RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/26/2009 1:58 AM
nitrostaff1
Score: 110
Last Login: 3/7/2011
Status: offline
quote:
ORIGINAL: WarbirdFlyer404
Hi John im very intrested in the 120 J3 Cub, I have a Zenoah G26 riding the bench and need to install it on something. Will the 120 J3 Cub hold up to this engine?
I can not be sure but Horizon hobby said this is ok because this engine, Zenoah G26, is meant to beef up 1.20 size planes.
John
Nitro Planes
_____________________________
THE BEST LIPO BATTERIES
http://www.hobbypartz.com/lipobatteries.html
Hide Signatures
(in reply to WarbirdFlyer404)
       Post #: 226
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/26/2009 2:13 AM
nitrostaff1
Score: 110
Status: offline
ok I'll have it go out today.
John
Nitro Planes
quote:
ORIGINAL: skyrider2
John,
Yes, please send the rudder and bill to my original order.
skyrider2
quote:
ORIGINAL: nitrostaff1
Yes I do have a replacement rudder and it's $25 shipped to you. Can I bill this to your existing order?
John
Nitro Planes
quote:
ORIGINAL: skyrider2
John,
I have a CMP020_Gas-Corsair120 purchased on
Order # yhst-17210252890263-54262 dated 9/17/2008.
Web Page: http://www.nitroplanes.com/f4ucorsair40.html
I broke the rudder on a noseover and need a replacement. I see that this model is back in stock so I figured you may have a replacement rudder. Please PM me with info.
Ed Redman (skyrider2)
Hide Signatures
(in reply to skyrider2)
       Post #: 227
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 11/26/2009 10:10 AM
Ralphbf
Score: 100
Last Login: 7/6/2011
Status: offline
You can try this one http://www.nitroplanes.com/fm08-102a.html
John
Nitro Planes
quote:
ORIGINAL: Ralphbf
I need a roll of covering for the silver Tiger Moth.
This link is for the 2m~200mX0.65m Cadmium-yellow, not the silver
Ralph
Hide Signatures
(in reply to nitrostaff1)
       Post #: 228
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/1/2009 4:04 AM
Red Raider
Score: 105
Last Login: 5/18/2013
Status: offline
I'm in need of a cowl for my Nitroplanes (CMP) P-40 Warhawk. I found this number on your website: CMP40_140-COWL. Any way to know when they will be available??
Steve
Fly it like you stole it
Hide Signatures
(in reply to SamuelG)
       Post #: 229
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/1/2009 5:11 AM
ashdec87
Score: 100
Last Login: 2/8/2010
Status: offline
Any luck on the canopy for the CL-415?
thanks
ash
Hide Signatures
(in reply to Red Raider)
       Post #: 230
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/4/2009 12:27 AM
tailer1
Score: 100
Last Login: 3/14/2011
Status: offline
I need to order a replacement cowl for (2008 Red Yak 52 3D 50 - 56" Version 2 Nitro Gas )
Thank you
Charles Bucci
414 425-2930
Hide Signatures
       Post #: 231
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/4/2009 4:40 AM
Ralphbf
Score: 100
Status: offline
How can customer support be so unimportant to you?
Ralph
Hide Signatures
(in reply to Ralphbf)
       Post #: 232
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/4/2009 6:31 AM
nowires
Score: 118
Last Login: 4/12/2010
Status: offline
If you look on the prop., it's an 11 X 4.7.... My LHS had one but it was meant to secure with a nut on either side so I wasn't sure it would fit over the shaft correctly since the Sky Trainer doesn't use nuts to secure the prop. Instead, I got an 11 X 3.8 that had the identical prop shaft configuration. The LHS expert said since it had slightly less pitch, it will spin a bit faster but would work just fine. On further review, I think the 11 X 4.7 they had would work too.
So far, it's a great plane... I'm starting a post about the small probelms that were easily fixed with the model.
