Great Planes P47
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Great Planes P47
Page: [1]
Login
Great Planes P47 - 7/2/2009 10:08 PM
speedy72vega
Score: 108
Last Login: 11/21/2009
Status: offline
Well, I just picked up a Great Planes P47 Jug, 39 1/2" w/s. The fit and finish looks to be excellent, and the hardware seems to be decent. Has anyone built/flown this plane?
What experiences did you have, good or bad?
I have 2 choices of what motor I can run in it, I have a 35-36-1400 motor, 550 watts, or a 35-42-1000 motor that is 605 watts on 4S. I figure a 10x7 or 11x6 prop?
I can't wait to get this thing together.
Hide Signatures
       Post #: 1
RE: Great Planes P47 - 7/3/2009 2:27 AM
RedGN
Score: 100
Last Login: 10/18/2009
Status: offline
Looks like a nice plane. I just put together a World Models P-47. It look very similar to the GreatPlanes one. It's pretty delicate especially the vertical and horizontal stabilizers.
One major difference is that the World Models P-47 comes with Retractable Landing gear pre installed.
Total weight without battery is around 725 grams.
Hope this Helps
Hide Signatures
(in reply to speedy72vega)
       Post #: 2
RE: Great Planes P47 - 7/5/2009 3:00 AM
speedy72vega
Score: 108
Status: offline
Well, I got this thing together and maidened it today. After all the trimming and adding a bit more travel than the rates in the manual, it flies great. It flies pretty fast, and is quite stable in flight. It does come in for landings a bit hotter than i'm used to, so it will take a bit of practice. One thing I wasn't ready for though, it required quite a bit of down elevator trim. As soon as I throttled up, it started climbing like crazy. I rechecked the CG, was right on the money. I had one of the very experienced pilots fly it, and he suggested increasing the throws due to the nature of the planes flight characteristics. I readjusted the throws and retrimmed, and it's great.
I am also going to add a steerable tailwheel, as the kit just came with a skid.
The kit is actually quite good for the price. Sheeted fuse, decent hardware, EZ link connectors, but the wing required a bit of massaging to fit, and the lower wing trim panel didn't fit flush. All in all, i'm very satisfied with it, I like it much better than the cheap Electrifly 41" Edge 540 I bought awhile back. I think i'll just put that plane on Craigslist or something .
If anyone is contemplating this plane, I would recommend it.
Hide Signatures
(in reply to RedGN)
       Post #: 3
RE: Great Planes P47 - 7/6/2009 10:12 PM
RedGN
Score: 100
Status: offline
Glad to hear all went well
How is to build quality of the Great Planes p47?
The World Models p47 is pretty delicate. I put some epoxy around motor mount and other key stress locations.
Other than that it flew well. The servo i used for the retrats was too weak and stripped the gears.
If you are looking for another p47, check out the world models.... Has retracts and steerable tail wheel.
Hope this helps.
Hide Signatures
       Post #: 4
RE: Great Planes P47 - 7/7/2009 2:41 AM
speedy72vega
Score: 108
Status: offline
Thanks Red, i'll check it out. The build was easy, the fuse is fully sheeted and very sturdy. The wing is mostly sheeted, but has a few small sections where there are ribs and covering.
I really enjoyed building it, it only took 1 evening. There was 1 thing that was kinda sloppy, there is a plastic filler panel under the wing, and it didn't fit very well.
The thing flies really good, very fast and accurate. I have a 35-36-1400 motor on it that I run at 11.1 volts with a 10x7 prop. It flies quick at only 1/2 throttle, and climbs till you almost can't see it anymore with ease.
This is my first warbird, and so far i'm impressed.
I'm going to go check out the model you are talking about, would be cool to have retracts.
Hide Signatures
(in reply to RedGN)
       Post #: 5
RE: Great Planes P47 - 7/14/2009 6:46 PM
Willit Run 353
Score: 100
Last Login: 11/18/2009
Status: offline
I have never flown this model but go for the biggest motor you can fit in the cowl, remember there is no such thing as over-powered
with a huge motor you can fly fast as well as slow but with a smaller motor you can only fly slow (and on a plane this isze it gets boring)
Hide Signatures
       Post #: 6
RE: Great Planes P47 - 7/14/2009 10:25 PM
RedGN
Score: 100
Status: offline
Almost the exact set-up to mine. Well, really my son's. He 10 and i bought it for him as a gift. He put it together but i helped when he was in trouble.
I also bought him a Mitsubishi Zero by World models however that one is still in the box. Same dimentions ( 39.5 inch Wingspan ) and i think it's probably the same quality.
It also comes with retracts and a steerable tail wheel.
Oh... After the servo stripped in my sons P47 we belly landed it on grass and it barely scatched it after a few landings.
Happy Flying
Hide Signatures
       Post #: 7
RE: Great Planes P47 - 7/15/2009 2:44 AM
speedy72vega
Score: 108
Status: offline
Well, I put the P47 into a post last weekend . Our club had the annual electric fun fly, and I was getting in some flying before the event. I was bringing the Jug in for a landing, and didn't notice someone had set some posts that were set in bases on a corner of the runway. The plane started drifting off to the side of the runway on approach, about 3 feet or so off the ground. Just as I started to steer back towards the center of the runway.........CRACK. The plane disappeared. I ran right into the posts. I was concentrating on the plane, and didn't even see the posts...........
Luckily, only the wing sustained major damage. The fuse is fine, the motor mount popped off along the glue lines, but nothing a little epoxy didn't fix. Slight damage to the elevator, but easy to fix too. I have already orderd a replacement wing, hopefully I'll get it tomorrow.
This plane flies great, very sleek and fast. I can't wait to get her back up in the air.
P.S. How is the Zero kit?? I want to build either a Zero, or messerschmit (I don't think I spelled that right ).
Hide Signatures
(in reply to RedGN)
       Post #: 8
RE: Great Planes P47 - 7/15/2009 5:32 AM
RedGN
Score: 100
Status: offline
Sorry to hear..... I'm sure it'll be back in the air in no time.
I haven't even open the zero box yet...Building a BD5 now. ( 44" WS )
How many years have you been flying? I have many crash stories.... ( i don't know whether to laugh or cry )
Hide Signatures
       Post #: 9
RE: Great Planes P47 - 7/16/2009 1:57 AM
speedy72vega
Score: 108
Status: offline
quote:
ORIGINAL: RedGN
I haven't even open the zero box yet...Building a BD5 now. ( 44'' WS )
Actually Red, i've only been flying since the end of January this year. I'm completely self taught (I know, not recommended ). I have gotten the bug bad! I already have 7 planes in various states of completion, 5 of them flyable, and I have already sold 2 planes, my old trainer and my Super Cub.
The planes I have are a Mini Ultra stick, an Electrifly 41" Edge 540, a Nitro Planes 63" Extra 330L that I converted to electric, an Eratix 3D, a Profile foamie Edge 540 Kirby Chambliss Red Bull Special, my P47, and a little foam Zoomer. I also had a Stevens Aeromodel Edge 540 that I crashed a couple of months ago. That was a GREAT plane, excellent kit.
I fly every chance I get! Luckily, my local airfield is only 5 miles from my house.
I got my wing today, so my P47 will be ready for this weekend.
Hide Signatures
(in reply to RedGN)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.813RCU1
