Moisture in Methanol
Tower Hobbies
Logged in as Guest
  Printable Version
RC Extreme Power 102cc Gas Engine - RTF
Seller:  Milton
Details:   $799.95   |  7/4/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Moisture in Methanol
Page: [1] 2   next >   >>
Login
Moisture in Methanol - 3/28/2002 4:37:23 AM
JoanC
Status: offline
What happens when methanol gets moisture? How do you notice your fuel has moisture when you are running your engine? What amount of water must the fuel have for being unusable?
       Post #: 1
Moisture in Methanol - 3/28/2002 6:53:03 AM
Vince
Status: offline
The fuel will become cloudy. Be advised that fuel stored for any great length in a plastic bottle can absorb moisture right through the plastic from the outside air.
Vince
(in reply to JoanC)
       Post #: 2
What kind of problems are you having - 3/28/2002 2:28:29 PM
bob_nj
Status: offline
And how are your engines running?
(in reply to JoanC)
       Post #: 3
Moisture in Methanol - 3/28/2002 8:47:38 PM
JoanC
Status: offline
No problems. I just wanted to know the effects of moisture in how the motors work.
(in reply to JoanC)
       Post #: 4
Moisture in Methanol - 3/28/2002 9:18:37 PM
ramcharger
Status: offline
If water is your fuel, the engine will run lean and get hot. I suppose water in the fuel would be last on the list of trouble shooting items you would look into when a lean run is encountered. Depending on the amount of water in the fuel, the problem may be eliminated by re-tuning.
(in reply to JoanC)
       Post #: 5
Moisture in Methanol - 3/29/2002 12:02:47 AM
Sport_Pilot
Status: online
Fuel does not get cloudy with water, unless there is so much water the oil will not mix, thats a LOT of water. If you adjust the needle each time you fly you will not get a lean run from water. Since adding water displaces fuel it will run leaner on the same needle setting but opening up the needle solves. I don't know how much fuel our engines can tolerate but I suspect it is over 10%. I know that our engines can run with over 30% oil and extra oil has a similar effect as water. In fact oil is worse than water because it wets the glow plug where water remains as superheated steam. If you have too much water in your fuel don't throw it out, try a hotter plug first. You can also somtime salvage it by mixing it with higher nitro fuel, though by the time I suspect I have wet fuel its almsot gone and not worth mixing. In fact swithching to an Enya #3 plug will ususally solve wet fuel problems.
PS Also don't throw your fuel out if it turns colors. As far as I know all of the synthetic oils are clear. However all color's of dye are added to the oil or fuel. Since its just for coloring the fuel manufactures don't go for indelible colors and sunlight will cause most of them to turn colors, turn dark, or even disappear!
(in reply to JoanC)
       Post #: 6
Moisture in Methanol - 4/8/2002 5:57:37 PM
BIGRCR
Status: offline
Our engines cannot tolerate water in the fuel at all. I would imagine that this figure is MUCH less than 10%. Fuel manufacturers usually use methanol that contains less than 500 ppm moisture (.05%). You cannot tell how much or if any water in in your fuel by a visual check, water and methanol form nearly an aziotope (become inseperable). The only detection methods are to use very expensive lab equipment.
The problem does not have to do with being lean and opening the needle valve. The engine will not run with the water at all. When running moisture contaminated fuel, the engine will usually start up and then abruptly die. I have experienced some bad fuel that would run untill your got into the air and then would shut down. You will also most likely experience a rash of plug failures while dealing with this bad fuel.
Later,
(in reply to JoanC)
       Post #: 7
Moisture in Methanol - 4/8/2002 8:17:30 PM
downunder-RCU
Status: offline
Well I have to agree with Sport_Pilot here...I don't think water is quite the problem we're all led to believe. In fact I've heard of one guy who even deliberately adds water to his tank because it delays detonation (much the same as acetone does). Water can't harm a plug...the only thing that will destroy a plug is aluminium.
However right now this is just opinion, sometime soon I'll add some water to my tank and go fly to see what happens. I'll also take rpm and head temp readings before and after. Anyone else care to experiment?
(in reply to JoanC)
       Post #: 8
Moisture in Methanol - 4/10/2002 5:50:55 AM
Sport_Pilot
Status: online
Don't know why adding water would ruin a plug. After all when our fuel is burned one of the biggest byproducts is water in the form of superheated steam. Superheated steam is as clear as air, but in cold weather it will condense shortly after leaving the exhaust pipe. Which is why we can see a white trail in the winter but it is nonexistant or faint in the summer.
(in reply to JoanC)
       Post #: 9
Moisture in Methanol - 4/10/2002 4:47:19 PM
BIGRCR
Status: offline
Water is non compressable, coagulates the oil in the fuel and is non combustable. Water will raise the compression in the cylinder and combined with "globs" of oil (because of the water) will "knock" the element out of the plug as well as foul the catalytic action.
