RE: BH Models    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: BH Models
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9   next >   >>
Login
RE: BH Models - 11/7/2009 1:40 AM
grandstand
Score: 100
Last Login: 5/13/2013
Status: offline
Jim , The one picture showes the stock way ..Then I started to tug on the gear and found out I better double up on the Plastic hold dows ..Then I put a washer and collett on the rear wire..Plus the bigger wheels 3in..will help If you dridt off in the grass ..I have a paved runway..Wich helps,........on a plane like this I will set the dead mans throttle ..once it touches down pull the throttle trim back to kill the engine ..I have done this before on Nose-Over prone planes ..Shure is easier to walk out and pick the plane up ,than fix a busted prop and rudder...With you being in NJ .your probably waiting for a good day ...Here in FL . I can go any day and fly..But this weekend is a bummer ..Winds up to 20MPH for the next 3 days ...I should have it finished by Wed. for a maden flight...I have just been putting everything on a Diet..I look at all kinds of ways to keep it light ...LATER Rich
Hide Signatures
(in reply to grandstand)
       Post #: 101
RE: BH Models - 11/7/2009 2:13 AM
grandstand
Score: 100
Status: offline
pix...........................
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 102
RE: BH Models - 11/7/2009 2:17 AM
grandstand
Score: 100
Status: offline
more pix
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 103
RE: BH Models - 11/7/2009 2:30 AM
_Tommy D
Score: 100
Last Login: 1/6/2013
Status: offline
quote:
ORIGINAL: grandstand
Tommy, What are you doing up at 5:25 AM ..Well goint to work now but will get pix and more to ya when I return this PM.....Rich
Wow... I knew it was late but I had no idea it was THAT late! No wonder I was so tired today at work.
Whats the theory on the collet/washer on the trailing dogleg? Are you trying to prevent them from pushing through the wing in the event of a hard touchdown?
Tommy D
_____________________________
http://tommydsblog.blogspot.com/
Hide Signatures
       Post #: 104
RE: BH Models - 11/7/2009 4:25 AM
jcw111
Score: 100
Last Login: 4/24/2013
Status: offline
Tommy, must chime in here. Yes the way Rich has the trailing support is to keep it from pushing thru the wing. On mine I soldered a approx 1" square thin brass sheet to the support strut. I can tell you first hand that it worked very well on my last flight. Do it anyway you want but "do it" As I said in my last post the 2 point attacment of the cuff to the wing worked as it should. It stayed put while all the rest of the stuff exploded. There was no damage to the wing whatsoever.
Jim W
Hide Signatures
(in reply to _Tommy D)
       Post #: 105
RE: BH Models - 11/7/2009 4:35 AM
_Tommy D
Score: 100
Status: offline
I would think the washer would just blow through the wing sheeting on the bottom vs the top if pressed.
While it's definitely food for thought, I think I would like to see your brass sheets Jim
Flying tomorrow but not the Lion.
Tommy D
Hide Signatures
(in reply to jcw111)
       Post #: 106
RE: BH Models - 11/7/2009 6:50 PM
jcw111
Score: 100
Status: offline
Tommy
In place of the washer and wheel coller simply cut a 1" square piece of 1/64 brass and drill a hole in its center. Elongate the hole so it will fit flat on the wing surface when placed on the strut support and make sure it is flat  Then solder it in place. I tinned all the surfaces where it was to be soldered and soldered it together on the wing surface. Not enough heat to bother anything on the wing. This will keep the support wire from even thinking about pushing thru the wing.  Do not glue the brass to the surface.  I speak from experience not theory. This mod works. My extremely hard landing caused both strut supports to bend into a semi  "U" shape. It took a lot of energy to bend this thing.  Easy to straighten out with a good pair of pliers. Sorry bout the pictures. My camera is not working. Again the 2 point fastening of the wheel cuff also worked. They were both in tact and did not crack or break. As I said befor the rest exploded and took a lot of CA to fix. No parts available from Hobby People which from what I have since heard is typical.
Jim W
Hide Signatures
       Post #: 107
RE: BH Models - 11/7/2009 11:58 PM
_Tommy D
Score: 100
Status: offline
Thanks for the update Jim
If you notice HP has a bunch of new BH models listed AND some spare parts as well! Perhaps pants for the Lion will be on the next boat out of China?
Tommy
Hide Signatures
       Post #: 108
RE: BH Models - 11/8/2009 3:00 AM
grandstand
Score: 100
Status: offline
I just went on HP web sight ..See they have a 50cc Gilmore red lion..84in WS, Must be by the same builders in TIE Land..At $519 It must be another HAY RACK like the one Im building ...O Well Rich
Hide Signatures
       Post #: 109
RE: BH Models - 11/8/2009 5:00 AM
GaGeeBees
Score: 313
Last Login: 5/12/2013
Status: offline
I'm just a country boy from Georgia and don't quite understand what you mean when you call this plane a HAY RACK...
...and then the unthinkable happened!
Hide Signatures
       Post #: 110
RE: BH Models - 11/9/2009 3:23 AM
grandstand
Score: 100
Status: offline
A Hay Rack is a Broken down trailor that hauls hay..A Eaton Ill. Farmer expresion...I guess you got to be a Yankey to know....rich
Hide Signatures
(in reply to GaGeeBees)
       Post #: 111
RE: BH Models - 11/11/2009 6:12 AM
_Tommy D
Score: 100
Status: offline
Wow.. tough crowd! I think the Lion is a nice model. A lot better then I could ever build even if it was offered from say a lazer cut kit. Then again I have not flown mine yet!
