11t Pinion Gear on 3900 Motor
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> 11t Pinion Gear on 3900 Motor
Page: [1]
Login
11t Pinion Gear on 3900 Motor - 7/8/2009 2:23 PM
slotdr
Score: 100
Last Login: 1/4/2010
Status: offline
Hi all, I was wondering if putting 11 t pinion gear on my HBK2 with 3900 motor and cnc head would work and if so what would be the results. I am using a Dx6i TX or should I go with a 10t gear
Hide Signatures
       Post #: 1
RE: 11t Pinion Gear on 3900 Motor - 7/8/2009 2:42 PM
noobflyer01
Score: 157
Last Login: 3/16/2010
Status: offline
hey slot, use this calculator for headspeed.  http://dhrc.rchomepage.com/calc.htm  if you're going over 2800rpm on the main blades  then use carbons,.   but yeah you should have no problem going with the 11t pinion.  headspeed will be higher and the esc will have to work harder.  as long as your esc can handle the additonal amp draw you'll be fine.
_____________________________
Trex500ESP
Trex450Pro
Hide Signatures
(in reply to slotdr)
       Post #: 2
RE: 11t Pinion Gear on 3900 Motor - 7/8/2009 10:12 PM
Tommyjoking
Score: 100
Last Login: 7/25/2009
Status: offline
I agree the Dark horse calculator is a good link for figuring gearing , motor + battery size ect. I run an 11t on a 4200kv motor on my king with woodies and and stock head, no problems at all.
Hide Signatures
(in reply to noobflyer01)
       Post #: 3
RE: 11t Pinion Gear on 3900 Motor - 7/9/2009 7:32 AM
jerrymac
Score: 110
Status: offline
Well I guess that Tommy is a lot luckier than me, lol. I put a 4200kv with 11 tooth pinion on one of my King2's that was all stock except for the 43 tooth tail upgrade pulley. The first time I spooled it up , one of the tail blade holders split in half at the bolt hole and the tail blade flew off = crash. I put cnc tail grips on and next spool up one of the main rotor blade grips split at the bolt hole and the main blade flew off and almost hit me. You should be ok though with all cnc grips I would think. I just changed the pinion to a 9 tooth and it hasn't come apart again yet with the plastic grips.
I Never wanna be first. The second mouse to the trap always gets the cheese!
Hide Signatures
(in reply to Tommyjoking)
       Post #: 4
RE: 11t Pinion Gear on 3900 Motor - 7/9/2009 1:51 PM
slotdr
Score: 100
Status: offline
Thanks, does anyone know what the stock main gear has in teeth, is it 140
Hide Signatures
(in reply to jerrymac)
       Post #: 5
RE: 11t Pinion Gear on 3900 Motor - 7/9/2009 2:05 PM
noobflyer01
Score: 157
Status: offline
the stock honeybee king2 is 140T for the main gear.
Trex500ESP
Trex450Pro
Hide Signatures
       Post #: 6
RE: 11t Pinion Gear on 3900 Motor - 7/12/2009 7:54 AM
Tommyjoking
Score: 100
Status: offline
jerrymac
Ugghhh that don't sound good....thats why I wear my mc helmet when I am blade tracking. Maybe my motors are not pulling the listed rating or maybe you got a real hot one...dunno. For the last year I have been using 1500 15 and 20c batts and seem to have adequate power to pull out of close calls. I just switched out my 4200kv for an extreme 400 and it does not have quite the snap of the 4200 but its ok. What make of motor did all that?? I would not want to put one in and get similar results.
Tommy
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
