Receiver Antenna / Bobbin
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Receiver Antenna / Bobbin
Page: [1]
Login
Receiver Antenna / Bobbin - 7/1/2009 4:51 PM
hetr
Score: 100
Last Login: 10/12/2009
Status: offline
with newer 72mhz receivers l've gotten lately Hitec supplies a "bobbin" on which one can wind up to @ 18" of the receiver antenna, starting 3 -4" from the receiver - and of course with the instruction to not cross over any of the antenna - just spool it
l have done so on a mid-size plane and a smaller Taylorcraft (which is not parkflyer as such) = and have had no problems or noticeable issues with flying; distance, etc
some guys question the practice - as it is in one respect "shortening the antenna length" despite not cutting anything off
the instructions do not mention any best practice - such as in use only with park flyer or something of that nature
is there a guideline for spooling the antenna - in terms of any range loss, chance of increased interference, etc or is it a primarily cosmetic enhancement for those that want less antenna to fasten down ant trail the plane in the air?
thanks in advance
(note: added after posting original: had missed a post of 6/27/09 concerning same topic = but would like some clarification if there is some - l have flown 400 - 500 feet away and no side effects - have l been lucky?)
< Message edited by hetr -- 7/1/2009 5:28 PM >
Hide Signatures
       Post #: 1
RE: Receiver Antenna / Bobbin - 7/1/2009 9:30 PM
A.T.
Score: 100
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: hetr with newer 72mhz receivers l've gotten lately Hitec supplies a ''bobbin'' on which one can wind up to @ 18'' of the receiver antenna, starting 3 -4'' from the receiver - and of course with the instruction to not cross over any of the antenna - just spool it l have done so on a mid-size plane and a smaller Taylorcraft (which is not parkflyer as such) = and have had no problems or noticeable issues with flying; distance, etc some guys question the practice - as it is in one respect ''shortening the antenna length'' despite not cutting anything off the instructions do not mention any best practice - such as in use only with park flyer or something of that nature is there a guideline for spooling the antenna - in terms of any range loss, chance of increased interference, etc or is it a primarily cosmetic enhancement for those that want less antenna to fasten down ant trail the plane in the air? thanks in advance
The bobbin is intended for use with smaller models which would not be seen if flown at full range of 1500m+. Best practice is to always use the aerial full length when ever possible and irrespective always range test before flight. With use of the bobbin, if installed correctly, no effects should be obvious within say 500m, please refer to earlier information:
What is purpose of the Antenna Bobbin
Guide to receivers - and solving apparent RX & "Interference" problems
See also sub Sections
"Antenna - Rubber Duckie, Micro & Whip Flywire - replace long aerials with loaded base antenna " and
Range check and Range problem solving"
under
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
< Message edited by A.T. -- 7/1/2009 9:31 PM >
Hide Signatures
(in reply to hetr)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.357RCU1