Hide Signatures
(in reply to Poweller)
       Post #: 233
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/5/2009 8:46 AM
dslusarc
Score: 100
Last Login: 9/12/2012
Status: offline
I have sent emails, done live chat, posted here, sent a PM, and even called for a replacement fuselage and canopy and I still can not get a price from anyone. Been waiting almost two weeks for a return call with the price
Hide Signatures
(in reply to nowires)
       Post #: 234
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/5/2009 10:38 PM
Ralphbf
Score: 100
Status: offline
So did you want low prices and customer service?
Good Luck.
Ralph
Hide Signatures
(in reply to dslusarc)
       Post #: 235
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/6/2009 4:03 AM
bfrank88
Score: 105
Last Login: 1/23/2010
Status: offline
I was told the replacement fuselages for the exceed j3 cub  and other parts would be in in 4-6 weeks. that was in september, what gives?
Hide Signatures
       Post #: 236
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/6/2009 8:09 PM
elec1066
Score: 100
Last Login: 6/3/2011
Status: offline
I just purchased a FMS skytrainer and it appears I have the newest nosewheel assembly, as its installation is not covered in the supplied manual, and it is a different setup than all the assembly video(s) show on you tube. There are serious problems with it - the shaft is too short and does not fit properly in bearing so it wobbles. The small set screw stripped during assembly as I rotated the nosewheel to see if it was secure.This is otherwise a top notch airplane, but this nosewheel assembly is terrible. Even if it is assembled using proper instructions I doubt  it would hold up any better than the previous design, and it may be worse. Do you plan to make some fix available? I don't want to risk flying this plane with this setup. Again, it appears otherwise to be an excellent aircraft and deserves a proper nosewheel assembly.
Tom M.
Hide Signatures
       Post #: 237
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/8/2009 10:00 PM
C Walls
Score: 100
Last Login: 1/21/2011
Status: offline
John,
I purchased  a FMS skytrainer and recieved it last Friday.  I found out the hard way how horrible the nose wheel is assembled. The nose wheel broke during its first landing breaking the cowl, nosewheel,  and snapping the plastic piece that the motor mount  is attached too. Motor and metal mount are fine.  Can't believe how well the rest of the plane held up. It seems  the complaints keep comming in and I'm just wonder if  there are any solutions in sight for this problem? Also, I wouldn't be asking if this wasn't such a big design flaw. Would you be willing to relace at least a newer front nosewheel assembly, cowl, proppeller, and spinner( Basically the front of the plane is gone)? Not sure if I can fix the motor mount support (plastic)  without replaceing the entire fuselage but I'll try.
Order #:  yhst-17210252890263-101877
Hide Signatures
(in reply to elec1066)
       Post #: 238
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/9/2009 7:56 AM
flyrcjets
Score: 100
Last Login: 5/13/2013
Status: offline
Where can I get a wing for a Z50?
Hide Signatures
(in reply to C Walls)
       Post #: 239
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/9/2009 4:37 PM
C Walls
Score: 100
Status: offline
John,
FMS SKYTRAINER
In regards to my last post, I fixed the mounting plate for the motor mount. I can pick up a proppeller and spinner at a local hobby shop. I will try to fix or rig up a nose wheel for now. It looks like all I need is a new cowl. Do you have any in stock?  What is the cost for the used fuselage you mentioned in another post?
Hide Signatures
(in reply to flyrcjets)
       Post #: 240
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/9/2009 10:23 PM
hshotty83
Score: 100
Last Login: 2/12/2010
Status: offline
My order number is yhst-17210252890263-98158. I am in desperate need of a j-3 piper cub fuselage before christmas, I have been checking your site on a daily basis and it always says it's sold out. Please tell me you have one or even a fuselage that will work I don't care if it's painted.
