RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
Page: <<   < prev  15 16 [17] 18 19 20 21 22 23 24   next >   >>
Login
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/13/2010 2:58 PM
flapwad
Score: 100
Last Login: 2/8/2012
Status: offline
Hi,
I just bought and completed your 56" yak 52 model. It's the $80 special blue version 2 airplane with the pull-pull and strengthened wings and tail: see link to your add here:
http://www.nitroplanes.com/yak523d5056v.html
Very nice kit and a good deal for the price to be sure. I had read on RCGroups.com and RCUniverse.com forums about the many stabilizer failures the earlier version of this airplane had but was reassured by the note in the advertisement that says that version 2 has a strengthened stab and rear fuse. During assembly, I thought the stabilizer still looked mighty weak but I went ahead and built the plane per directions assuming the problems had been fixed.
My plane flew extremely well on the first flight, but on the second time up the stab fluttered and sheared off flush with the fuselage in straight and level flight at part throttle, causing a major crash. The fuselage survived with minor damage but both wings were severely damaged. When I looked at the failure, I could see that the stab has no reinforcement at all, it’s just made of 5/16" soft balsa sticks with no spar or sheet stock and is very flimsy, so it's no wonder it failed. Apparently whatever upgrade was made has not solved the problem the old version had with stabilizer failures. I can send pics of the fracture if it helps. I accept partial responsibility for the in-flight failure because I should have trusted my instincts and removed the covering from the stab and reinforced it properly, but this is still a real weak link in the design.
I wan to buy a replacement airframe because it's a great kit, but I see the sale has ended and the same plane (although red instead of blue) is now $125. I don't want to pay 50% more for a replacement than I paid for the original.
The only consideration I’m asking from NitroPlanes is to allow me to buy a replacement airframe for the same $80 I paid for the original. I’ll reinforce this one for sure! Here is the link for the identical version 2 plane that I ordered, except in red (the blue is out of stock now.)
http://www.nitroplanes.com/20redyak523d.html
I note you have another 56" yak for $99 but it is different, doesn't have the pull-pull and doesn't appear to have inserted wings or a firewall setup for electric motor. I definitely am not interested in that one.
my order number is yhst-17210252890263-146654.
Thanks and keep up the good work supplying low cost RC gear.
Scott
By the way, your message queues are full at RCGroups and RCuniverse and it is no longer possible to send PMs to you from those forums, you might want to clean them out.
Hide Signatures
(in reply to hillbillyexpress)
       Post #: 401
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/14/2010 3:34 AM
flyboy12
Score: 100
Last Login: 5/12/2013
Status: offline
have any of you guys gotten any responce from nitro planes lately. I can't even get them to tell me if and when they are going to get parts in for my jet or my FW 190
Hide Signatures
(in reply to flapwad)
       Post #: 402
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/15/2010 8:24 AM
lsburruss
Score: 100
Last Login: 6/29/2012
Status: offline
John, I am inquiring about a new cowl and manual for the Super Chipmunk-40 ARF. Are they available? If so, please advise cost and delivery. Thank you, LSB (burruss@usa.net)
Hide Signatures
(in reply to nitrostaff1)
       Post #: 403
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/15/2010 5:59 PM
marshallfamily
Score: 100
Last Login: 5/10/2012
Status: offline
When are replacement parts for the 1450 mm P-51 going to be available? Specifically the 2 blade spinner, electric motor, ESC, tail, wing, and etc. Lack of replacement parts is a killer.
Hide Signatures
(in reply to SamuelG)
       Post #: 404
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/16/2010 3:51 AM
foambreaker
Score: 105
Last Login: 4/21/2013
Status: offline
Try  www.pw-rc.com
Hide Signatures
(in reply to marshallfamily)
       Post #: 405
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/16/2010 6:06 AM
marshallfamily
Score: 100
Status: offline
Thanks!
