HELP, FAST...Which prop to run on stock zen 260?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
NEW MHZ Speedmaster S6 Stern Drives - price reduced!! - Kit
Seller:  Justaddwata
Details:   $500.00   |  10/30/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Boats >> Speed - RC Gas Boats >> HELP, FAST...Which prop to run on stock zen 260?
Page: [1]
Login
HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 2:54 AM
onehot69stepside
Score: 100
Last Login: 11/8/2009
Status: offline
after screwing around for 2 years, i finally got this woody ready to drop the motor in after i give it a clear coat. Was wanting to run this thing asap but the only thing i dont have is a prop. Im going to buy a prop from wharehouse hobbies and i dont have the time to balance and polish a brass prop just yet. I was looking at the 75mm and 80mm aluminum props but dont know what to really get. Its got a zen g260 with a wet pipe system that i purchased from WHH a year ago. Thanks in advance guys!
Hide Signatures
       Post #: 1
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 3:00 AM
Dreamin Hemi
Score: 150
Status: offline
**NEWSFLASH***
You still need to sharpen and balance it
< Message edited by Dreamin Hemi -- 7/3/2009 3:01 AM >
_____________________________
These opinions expressed here are my own and may not necessarily represent the views of RCUniverse.com
Proprietor of FirstStateComposites dot com
Hide Signatures
(in reply to onehot69stepside)
       Post #: 2
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 3:08 AM
onehot69stepside
Score: 100
Status: offline
on the wharehouse hobbies site, it says that no additional work is required to use it. whay would it say that? If that is the case what is the best prop to use?
Hide Signatures
(in reply to Dreamin Hemi)
       Post #: 3
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 3:13 AM
black talon
Score: 100
Last Login: 11/7/2009
Status: offline
get the 70mm/3. IT TAKES THE LEAST AMOUNT OF WORK TO BALANCE AND IS GREAT FOR A STOCK ENGINE.
One day at a time, it''''''''s not always a race.
Hide Signatures
       Post #: 4
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 3:16 AM
Dreamin Hemi
Score: 150
Status: offline
Grim Racer props also advertise the same thing. Have several of them and all needed sharpening. Have 2 of the WHH aluminum props and they both needed sharpening. I prefer them to be able to cut paper. There are several nice props out there. For your stock engine, you could start with a Pranther 275 or similar size. Still needs sharpening and balancing however.
Hide Signatures
       Post #: 5
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 3:55 AM
bondobuster
Score: 100
Last Login: 10/31/2009
Status: offline
Those aluminum props DO need to be sharpened. They come thick and as dull as a butterknife! My boat loves the octura x472 and the 70mm(from Whobbies) and the grimracer 3 blader.
Hide Signatures
       Post #: 6
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 4:37 AM
dicko
Score: 121
Status: offline
I suggest you get a sharpened & balanced Prather 275 from Dasboata (Chris Hofmann). He's reasonably priced & the prop will serve you a long time.
You can probably get one of his off of Ebay, that's where I got mine.
< Message edited by dicko -- 7/3/2009 4:38 AM >
The answer is always more power.
Hide Signatures
(in reply to bondobuster)
       Post #: 7
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 6:12 AM
bondobuster
Score: 100
Status: offline
quote:
ORIGINAL: dicko
Went to his website but has no listings for prather props at all. Will have to e-mail him.... Found somwheres that grimracer prop equivalent chart: 65x100/2 blade=prather 265
67x105/3 blade=prather270/275
Just info to share.....
Hide Signatures
(in reply to dicko)
       Post #: 8
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 7:43 AM
planebasher
Score: 100
Status: offline
I have one of each of the WHH Al props; they are balanced; but dull; they perform much better after you sharpen them.
The 280 and the 70mm-3 are quite a load on the 260; the 275 runs better for me after detonguing a little and sharpening; I have gotten the best performance and speed with the Octura X472; an avg of 4 mph better; just sharpening and balancing; no tweaking of the blades.
The best improvement so far in the performance of the engine has been the change to a 275 carb; The Magnum did a wheelie today; came out of the water landed on the stern and bent the rudder mount sideways. It really woke the Zen up. Cheap mod too; $27.00 .
Hide Signatures
       Post #: 9
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 8:14 AM
martno1fan
Score: 155
Status: online
quote:
ORIGINAL: onehot69stepside
correct no need to balance or sharpen pollish an ali prop,they are so light they dont require balancing much if any from the mould and theyre allready sharp really.Stick it on and run,i get mine from china they come looking awesome as he polishes them.go for a 70 mm prop or 72 mm,if they do a 3 blader try one arround 67 -70 mm.Cant speak for wwhobbies props but the ones i get come ready to run,hes now claiming sharpened and balanced but my ones didnt come with that claim and they were perfect.Supose a quick sharpen of the blade wont hurt but they arent anything like a brass prop they are much thinner and sharper in stock form.I do agree though best props are ss or brass from dasboata .Or buy a stock prop and have a go yourself its not that hard to do ive done plenty with good success.
