RE: First solo flight
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
TamJets F-18F RTF
Seller:  Patrick Frost
Details:   $5,800.00   |  11/4/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> RE: First solo flight
Page: <<   < prev  1 [2]
Login
RE: First solo flight - 7/3/2009 5:19 AM
Fizzmaster
Score: 100
Last Login: 8/24/2009
Status: offline
I didn't think it would be a big deal. I like the pics Nordicz
Hide Signatures
(in reply to Nordicz)
       Post #: 26
RE: First solo flight - 7/3/2009 5:23 AM
Deadeye
Score: 111
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: Nordicz
Here is the second of a couple I guess.
Nordicz, nice field you have there. What direction from town is it? I'd like to see it from Google Earth.
_____________________________
Randy Rossmiller, member, Golden Triangle Flyers
Hide Signatures
       Post #: 27
RE: First solo flight - 7/3/2009 5:32 AM
Nordicz
Score: 100
Last Login: 11/6/2009
Status: offline
The field can be seen from Google Earth it is SouthWest of Owatonna MN, The nearest intersection I believe is 48th st. and Lemond or CR7. Tim Johnson owns the field and it is the Southeast Minnesota Model Aircraft Club. Here is the web site addresss. www.smmac.com
Nordicz
< Message edited by Nordicz -- 7/3/2009 5:34 AM >
Hide Signatures
(in reply to Deadeye)
       Post #: 28
RE: First solo flight - 7/3/2009 5:38 AM
Nordicz
Score: 100
Status: offline
Thanks Fizzmaster,
I didn't take them but by the smile on my face I can say I felt really good that day. But I really have to hand it to my instructor and all the help he gave me. My first attempt on the buddy box I thought this is going to not be good. Some sim time and a couple more attempts and I was off and running. You look like you also have a nice rural field to fly in..
Nordicz
Hide Signatures
       Post #: 29
RE: First solo flight - 7/3/2009 5:50 AM
Deadeye
Score: 111
Status: offline
Is this it?
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 30
RE: First solo flight - 7/3/2009 6:12 AM
Nordicz
Score: 100
Status: offline
It doesn't look like it. The tarmack is a multi-piece conveyor belt of different colors. That looks like the Municpal airport.
Z
Hide Signatures
       Post #: 31
RE: First solo flight - 7/3/2009 6:26 AM
victorzamora
Score: 118
Status: offline
Actually, angled to the right (or left) is where your 2.4GHz antenna should be. If the top of your antenna points immediately at your model you lose a good deal of reception.
Had I have known that the law of gravity was going to be so expensive, I would''ve voted to veto the darn thing!!
Hide Signatures
       Post #: 32
RE: First solo flight - 7/3/2009 6:34 AM
Nordicz
Score: 100
Status: offline
Deadeye,
My mistake the field you are looking at is our second field in the area. I did not recognize it because the capture is older than the crosswind runway the club put in. I maidened my winter build there in May. Go just a little more South West and that is the site.
Nordicz
Hide Signatures
(in reply to victorzamora)
       Post #: 33
RE: First solo flight - 7/3/2009 6:39 AM
Korps
Score: 110
Last Login: 10/26/2009
Status: offline
Yip I see the antenna now . I didn't know it really mattered with 2.4 that the antenna should point to the right or left. Well you learn something new everyday
Watch out! Dead Man Flying!
Hide Signatures
       Post #: 34
RE: First solo flight - 7/3/2009 2:59 PM
victorzamora
Score: 118
Status: offline
With ALL technologies, the radio nearly doesn't transmit from the top of the antenna. With 2.4, with those teensy antennae on the Rx....it becomes even more critical.
Hide Signatures
(in reply to Korps)
       Post #: 35
RE: First solo flight - 7/3/2009 10:02 PM
Gooseman240
Score: 110
Status: offline
Well it is nice to see some one else openly boast that they flew a nexstar for a trainer.
I have one, I have to say, not disappointed with it at all. Although I did note peeps stating it has a bad right swing (tip) when lifting from the ground, and I was able to anticipate that. But I have enough flights on mine now in 1 year that the covering is falling off, I have to re-coat it now. Thank god for clear tape to hold it together until I get time to build my second plane and work on the nexstar over the winter. Watch the front landing gear screws and motor mount screw's on the firewall tend to come loose...
