.
       Post #: 10
Is this battery big enough? - 6/23/2003 11:46:34 PM
JohnVH
Status: offline
Im not sure, have to check some places online, the 1800 is a pretty big batt pack.
The 1100 should be good, just check the battery after each flight so you know.
       Post #: 11
Is this battery big enough? - 6/23/2003 11:53:50 PM
zope_pope
Status: offline
Yeah, I have a volt watch, so that should help me keep track. Thanks.
       Post #: 12
Is this battery big enough? - 6/24/2003 6:34:16 AM
Geistware
Status: offline
I would use 1400maH if NiCad or 1800maH for NiMH
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 13
Is this battery big enough? - 6/24/2003 10:54:46 AM
zope_pope
Status: offline
Thanks for all your posts. It really helped. I have decided to go with a 1400 Mah Nicd. Thanks.
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