Our glow engines are just that, they do not have an ignition spark to keep up combustion.
But go ahead, add water to your fuel and learn the hard way! It's your hobby and your money!
Oh yeh, a lot of things can destroy a plug (other than aluminum). A lean run or two has been known to cause a certain amount of harm to a plug!
Later,
(in reply to JoanC)
       Post #: 10
Moisture in Methanol - 4/10/2002 6:06:49 PM
Sport_Pilot
Status: online
[QUOTE]Originally posted by BIGRCR
[/QUOTE]
This argument has often been repeated before, I am curious where you got this information?
(in reply to JoanC)
       Post #: 11
Moisture in Methanol - 4/10/2002 11:55:54 PM
JoanC
Status: offline
I was talking about moisture, not big amounts of water. I suppose that the moisture that the methanol attracts gets totally disolved with the methanol so there are no "globs" of oil. It is this amount of water that I was asking about and I am concerned of and if it really affects to the engine performance or it is a thing that I must not worry about.
(in reply to JoanC)
       Post #: 12
Moisture in Methanol - 4/11/2002 2:53:02 AM
BIGRCR
Status: offline
"This argument has often been repeated before, I am curious where you got this information?"
I have obtained this information from several years of experience in R/C flying. I have gotten some water contaminated fuel before and it will not run correctly. It will cause you many episodes of dead stick landings at best.
There are reasons that the fuel manufacturers go through a lot of trouble to use and to ensure that the methanol that they use is moisture free. It is not so that someone who knows better than them can add the water back to control timing or for whatever other wonderful reason!
I have also been mixing fuels for nearly 15 years now and have tested these fuels for moisture using a Mitsubishi Moisture Analyzer, by titration.
I have a limited 21 year chemical back ground as a Lab Technician and an Engineered Resins Technician for a major motor fuels and Chemical Industry company, BP Amoco.
BUT I could be wrong!
Later,
(in reply to JoanC)
       Post #: 13
Moisture in Methanol - 4/11/2002 4:52:48 AM
Ladyflyer
Status: offline
Thanks for the expert advice Big ! Very well stated.
_____________________________
LF
When they have to say "NO FEAR" it really means NO SENSE.
(in reply to JoanC)
       Post #: 14
Moisture in Methanol - 4/11/2002 7:56:45 AM
Sport_Pilot
Status: online
Well I don't think any of us want water in our fuel. After we want to burn our fuel and water doesn't burn nor lubricate our engines, so of course the manufactures want their fuel as pure as possible. Obviously our engines will not run on water! The lady wanted to know how much water is a problem. You stated that any water is intolerable. So I guess I should throw out my fuel after the first use? Because you will have water in the fuel the first time you use it. Even if you were to manage to get your pump attached to the fuel can without opening it you will encounter the greatest source of water when you defuel your plane. Since much of our fuel is converted to water when we burn it the muffler pressure has a lot of steam in it. This of course gets into the fuel in our tanks, and is then transfered back to our fuel can when we defuel the plane. So since most of us defuel our plane several times on each gallon of fuel and ususally without having problems. So this is proof that our engines can tolerate at least some water in our fuel, the question asked was how much.
You state that water is incompressable, this is true but our fuel is incompressable also, that is why we get hydralic lock when the cylinder is full of fuel, because it is incompressable. In fact it is one of the descriptions defining liquids and gasses, liquids are incompressable and gasses are compressabel. Now water has as a gaseous form also, it is called, well you know, steam. You also state that water will raise the compression in the engine. The law of partial pressure say's this isn't so. Steam is very compressable and only somewhat denser than our fuel.
To put it anouther way. You take a cylinder of fuel, air, and water vapor at 14.7 psi absolute, this is our average air pressure. Now take away the water and put it into a cylinder of perfect vacume. Now maybe it has a pressure of maybe .5 PSIA that means the pressure of the remaining fuel is 14.2 PSIA. Now you compress each gas to a compression ration of 10 to 1. Now the water vapor is 5 PSIA and the fuel and air is 142 PSI Put the water vapor back into the engine cylinder and the pressure is 147. Thats 10 times 14.7 so it is still a compression ratio of 10 to 1. So water doesn't change the compression ratio. This is the law of partial pressures.
Downunder has it right! In fact the early turbocharged GTO had a water injector to prevent detonation from the boost of the turbocharger. It was I think the first production car with a turbocharger. Actually the injector used a mixture of water and alcohol, but in a pinch pure water would work. Also I recall LF posted a site on racing fuel a while back and water was one of the additives mentioned to reduce detonation, along with acetone, and more exotic additives. Not all of these were for detonation I think.
(in reply to JoanC)
       Post #: 15
Moisture in Methanol - 4/11/2002 3:06:47 PM
downunder-RCU
