RE: MOKI RADIAL Care and Maintenence    Gallery
Logged in as Guest
Users viewing this topic: Michael Helfrich
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: MOKI RADIAL Care and Maintenence
Page: <<   < prev  81 82 [83] 84 85 86 87 88 89 90   next >   >>
Login
RE: MOKI RADIAL Care and Maintenence - 6/20/2012 11:40 PM
mogman
Score: 100
Last Login: 5/23/2013
Status: offline
Here you go......This is on a 400, I can't imagine the other mokis being different.
#1...lifter
#2...pin shows breather? or air intake for pulse piston?
#3...ign. sensor
#4...sensor removed, this is where I added oil.
Cheers,
Dave.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to mogman)
       Post #: 2051
RE: MOKI RADIAL Care and Maintenence - 6/20/2012 11:41 PM
Scott Prossen
Score: 106
Status: offline
Thanks Dave. The pictures will help those who don't know the terminology.
Scott
Hide Signatures
       Post #: 2052
RE: MOKI RADIAL Care and Maintenence - 6/21/2012 12:26 AM
mogman
Score: 100
Status: offline
Just thought of something...I've heard of people losing pushrods...nothing to prevent the lifter from departing the engine also...might be prudent to carry a couple of spares?
Hide Signatures
(in reply to Scott Prossen)
       Post #: 2053
RE: MOKI RADIAL Care and Maintenence - 6/21/2012 12:40 AM
Scott Prossen
Score: 106
Status: offline
That's perfect Dave. Thank you. Now everybody will now what to do. Except the blind guy just called me and asked for it in braille. Can you do that next!?!? Ha!
All the best friend. See you in Fall.
Scott.
Hide Signatures
       Post #: 2054
RE: MOKI RADIAL Care and Maintenence - 6/21/2012 12:56 AM
mogman
Score: 100
Status: offline
I would be interested in hearing from Goetz Vogelsang on this issue. Being that he is a Moki service centre, he may have an opinion on grease vs oil in the front housings.
Dave.
Hide Signatures
       Post #: 2055
RE: MOKI RADIAL Care and Maintenence - 6/21/2012 10:37 PM
Growler84
Score: 105
Last Login: 5/22/2013
Status: offline
I talked to Goetz about the lubrication in the front case of the 250 since ours is an earlier version with the smaller exhaust tubes. He ask me to tell everyone that on the early 215/250 the grease used during assembly will harden and migrate to the outer walls of the case as discussed in this forum. HOWEVER, he emphatically stated that the newer 215/250 are packed with a vastly superior SKS grease, which requires NO additional lubricant or needless dissasembly of the engine. He cites as an example a 250 used very hard by a major kit manufacturer and sent to him with over 400 flights on it. Goetz said the inside of the front case on the engine was perfect with absolutely no wear on the internal components. The early 250 my friend Phil is runing in his CARF Corsair has OVER 25 hours of run time on it with no issues other than a couple of pushrods we lost before we learned how to properly lubricate the valve train.
In a related note and on the subject of valve train lubrication, we talked to a Red Line oil engineer about the best lubrication to use on the valve train and more importantly to lubricate the exhaust valve stems. He said, whatever lubricant you use make sure it IS NOT silicone-based because even with PTFE (as many silicone spray lubes advertise) the silicone-based lubricant will NOT hold up under the engine heat. Red Line recommended a high grade compressor oil they sell in three viscosities. We chose not to go with their oil and instead have settled (again, for 25+ hours) on TRI-FLOW spray lube. TRI-FLOW has excellent pennetrating properties (for working the oil down the exhaust valve stems) and more importantly, it withstands up to 475 degrees F. Our valvetrain lubrication regimen is: Lube external valve train every flying day. Lube external valve train and exhaust valve stems every 6 flights (our flights are 20+ minutes each). We lube the exhaust valves by depressing the valve rocker, removing the pushrod then filling the pocket around the top of the exhaust valve with TRI-FLOW and depressing the valve spring to allow the lube to migrate down the valve stem. Obviously each cylinder needs to be vertically oriented with the valve pocket pointed up. This creates work with the Corsair because the wings have to be removed and the fuselage rotated around in the cradle. The truth data: after the pushrod losses at the 5-hour point in the engine's operational life we adopted the regimen I laid out and have not lost a pushrod since.
In summation:
-From Goetz, do not take these engines apart needlessly, crappy case grease only applies to early 215/250 (like ours).