Is your covering coming loose yet? or is it that new still?
Hide Signatures
       Post #: 36
RE: First solo flight - 7/3/2009 10:12 PM
hairy46
Score: 110
Status: offline
I started this hobby over 25 years ago and just did my solo couple years back! Got a plane for my birthday back then and shortly later ended up a single dad, and after getting my kids through school I took up the hobby again! I never flew but a little bit with a friend and never took off or landed the plane at that time. Now I fly as often as I can and like the War-birds most! But I remember when I soloed it was one of the happiest days I ever spent! and great people in this hobby are a plus. I will be doing my first War-birds fly-in next month at War-birds over the Rockies, Wow I love this hobby! Bob
Want to keep from crashing? take off and land higher!
Hide Signatures
       Post #: 37
RE: First solo flight - 7/3/2009 10:24 PM
bonebreak
Score: 110
Last Login: 11/7/2009
Status: offline
quote:
ORIGINAL: Gooseman240
I too flew the Nexstar as my trainer (the same one Fizz is flying as a matter of fact), and I never had any issues at all either. I think it does tend to go right on liftoff, but it does it EVERY time, so it is easy to counter. I think the Nexstar has the lowest stall speed of any plane out there. You can almost get it to stop in the air on approach, with no bad tendencies. I had fun flying it again while training him. Brought me back to my first flights.
As far as the covering goes, Fizz is the proud new owner of a slice on the fuse under the wing courtesy of myself. I was installing a charge jack, and thought the balsa went all the way down. In short, it didn't, and when I was slicing through the balsa, I hit the covering, and sliced it to the gear. A little clear tape fixed it. (Sorry again Fizzmaster).
Hide Signatures
(in reply to Gooseman240)
       Post #: 38
RE: First solo flight - 7/3/2009 11:11 PM
Tom Nied
Score: 100
Status: offline
That's a good looking trainer. You're going to have fun with that. Fly the heck out of it.
Hide Signatures
       Post #: 39
RE: First solo flight - 7/4/2009 1:15 AM
tony0707
Score: 100
Status: offline
HI WELCOME TO THE RC FLYERS OF AMERICA (A 4TH OF JULY GREETING )-you are now one of the chosen -to enjoy this hobby for many years if you choose toi find this to be a very critical time in the hobby -for now you stand alone with your plane for the first timemy best advice is ask for help and someone to be close by until you can trim out -your first flight aircraft-knowing when to ask for help-is the key to being very susesful in this great hobby-and that applies to any time you may think that help is neededdo not be shy-your fellow models have been there done thatand are willing to be helpful-they can stand by you and input trims on that always awsome first flightSO ASK FOR HELP NOW !!
Hide Signatures
(in reply to Tom Nied)
       Post #: 40
RE: First solo flight - 7/4/2009 2:31 AM
rc airplane nut
Score: 125
Status: offline
Congrats Fizz! Your lucky to have pics on your solo, I didn't get any, but I did get a dead radio battery. I was so excited (and shakey) that I forgot to turn off the radio and the plane. The bad thing was, I did remember to take the pin back. And CGretired is right about the "multitude of the forever broke" I just ordered my second plane and now I have a whopping $00.33.
"Pull Up Pull Up"
Hide Signatures
(in reply to tony0707)
       Post #: 41
RE: First solo flight - 7/4/2009 3:46 AM
PipeMajor
Score: 100
Status: offline
Congrats from here as well. My son and I solo'd not quite 4 years ago. We had been on the buddy box for 6 total flights. Our instructor told us he had no problem with us going solo in calm winds. My son had a couple of days off school (he was 13) for conferences so we headed up to the field for our solo but, there was no one there!
We checked everything out and wound up doing a pair of solo flights each, totally unsupervised. We documented our "special day" in this thread.
Hide Signatures
(in reply to rc airplane nut)
       Post #: 42
RE: First solo flight - 7/4/2009 5:02 AM
StingRayZ09
Score: 110
Status: offline
Congrats,, I wasn't long ago that I made my frist solo, I remember all so well, Even today when I fly I still forget to breath. The trainer was given to me now I will give it to someone who want to learn and fly. Now I own six birds now. and building more.. Happy Flying and welcome welcome welcome to out world......
Hide Signatures
(in reply to PipeMajor)
       Post #: 43
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.109RCU1
