ready mk3 novice    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> ready mk3 novice
Page: [1]
Login
ready mk3 novice - 7/16/2009 11:19 AM  1 votes
kendo450
Score: 105
Last Login: 11/18/2012
Status: offline
hello guys i am new to the hobby i was given an Irvine Tutor 40 with a futaba exp radio the plane had been crashed and repaired many times and was past its best so i went to my local model shop and brought a Thunder Tiger Ready mk3 having built the kit and installed the OS46 LA which igot with the Irvine i am almost ready to take it out. i would be interested in the views of you guys and any advice . one question i do have regarding the engine is in this model the engine is mounted horizontally it seems to run ok but has cut out a couple of times while idleing
Hide Signatures
       Post #: 1
RE: ready mk3 novice - 7/16/2009 1:53 PM
Korps
Score: 123
Last Login: 2/1/2011
Status: offline
I don't know the aircraft so I cannot comment whether it is a good trainer etc.
I gather that you have never flown from your post.
I would recommend though that you get someone to help you. Let them look the plane over and also get someone who can teach you to fly - an instructor. You could try this on your own, but it might not end to good then. Yes there are people who have been self taught and some that tried.
The problem you have with your engine could possibly be due to your low end which is not set correct or a fuel system problem? Others will be able to help you better with this I think.
But definitely I would recommend getting someone experienced to help you.
_____________________________
Watch out! Dead Man Flying!
SAMAA no. 12334
Hide Signatures
(in reply to kendo450)
       Post #: 2
RE: ready mk3 novice - 7/16/2009 2:35 PM
CGRetired
Score: 221
Last Login: 6/19/2013
Status: offline
Well, that's a step in the right direction. The Thunder Tiger MK2 looks like a trainer.. and you know what they say.. if it looks like a duck.. and so on..
From what I see, it's offered in the UK. I've not seen hobby shops here with it, but that only means I've, me personally, have not seen it. But, as I said, it looks right..
Now, you really need to approach this slowly. You will need someone to teach you how to set up the plane, set up the control throws so that you don't make it TO radical.. or, for that matter, radical at all. You want a nice smooth trainer with no adverse tendencies. So, keep the control throws down to the minimum as stated in the manual (hopefully, there are minimums in the manual).
Have someone go over it completely before you fly it.. making sure that the elevator works as advertised, that the correct contol stick is on the elevator, ailerons, rudder, throttle (sounds simple, but an easy mistake for a beginner) and that the throws are not causing binding on the serovs which will severely shorten battery duration in flight.
Get someone to maiden it for you to make sure it flys... and that it flys within the trim capabilities of your radio.
Get someone to buddy box up with you so you can learn how to fly. This way you won't throw away your hard earned money trying to do the improbable... learning by yourself.
And, best of luck.
CGr.
Skylark 70 - OS .75 AX; Excelleron 90 - OS 1.20 AX; Venus II - OS 1.20 AX; And, I still fly my trainer, Hanger 9 Alpha - OS .46 FX! Some electrics. Airtronics RD8000 - Spektrum DX7 - DX6i. AMA 705964.
Semper Paratus!
Hide Signatures
(in reply to Korps)
       Post #: 3
RE: ready mk3 novice - 7/16/2009 9:48 PM
kendo450
Score: 105
Status: offline
its not a new engine it was used in the irvine  i have been running the engine and fine tunning it seems to run a lot better now i have tried to find a club in my area and so far they have not replied or have a waiting list i have access to a turf field miles from any towns so have been running the plane around on the ground also i have been using a phoenix flight simulator which i have been getting quite good at so will see what happens
Hide Signatures
(in reply to CGRetired)
       Post #: 4
RE: ready mk3 novice - 7/16/2009 11:20 PM
jetmech05
Score: 133
Status: offline
please get an instructor......before anything else
Hide Signatures
       Post #: 5
RE: ready mk3 novice - 7/17/2009 12:06 PM
kendo450
Score: 105
Status: offline
i have been trying to find a club in my area but with no luck so far they either dont reply to my emails or they are full so i am having to look further afield. i do have access to a large turf field so i can carry out tests on the ground but if i cant find a club within reasonable travelling distance i may have to attempt flights on my own i expect a few mishaps along the way self teaching but in the short term it may be my only option
Hide Signatures
(in reply to jetmech05)
       Post #: 6
RE: ready mk3 novice - 7/17/2009 3:10 PM
Korps
Score: 123
Status: offline
quote:
ORIGINAL: kendo450
I understand your problem with getting into a club. I do however think that you should get an instructor first before attempting any flights. I taught myself on a simulator and never went on a buddy box except for 5 minutes with a friends plane. It is possible, but I had my friend next to me when I soloed and that was good piece of mind. Self teaching is possible and one can succeed. I do however think there should be someone next to you when you try to fly. A few mishaps - maybe you will get off lucky, but remember you can also destroy your plane on the first take off run. Remember, an engine can quit on you in mid air or even right after take off? Do you know what to do then? etc etc. There are a lot of things which can go wrong.