Hide Signatures
(in reply to foambreaker)
       Post #: 406
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/17/2010 6:46 PM
Galand
Score: 100
Last Login: 7/14/2012
Status: offline
I own two Badius Accipiter gliders bought from Nitroplanes. Where can I find replacement wings?
Hide Signatures
       Post #: 407
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/17/2010 10:57 PM
Jabird73
Score: 100
Last Login: 6/10/2011
Status: offline
I looked through website, cant find this part.. Ultimate 50cc stab and elevators. the right side separated in flight. Still flew good and got it down without issue.. But alas, I need a new one. Do you have them?
Hide Signatures
       Post #: 408
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/21/2010 4:19 PM
gbooysen
Score: 100
Last Login: 5/2/2013
Status: offline
Super Chipmunk 40, replacement cowl needed!! any body have any idea where I can get one? they have been out of stock at nitromodels this entire year.
tnx
Hide Signatures
(in reply to Jabird73)
       Post #: 409
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/25/2010 5:28 AM
ncpweld
Score: 100
Last Login: 3/26/2013
Status: offline
NITROMODELS STAFF,
HELP PLEASE,
I need a new wing set for the CMPro F6F Hellcat- 90.
Please respond back to let me know if available.
Joe
Hide Signatures
(in reply to 03svtsnakevert)
       Post #: 410
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/26/2010 1:46 PM
wickedxter
Score: 100
Last Login: 11/13/2010
Status: offline
 order # yhst-17210252890263
plane: red ez hawk
probelm:
i've assymbled the plane and exp. problems when I turn on the trans. and plug in the bat. I get no responce from the servo's or  no beep from the ecs unit. I Think its either the Rx or the Tx. Plz help
Hide Signatures
       Post #: 411
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/28/2010 6:39 AM
Sharpeye22
Score: 120
Last Login: 5/23/2013
Status: offline
I have a CMP Zero Fighter 50cc - 80" ARF and recently flipped it over on landing.  Unfortunatly it broke the canopy.  Is it possible to buy a new canopy?  The one I have is the one from this page of your site: http://www.nitroplanes.com/cmpzefi80arf.html
Thank you,
_____________________________
Larry
Saito Club #692
Hide Signatures
(in reply to wickedxter)
       Post #: 412
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/28/2010 6:44 AM
Sharpeye22
Score: 120
Status: offline
I also have a Boeing P-26 Peashooter 90 - 71" ARF that also has a broken canopy.  Is it possible to buy a new canopy for this airplane?  The one I have is the one from this page of your site: http://www.nitroplanes.com/boppe9071arf.html
Thank you,
Larry
Saito Club #692
Hide Signatures
(in reply to Sharpeye22)
       Post #: 413
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/29/2010 12:46 AM
opjose
Score: 280
Last Login: 5/24/2013
Status: offline
A Beatiful plane! I wish the manufacturer would go back into production on those Peashooters.
I've been wanting one since I ran accross that listing.
Unfortunately the lack of a sellable plane also points to a lack of parts too...
Don''t worry, be happy and fly something!
Hide Signatures
       Post #: 414
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/29/2010 5:26 AM
Galand
Score: 100
Status: offline
quote:
ORIGINAL: Galand
After an e-mail to Nitro they called me and are shipping 1 set of polyhedral wings.
Nice!!!
Hide Signatures
(in reply to Galand)
       Post #: 415
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 10/29/2010 6:42 AM
flyboy12
Score: 100
Status: offline
I still have not heard from them about a new canopy for my 71" FW 190 and a new 64mm fan for my F18
Hide Signatures
       Post #: 416
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/2/2010 5:34 PM
wayupnorth
Score: 100
Last Login: 9/5/2012
Status: offline
Hi. I need a replacement cowl for the Edge 540T 46 - 52". My order # was yhst-17210252890263-139834. Here is a link to the ARF: http://www.nitroplanes.com/ed544652niga.html. Thanks.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to flyboy12)
       Post #: 417
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/3/2010 7:20 PM
wizkid
Score: 100
Last Login: 1/3/2012
Status: offline
Hello NitroModels
Do you have a estimate when Item#: 93A40-13-LandingGearSet will be in? I just got the Flying Tiger kit, and I want to put the retracts in. Note that I'm a bit disappointed that you advertise that the kit has the retracts, and down below you point out it doesn't have them. You should go to Airfield and get them to include them! Other then that, the plane looks great so far (I haven't taken everything out and inspected it yet though)
Thanks!
