DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/23/2009 6:38 AM
nitrostaff1
Score: 110
Last Login: 3/7/2011
Status: offline
Continue from old thread.
John
Nitro Planes
< Message edited by opjose -- 7/23/2009 8:14 PM >
_____________________________
THE BEST LIPO BATTERIES
http://www.hobbypartz.com/lipobatteries.html
Hide Signatures
       Post #: 1
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/23/2009 8:19 PM
opjose
Score: 280
Last Login: 5/23/2013
Status: offline
To speed things up please do the following.
- Always provide your order number ( usually begins with YSTxxx ).
- Provide a link to the web page showing which product you purchased.
- Include a description of the missing or problematic item.
- If possible pictures help.
Caveats:
- Do not attempt to fly your plane / heli without static testing it FIRST. Even RTF's.
- EDF's should be tested through several charge/discharge cycles before flying.
- NiCD battery packs may need to be discharged and recharged several times before flying your craft.
- Even RTF's need to have their trims and linkages adjusted.
- Adjustments should be done by someone experienced with RC.
< Message edited by opjose -- 7/23/2009 8:20 PM >
Don''t worry, be happy and fly something!
Hide Signatures
(in reply to nitrostaff1)
       Post #: 2
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/24/2009 11:58 PM
kygah
Score: 100
Last Login: 10/5/2009
Status: offline
ORDER Number: yhst-17210252890263-87763
I received this order today and have some serious issues with the airplane.
#1 – Servo will not fit in wing. Hole is not cut out properly to receive the servo that was sent. Also, correct screws not sent to secure servo.
#2 – Servo opening in wing, the plywood support is broken.
#3 – Right aileron is detached from wing. Hinges are not glued in place, and control is very sloppy.
#4 – Left aileron is VERY stiff, and has limited control movement. This may be normal and acceptable. It is securely attached to wing.
#5 – Vertical stabilizer is out of alignment with the aircraft.Tilts to one side, and is not square with aircraft.
#6 – Rudder is not in alignment with the vertical stabilizer. I thought the vert stab might be tilted to counteract torque of engine (similar to down and out of engine), but the rudder is out of alignment nonetheless.
#7 – There is no way to secure the receiver and ESC. I can take care of this, but the instructions show it being included.
I would like to return the entire airplane. I am very disappointed with the entire aircraft.
I can post pictures if necessary. Please advise.
Respectfully,
Gregg
Hide Signatures
       Post #: 3
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/25/2009 1:27 AM
opjose
Score: 280
Status: offline
#1 - Enlarge the hole with a hobby knife
#2 - While it should not be this way, you can CA it to fix.
#3 - Affix with glue or tape. The included clevises do have a degree of slop, but this will not affect flight.
#4 - Bend back and forth a bit after disconnecting clevis to free it up a bit.
#5 - While this is not the way it should be, you can bend it back lightly... I sometimes use a heat gun on low settings for this.
#6 - Same as #5
#7 - That's pretty standard, use whatever means you want, tape, velcro, etc.
Hopefully John will contact you about a return.
None of the above is a big problem however.
Hide Signatures
(in reply to kygah)
       Post #: 4
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/25/2009 2:10 AM
kygah
Score: 100
Status: offline
No disrespect, but shouldn't an ARF be ARF? I don't consider these to be things that I should have to fix. If I wanted to purchase an airplane that I had to fix all of these items, I would have purchased a kit.
What would happen if I were to break a part, or be unable to fix it? What if I thought I fixed it, but it failed and the aircraft crashed? I think it would be pointless to return at that point.
Hide Signatures
(in reply to opjose)
       Post #: 5
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/25/2009 2:13 AM
theradioflyer
Score: 111
Last Login: 2/11/2012
Status: offline
Kygah,
Those issues are normal for most of the ARF's I've ever bought. The only ones I've never had to tweak a little in the build are 3Dhobby Shop planes.
Blessings,
Jay
I dig up so much dirt with the Prop, they call me the farmer.
Hide Signatures
(in reply to kygah)
       Post #: 6
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/25/2009 2:43 AM
kygah
Score: 100
Status: offline
So...Are you saying this is normal? I mean, I'm not expecting the moon, I know how much I spent. In the world of RC planes, I didn't spend much at all. Less than some good servos themselves used to cost.
I'm out of CA right now, besides, wouldn't CA eat through the foam?
Would I be better off to use some epoxy?
Hide Signatures
(in reply to theradioflyer)
       Post #: 7
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/25/2009 3:15 AM
kygah
Score: 100
Status: offline
I think I'm gonna give it a shot. I didn't mean to offend anyone. In fact, I posted a question earlier in the week, and was greatly very warmly. I think I just got my hopes up like the kids that didn't get the BB gun on Christmas morning....