Mart
http://cgi.ebay.co.uk/Aluminum-CNC-Prop-70mm-dia-pitch-98mm-shapened-balanced_W0QQcmdZViewItemQQ_trkparmsZQ7c301Q3a1Q7c293Q3a1Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem4397f51e0aQQitemZ290312232458QQptZRadioQ5fControlQ5fVehiclesQQsalenotsupported
< Message edited by martno1fan -- 7/3/2009 8:23 AM >
Manufacturer of quality gas boat mouldings.
waveridermouldings.zoomshare dot com
Hide Signatures
       Post #: 10
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 8:25 AM
onehot69stepside
Score: 100
Status: offline
would one of these provide more accelleration over speed and vice versa? kinda leaning towards the x472 from whh for 40 bucks balanced and sharpened.
dasboata has a few props on his store but none of them look familiar. can someone check them out for me?
< Message edited by onehot69stepside -- 7/3/2009 8:27 AM >
Hide Signatures
(in reply to dicko)
       Post #: 11
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 9:04 AM
Justaddwata
Score: 207
Status: offline
I would recommend e-mailing chris (Dasboata) and asking his opinion on what to try. The guy knows props like the back of his hand and has hundreds more options than listed on his site. He has set several speed records over the years (as have many customers of his). He has proven to be an asset to the hobby. And if your not happy with the prop he will make it so you are
He has my highest respect and it is well deserved.
One of the best gas boat picture sites - http://imageevent.com/justaddwata
“He is not only dull himself; he is the cause of dullness in others.”
Hide Signatures
       Post #: 12
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 9:10 AM
martno1fan
Score: 155
Status: online
The x472 is a good prop for a stock zenoah it unloads pretty fast so great acceleration and top speed is pretty good.I prefered the 6717/3 just ballanced and sharpened from dasboata,slightly slower on takeoff due to its 3 blades but it was faster top end on my vee, also it removed the chinewalking i was getting with the x472.Id maybe email Chris and ask his advise ,in the meantime the x472 is a decent start in my opinion.
Mart
Hide Signatures
       Post #: 13
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 9:56 AM
MrMikeG
Score: 105
Last Login: 11/2/2009
Status: offline
Stock engine big prop, stock engines have great low end torque, as they get modded the torque goes higher in the RPM range. 275, 280, X470/3 and 3014 are all good behind a stock Zenoah.
Hide Signatures
(in reply to martno1fan)
       Post #: 14
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 11:41 AM
lewisdf4
Score: 100
Last Login: 8/11/2009
Status: offline
I have 3 Octura alli props, they all came out of balance and blunt. I had to do considerable work to all 3 and would not have run one out of the packet IMHO.
Cheers, Chris
< Message edited by Justaddwata -- 7/3/2009 12:45 PM >
Hide Signatures
(in reply to MrMikeG)
       Post #: 15
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 11:56 AM
Mike2735
Score: 100
Status: offline
Check with Zippkits. They have props already sharpened and balanced. I have one and they did a wonderful job on it.
Hide Signatures
(in reply to lewisdf4)
       Post #: 16
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/3/2009 1:23 PM
martno1fan
Score: 155
Status: online
I think the octura ones are crap casting so ive heard so doesnt surprise me,the ones ive had and ive had 4 from china were sharp and polished to perfection at no extra cost when i got mine 2 yrs ago.Ran well out of the packet and still do.
Mart
Hide Signatures
       Post #: 17
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/4/2009 12:37 AM
onehot69stepside
Score: 100
Status: offline
i think ill go with the octura x472 from WHH and have them sharpen and balance it as Ill also be purchasing tonys T Bar from them. Thanks for everyones help! Its great to have timeley responses!
Hide Signatures
       Post #: 18
RE: HELP, FAST...Which prop to run on stock zen 260? - 7/4/2009 2:18 AM
bondobuster
Score: 100
Status: offline
Good choice! It is a good starting point and you will be impressed with the holeshot and get-up and go performance of that prop. You can also e-mail Tony ( tell him what you got for a set-up )and ask for his recommendations and he might steer you in a different direction. But I thinks you will be o.k. with your choice, Cheers....
< Message edited by bondobuster -- 7/4/2009 2:21 AM >
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.031RCU1