I don't want to discourage you or think that you are not good enough. One can be self taught, but so many times it just ends up on negative note.
Good luck to you whatever the route is you decide to take
SAMAA no. 12334
Hide Signatures
       Post #: 7
RE: ready mk3 novice - 7/17/2009 4:43 PM
kendo450
Score: 105
Status: offline
thanks i  will your advice and will continue to try and find an instructor but its very frustrating with the lack of response i am getting
Hide Signatures
(in reply to Korps)
       Post #: 8
RE: ready mk3 novice - 7/17/2009 4:51 PM
jetmech05
Score: 133
Status: offline
go to the club yourself ......most clubs don't respond to emails......as the web master has his hands full just keeping the site up to date.....I am going to be truthful with you, and this is going to sound harsh.....if you attempt to fly that airplane with out instruction you have better than a 95% of crashing the airplane....if you go with an instructor on a buddy box you have better than a 99% chance of taking your airplane home undamaged....
I wish you the very best
Hide Signatures
       Post #: 9
RE: ready mk3 novice - 7/17/2009 5:09 PM
JohnBuckner
Score: 352
Last Login: 6/20/2013
Status: offline
Lack of Response, what Response? internet, forget it expecting fast or any internet responses from many clubs is just about non existant. The fact is most most any club is a collective of people out doing their thing for fun and you simply cannot expect them to be run like a business in most cases even if they have a website.
You have to do you homework and get out there to network. Find them and go there. Please follow the advice of all the folks above. Yes of course its possible to be self taught and in the past that was indeed the only option However that comes at a cost without fail, I don,t care who who you are. That cost is always in the form of many repairs and or total losses (financial) along the way and perhaps even more important much more frustration and that added frustration is what causes so many new starts to give up without accomplishing their goal. See this all the time.
John
< Message edited by JohnBuckner -- 7/17/2009 5:11 PM >
"Keep your controllines tight"
Hide Signatures
       Post #: 10
RE: ready mk3 novice - 7/17/2009 5:10 PM
kendo450
Score: 105
Status: offline
ok i taken onboard what you say i have found a club not to far away and i hope to go  in the morning weather permitting and meet the instructors
Hide Signatures
       Post #: 11
RE: ready mk3 novice - 7/17/2009 6:08 PM
kendo450
Score: 105
Status: offline
ok i have found a club not to far away and i am going along to meet the instructor in the morning.i know it will take time but its the first poitive step so here we go reach for the sky.
Hide Signatures
       Post #: 12
RE: ready mk3 novice - 7/19/2009 1:57 PM
kendo450
Score: 105
Status: offline
ok went down to the flying club field but due to the strong wind nobody was flying so after a few phone calls i got in contact with the duty instructor and rather disappointing to find i am now on the waiting list more frustration but at least its a start
Hide Signatures
       Post #: 13
RE: ready mk3 novice - 7/20/2009 10:21 PM
kendo450
Score: 105
Status: offline
well after finding out i had to go on a waiting list i went back on line and tried to find another club that could help and what luck i have indeed got lucky and my 1st training day is 9th august would have gone earlier but got to go on holiday first
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