-Stay away from silicone lube, get oil down into the exhaust valve stem because when the exhaust valves go dry and coke up they stick and you lose pushrods.
Phil's Corsair is the one posted in the youTube link by Patrick a page back or so.
_____________________________
Greg
Hide Signatures
       Post #: 2056
RE: MOKI RADIAL Care and Maintenence - 6/21/2012 11:57 PM
wingstrut
Score: 100
Last Login: 5/24/2013
Status: offline
Growler84, thanks for the info that will save me a lot of work, as I stated earlier, I remove the pushrods and lube the sockets and lube everything you stated but I also lube the lifters.
Now the big question, ..How do you tell the new 215/250 engines from the old 215/250 ones?
Waco Brother #216
Hide Signatures
(in reply to Growler84)
       Post #: 2057
RE: MOKI RADIAL Care and Maintenence - 6/22/2012 12:04 AM
wphilb
Score: 105
Status: online
What about the 150's? What is the situation with those engines internal grease?
Thanks to all for all the info, makes you really wish a decent manual came with these engines!
Whit
Hide Signatures
(in reply to wingstrut)
       Post #: 2058
RE: MOKI RADIAL Care and Maintenence - 6/22/2012 1:05 AM
Jaketab
Score: 100
Status: offline
quote:
quote:
Appropriate questions indeed.
Jaketab
Hide Signatures
(in reply to wphilb)
       Post #: 2059
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 1:10 AM
wingstrut
Score: 100
Status: offline
Hey fellas, I thought I should mention that gear oil with GL-5 rating which has EP additives is corrosive to yellow metals, such as bronze and brass.
It looks like the Moki has yellow metal bushings in it so be careful if you select a gear oil because you could be doing more harm than good.
Just thought I would pass this info along..........Ron
I hope someone will tell us how to tell the difference between the old 215/250's and the new 215/250's so we know which grease we have in the front housing.
Thanks for all the support on this subject.
Waco Brother #216
Hide Signatures
(in reply to Jaketab)
       Post #: 2060
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 7:27 AM
lelle-4
Score: 100
Last Login: 2/12/2013
Status: offline
Hello everyone.
This answer has been given to me by Moki factory, so this is the greese what they use.
"The grease type what we use: SKF LGHP 2/1 High Performance
polyurea -40 to +150 º C "
Lelle
Hide Signatures
       Post #: 2061
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 11:44 AM
samparfitt
Score: 125
Status: offline
growler84,
Is this the product that you are using?
http://www.triflowlubricants.com/Tri-Flow_Superior_Aerosol_Lubricant.html
G. Samuel Parfitt
Hide Signatures
       Post #: 2062
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 11:50 AM
mick15
Score: 105
Status: offline
In spite of all that has been said and written, grease is still not the best lubricant for a gearbox!
The best you can hope for is a very small amount lubricating each component over and over again, 99% of the grease in the housing is doing nothing.
I will stick with oil.
m
Hide Signatures
(in reply to samparfitt)
       Post #: 2063
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 12:38 PM
wingstrut
Score: 100
Status: offline
Mick, I totally agree with you, and I understand that you have the older Moki engines that had the grease problem, you have the correct solution.
I am wondering if the so called new grease will flow at low temperature to migrate to the required areas, the reason I am wondering is because the stuff seems to get by the carb pump piston into the festo tube, so I'm assuming the grease must be liquifying to some extent.......Maybe not!
The only way to know is to get some of the LGHP 2/1 grease and warm it up, if it doesn't flow then I will add oil......Ron
I am not disagreeing with anyone, I am trying to bring up things we need to consider and possibly find an answer to before we change anything.
These are wonderful engines and quite an investment so I think we need to investigate completely before reacting.
I am sure everyone will agree our main problem is the lack of instructions and information from the factory!!!!!!
Waco Brother #216
Hide Signatures
(in reply to mick15)
       Post #: 2064
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 12:48 PM
mick15
Score: 105
Status: offline
You raise an interesting point, if the grease heats to oil why not use oil in the first place. I’m not trying to influence anyone just saying the way I treat my engines.
One of my 250s is new but that doesn’t change the way I treat it.
m
Incedentally I don't believe the grease does melt as it seems to stay all around the inside of the cam housing.