Orig powered by a KMS 4120/05 on 4S I'm switching it to a 4130/07 on 6S. It might push the weight up close to that 7lb mark BUT Ill be able to swing a 15" prop vs the 12". Watts will remain the same at or about 1KW but amps will be much lower.
Tommy
Hide Signatures
       Post #: 112
RE: BH Models - 11/11/2009 1:13 PM
GaGeeBees
Score: 313
Status: offline
7 lbs sounds like a lot. What is the wing loading (in ounces per square foot) at that weight?
Hide Signatures
       Post #: 113
RE: BH Models - 11/11/2009 9:13 PM
grandstand
Score: 100
Status: offline
Got this Hay-Rack all done..As soon as this Wind clears out of Florida I will put it in the sky ...It toped out at 5.7 Lbs dry..CG is on the money by moving the battery forward ..Will be back ....Rich
Click for fullsize
Hide Signatures
       Post #: 114
RE: BH Models - 11/11/2009 11:19 PM
onewood
Score: 100
Last Login: 5/15/2013
Status: offline
fellow modelers...I have one of these and love it. Magnum 70 4S is perfect. Flys wonderful. Gear were a little tough to figure out but got that worked out. ABS wheel pants are pretty cheap but work. Have about 20 flights on the model
Hide Signatures
       Post #: 115
RE: BH Models - 11/11/2009 11:40 PM
grandstand
Score: 100
Status: offline
That is good news..I really like the looks of mine..But also the wheel pants are Minkey Mouse...I will fly it first then if i really like it ..I will remove the wheel pants ang glass them with light glass then Repaint them the corect color ..As you can see I never put the decals on it...The plane is nice but I worked more on the wheel Pants ,than I did to build the plane ..Plus I think I used every tool in my Tool box...May be putting it in the air friday ....LATER ...Rich
Hide Signatures
(in reply to onewood)
       Post #: 116
RE: BH Models - 11/12/2009 12:35 AM
onewood
Score: 100
Status: offline
grandstand...I was abel to balance mine with out adding any weight. I did balance it upside down. I used the recommened throws on the controls. It is a **** cat to fly. I used a Pitts style muffler. Once you land and roll out a little ways keep full up elevator in it until it stops. Wants to nose over but not bad. I don't care what the rest of the world says it is a neat plane and looks good in the air.
Hide Signatures
       Post #: 117
RE: BH Models - 11/12/2009 2:23 AM
_Tommy D
Score: 100
Status: offline
Rich
Can I ask what size prop and about how many RPMs is it turning.
Best of luck on the maiden!
Tommy
Hide Signatures
       Post #: 118
RE: BH Models - 11/12/2009 2:24 AM
grandstand
Score: 100
Status: offline
Onewood, I see you have a 70 four banger..I had a OS SF 46 like new laying around ..So that is my set up ..but the battery had to go on top of the engine firewall...I figured I would use this engine as that is what they show in the book inst. ....Plus I like light planes ..Mine tiped out at 5.9 Rich
Hide Signatures
       Post #: 119
RE: BH Models - 11/12/2009 2:27 AM
grandstand
Score: 100
Status: offline
Tommy, I will fire it up friday and tune it then...Im starting out with a 12-6 prop...Rich
Hide Signatures
       Post #: 120
RE: BH Models - 11/12/2009 2:41 AM
grandstand
Score: 100
Status: offline
Got this one on the work bench next....Rich
Click for fullsize
Hide Signatures
       Post #: 121
RE: BH Models - 11/12/2009 2:45 AM
_Tommy D
Score: 100
Status: offline
Old Kyosho?
NICE!
Did you see the new BH Ryan? I'm a sucker for Ryans as well
Hide Signatures
       Post #: 122
RE: BH Models - 11/12/2009 4:36 AM
GaGeeBees
Score: 313
Status: offline
quote:
ORIGINAL: _Tommy D
Old Kyosho?
NICE!
I think that's the new Seagull Z. The Kyosho had an all fiberglass fuse.
Hide Signatures
       Post #: 123
RE: BH Models - 11/12/2009 5:35 AM
_Tommy D
Score: 100
Status: offline
quote:
ORIGINAL: GaGeeBees
It’s up there for sure. Figure 58”s of wing.. 10”s of cord… 580… at 7lbs <112ozs> .. what’s that in the 27 ounce range?
Currently RTF I’m at 6lbs 7ounces so just how much heavier is 7lbs?
I’m not terribly scared as Jim W is over 7.25lbs and has not reported any nasty tendencies.
quote:
ORIGINAL: GaGeeBees
quote:
ORIGINAL: _Tommy D
Old Kyosho?
NICE!
Good eye on your part. I would research it but it would cost me 2 things I don’t have. Time, Space and Money!
Tommy
Hide Signatures
       Post #: 124
RE: BH Models - 11/12/2009 5:50 AM
GaGeeBees
Score: 313
Status: offline
Yep, that's pushing 28 oz/sq ft. That's not terrible.
I've looked over the Seagull Z and it's not a bad ARF for the money. The landing gear struts look like the weakest link (just like on this model).
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