Hide Signatures
(in reply to wayupnorth)
       Post #: 418
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/4/2010 12:10 AM
Skoffer
Score: 100
Status: offline
Nevermind, taken care of on rcdiscuss.com
< Message edited by Skoffer -- 11/4/2010 4:30 AM >
Hide Signatures
(in reply to wizkid)
       Post #: 419
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/6/2010 2:24 AM
Fred420
Score: 100
Last Login: 3/4/2013
Status: offline
quote:
ORIGINAL: opjose
To speed things up please do the following.
- Always provide your order number ( usually begins with YSTxxx ).
- Provide a link to the web page showing which product you purchased.
- Include a description of the item you are trying to obtain.
- If possible pictures help.
Please note:
- If a component is not in stock it can take a while to get a replacement from the manufacturer.
- Nitroplanes may at it's discretion pull requested parts from new aircraft for you.
Super Chipmunk Cowling........listed on your parts page.........it has been OS for quite a while.
If they are still producing the aircraft, should they not have them?
Any chance someone could make a call, email, or even a fax to the factory to check for sure?
It is a shame........nice aircraft, good quality.........no spare parts.
So................can you use your descretion and pull a cowling for me?
Fred
Dave "Sparky" Davis - RCCA #870
"Earth is the insane asylum for the universe"
Hide Signatures
(in reply to opjose)
       Post #: 420
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/6/2010 9:34 AM
bamaguy0
Score: 100
Last Login: 12/28/2012
Status: offline
yhst-17210252890263-149194
Airfield RC P51 Mustang Blue http://www.nitroplanes.com/93a275-800p51-blue-arf.html
Need the red plastic "firewall" piece, and blue spinner.
-Cameron
Hide Signatures
       Post #: 421
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/8/2010 5:09 AM
rlytle
Score: 100
Last Login: 5/21/2013
Status: offline
I need a cowl for my Yak 54 like this one 90A162R_Gas_Yak54-3DRed. I purchased three of these planes late last year or earlier this year. Any chance you can help?
Ray
Hide Signatures
       Post #: 422
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/16/2010 10:08 PM
N215PB
Score: 100
Status: offline
Need parts for DYNAM GRAND CRUISER, props and spinners, when will they be available?
Larry
"My wife says if I buy one more airplane she''s gonna leave me, Gee I''m gonna miss her"
Hide Signatures
       Post #: 423
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/18/2010 9:30 PM
noveldoc
Score: 115
Last Login: 2/26/2013
Status: offline
re: http://www.nitroplanes.com/90a268.html Item#: 90A268-Senorita-EP-Trainer, order # 995690.
Got this item UPS yesterday. Undamaged intact box. Lots of missing items; unacceptable for sure.
Items missing are: aluminum front wing joiner, metal rear wing joiner, bag #4 - horiz stab and elevator assembly, bag #6 - sub bag with 4 x mounting screws, Bag #7 and subbag - windshield and screws, bag #8 and sub bag A & B - Complete LG setup, also bag # 10, 11, 12, 13 and 14.
Rather pitiful performance here. You can reach me ASAP at tshafer3661 (at) charter.net.
Tom Shafer
< Message edited by noveldoc -- 11/18/2010 11:23 PM >
Hide Signatures
       Post #: 424
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/20/2010 5:23 PM
noveldoc
Score: 115
Status: offline
Just a follow up. Melissa, manager from Nitro, called with 24 hours of getting notifying email. She said she will locate the missing parts and mail them Monday. The box was sealed at factory so appears the screw up was there.
Tom
Hide Signatures
(in reply to noveldoc)
       Post #: 425
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