Hide Signatures
       Post #: 2065
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 2:44 PM
Jaketab
Score: 100
Status: offline
http://www.mapro.skf.com/products/lub_lghp2.htm
Hide Signatures
       Post #: 2066
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 4:05 PM
wingstrut
Score: 100
Status: offline
Thanks Mick and Jaketab, I just got an idea to solve this whole dilema,... drill a small hole in top of the forward housing, then install a zerk fitting in the lower front housing, then before every day of flying just give it a couple of pumps of grease or until it comes out the hole in the top.........Problem solved. Ha!Ha!
I will go away now.....Ron
Waco Brother #216
Hide Signatures
       Post #: 2067
RE: MOKI RADIAL Care and Maintenence - 6/24/2012 4:16 PM
mick15
Score: 105
Status: offline
Bye bye!! lol.
m
Hide Signatures
       Post #: 2068
RE: MOKI RADIAL Care and Maintenence - 6/25/2012 12:59 AM
crusier
Score: 100
Last Login: 1/16/2013
Status: offline
Ok Guys, I have a moki 215 6-7 years old bought from RCS. only finish the plane last year . I have 80 minutes of run time. Friday I was flying, great first fligh. Second flight not so great. Grinding noise throttled back engine quit. Went to turn it over by hand one place felt grinding. Removed front cover found brass gears. Three of the teeth stripped off dont know why. Engine came out of time valve damage and lifting rods damage on two cylinders. have not taken it apart any futher. First does anyone have a parts list, best place to buy parts? Anyone know how to time this motor. There is a timing mark on the steel primary gear what do you line this up with. Any info helpful thanks Bill
Hide Signatures
       Post #: 2069
RE: MOKI RADIAL Care and Maintenence - 6/25/2012 3:00 AM
mogman
Score: 100
Status: offline
www.vogelsang-aeroscale.com
They sell the Moki and are a service center.
Hide Signatures
(in reply to crusier)
       Post #: 2070
RE: MOKI RADIAL Care and Maintenence - 6/25/2012 7:18 PM
Growler84
Score: 105
Status: offline
Sorry for the delay in replying guys. I was in Chino over the weekend flying the big Corsair against an equally big Zero at the Southern California Scale Squadron fly in, which was outstanding by-the-way.
Yes, that is the TRI-FLOW we use.
How to tell any early 215/250 from a late one? Call Goetz Volgelsang for the real truth data but I will tell you Phil's "early" 250 has smaller diameter exhaust tubes leading from the head to the collector ring (I understand these are the same as the 215 tubes). The newer 250s use a larger diameter exhaust tube. By-the-way, Goetz said the 250s with the larger exhaust tubes will make about 300 more RPM and sound a bit throatier/louder.
I do not know what the grease story is on the 150, one can only assume its the same as for the other radials Moki produces. Again, call Goetz for the 100% answer.
Click for fullsize
Greg
Hide Signatures
       Post #: 2071
RE: MOKI RADIAL Care and Maintenence - 6/26/2012 5:23 AM
MANFRED
Score: 105
Status: offline
Any word on the new ignition?
Time flies like a brick thru the window of life.
Hide Signatures
       Post #: 2072
RE: MOKI RADIAL Care and Maintenence - 6/26/2012 6:22 AM
Detlef Kunkel
Score: 100
Last Login: 11/9/2012
Status: offline
quote:
ORIGINAL: MANFRED
The new igniton is here in my hands; I have a prototype version  installed on a Moki 215.
it is running as fine as can be, but the company that makes the ignition is still working on some development for serial production.
I guess it wont´t take long until it is officially available on the market.
BTW it is the same company that has developped the ignition for my V-4 engine, so we are in very good hands with that
Hide Signatures
(in reply to MANFRED)
       Post #: 2073
RE: MOKI RADIAL Care and Maintenence - 6/26/2012 1:34 PM
77chickenhawk
Score: 105
Status: offline
Who's Zero is that? And what kit is it? Wow sor a second i thought it was my plane lol it looks exactly like mine lol
Just Make It Look Real !!!
Hide Signatures
       Post #: 2074
RE: MOKI RADIAL Care and Maintenence - 6/26/2012 7:54 PM
Growler84
Score: 105
Status: offline
Brian's Zero is a 50 lb Meister Scale with a DA-100. Speed wise it was no match for the Moki-motivated Corsair. The Zero turned like a bat however, true to scale all around!
Greg
Hide Signatures
(in reply to 77chickenhawk)
       Post #: 2075
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.844RCU1