Hide Signatures
       Post #: 241
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/10/2009 4:48 AM
flyrcjets
Score: 100
Status: offline
Your desperate! I can't fly without a wing LOL! So Nitro ,Do you have a replacement wing for the Yellow/Black Mazda Z50?
Hide Signatures
(in reply to hshotty83)
       Post #: 242
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/10/2009 5:05 AM
fraustyone
Score: 100
Last Login: 12/11/2009
Status: offline
order # yhst-17210252890263-102882
Need price and availability on Manufacturers p/n
EXA001 (Fuselage)
EXA003 (Canopy & Cowl)
did a nose over on landing and busted cowl and bulkhead where motor mount is fastened. Would like to know if you can get these parts. Thanks!
Ryan
Hide Signatures
       Post #: 243
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/10/2009 10:34 AM
Ralphbf
Score: 100
Status: offline
The last time any help logged in was 11/26/2009 2:13 AM
Then he gave me the wrong part number.
Just buy another plane and use it for parts.
The frustration and grief is not worth the trouble.
Merry Christmas
Ralph
Hide Signatures
(in reply to fraustyone)
       Post #: 244
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/11/2009 6:11 AM
flyrcjets
Score: 100
Status: offline
Your right Ralph, I should just buy another plane but it wont be a NM, not when you cant get replacement parts that they tell you would be available in 4 weeks and that was 10 months ago.
Merry Christmas to all!
Hide Signatures
       Post #: 245
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/14/2009 6:48 AM
nomedmon
Score: 100
Last Login: 5/7/2012
Status: offline
hello i need to order a edf fan 5 blade for my fms 70mm f 16 what part # do i need or do i have to get a whole unit...the plastic guard in the top of the duct tried to leave through the fan on my 8th flight putting jet in tree not bad just stalled right in the branch good catch on the tree's part. thks
Hide Signatures
       Post #: 246
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/14/2009 11:00 PM
Bradock
Score: 100
Last Login: 5/1/2010
Status: offline
Sam: Thanks for being patient, how may I help you today?Bradd: thanks~ Bradd: yes I have a ventus arf 2600mm sailplane and also ordered the power pod. i need to order the ducted fan setup and the servo compliment. can you help?Sam: sorry you need to order onlineSam: or call inSam: i cannot take any ordersSam: on live chatSam: sorryBradd: I just need the specifications or recommendations....Bradd: I will order online.Bradd: I did try your number but one does not work and the other has always been busy.Bradd: are you still there??Bradd: Sam, are you still there?Bradd: we must still be connected - correct???Bradd: you are receiving my replies - correct???Bradd: I waited for over a half hour to chat with someone - and you reply that you cannot help with no support what a joke.Bradd: Thanks for your help (or lack there of).  As you can see - not much help. I need the specified components for the Sailplane Power Pod and servo compliment. CM Pro Ventus 2hx 2600mm ARF. Thanks for your support - Bradock
Hide Signatures
       Post #: 247
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/17/2009 2:29 AM
fnmvon
Score: 100
Last Login: 1/26/2013
Status: offline
Hi John, I was wondering if there is any possibility of ordering a new canopy and build manual for your nitro planes marchetii sf-260.
Frank
Hide Signatures
       Post #: 248
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/17/2009 4:52 AM
angelo1939
Score: 105
Last Login: 8/30/2012
Status: offline
Good luck....fnmvon...In november I posted that i needed a canopy and cowl for my Marchetti SF 260, so far no replies and they are still out of stock on the plane and parts at nitro planes.....angelo
Hide Signatures
(in reply to fnmvon)
       Post #: 249
RE: NITROMODELS REPLACEMENT PARTS REQUEST_Post Here - 12/17/2009 6:41 AM
TailSpin Walt
Score: 100
Status: offline
The motor mounts for my Nitorplane Super Low Wing Trainer 40 broke where the screws went thru them to mount the motor (not sure why!).
How can I get a new set of motor mounts for this plane?
Hide Signatures
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.734RCU1