Hide Signatures
(in reply to kygah)
       Post #: 8
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/25/2009 4:35 AM
theradioflyer
Score: 111
Status: offline
Kygah,
I don't think anything you said was offensive and you do expect certain amount of quality. It is normal though to find all of the things you mentioned in any ARF. What's not to be expected is damage of cowls, broken wood, or even a box that shows up at your door that looks as if it's been stepped on by an elephant, (not that it would be Nitroplanes fault for that ).
Use foam safe CA's on any foam and if you can check the glue on a scrap piece or where it is not seen or structural. If you use an accelerant be sure to check that it doesn't eat the foam as well. Just a little will tear through foam.
Blessings,
Jay
< Message edited by theradioflyer -- 7/25/2009 4:36 AM >
Hide Signatures
(in reply to kygah)
       Post #: 9
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/25/2009 7:22 PM
kygah
Score: 100
Status: offline
Well, crash and burn, so to speak. Taxing around, throttled up, tracking straight, nosed over, broke the entire front end off. I'm gluing it back on now. I think I need an entire new wing. The hinges, and control arms are simply not holding. I've reglued the hinges on one aileron, and the control arm on the other aileron broke through as I was working the ailerons. I've  got everything glued back up and drying. We'll see what happens this time...
Any recommendations on another RTF or ARF kit that I can put these electronics into? Even a glider or trainer...I don't want this to be a total loss. Right now, that's what it's looking like.
Thanks!
G
Hide Signatures
       Post #: 10
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/26/2009 6:26 PM
kygah
Score: 100
Status: offline
OK, everything glued up and dried. Battery charged. Double check all surfaces, almost same amout of throw on all surfaces. Taxi around, everything OK. Throttle up, going down the road, landing gear folds under the plane. Completly tore out from under it. Never lifted off or even bounced. I'm not on grass, I'm on pavement. I'm afraid to hand launch, since it doesn't seem like it even has the power to fly anyway.
Is this much trouble common on these foam planes? I saw a review on a different corsair, and the thing actually flew. Come to find out, I ordered the wrong plane, my fault. I just thought I was getting a different color, but it appears I got a completly different plane.
I would like a response from Nitroplane on this.
Did I get a lemon?
Am I the only one that has complained about this model? If so, I'll put on my big boy pants, and realize the fact I threw away $100.
Hide Signatures
(in reply to kygah)
       Post #: 11
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/27/2009 11:58 PM
trashslammer
Score: 100
Last Login: 2/15/2012
Status: offline
I have the 51.5" wingspan P-38 Lightning. This model comes with two covers, looking like "superchargers" for the engines, attaching where the wing attaches to the two main fuselage pieces. These two pieces need to be shaped to fit, as the wing becomes assembled to the airplane. They are the covers that cover the elevator servos, and the screws that hold down the wing. Well I butchered my two covers. Can I buy two more please? My email is : bjbc04@suddenlink.net
Thank you;
Brian
Hide Signatures
(in reply to kygah)
       Post #: 12
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/28/2009 7:49 AM
emtffkev
Score: 100
Last Login: 8/8/2009
Status: offline
I just recently received my new F-4E Phantom and everything is looking good aside from two items that apparently missed QC. The lesser of the two would be the coupling that attaches the nose gear to the post coming from the bottom of the plane, both screw holes are stripped. I can probably fix this pretty easily so I'm not too worried about that. The big issue is the small servo that controls the nose gear seems to be DOA. I've ruled out the receiver by attaching another servo to the same channel and it works fine. I took the servo out and tried testing it thinking it may have gotten hung up and it won't work by itself either.
Would it be possible to get a replacement servo for the nose gear, I have some spare servo's at the house, but all of them are much too big to fit in the tiny nose of this plane.
My order number is:
yhst-17210252890263-87439
Hide Signatures
(in reply to trashslammer)
       Post #: 13
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/30/2009 4:17 AM
nitrostaff1
Score: 110
Status: offline
ok RMA issued you can send it back for refund.
John
Nitro Planes
quote:
ORIGINAL: kygah
Respectfully,
Gregg
Hide Signatures
(in reply to kygah)
       Post #: 14
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/30/2009 4:19 AM
nitrostaff1
Score: 110
Status: offline
Don't worry about it just give it a shot.
John
Nitro Planes
quote:
ORIGINAL: kygah
Hide Signatures
(in reply to kygah)
       Post #: 15
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/30/2009 4:23 AM
nitrostaff1
Score: 110
Status: offline
Please see here: http://www.nitroplanes.com/plinigasrare.html
the 2 piece you need is in black color right? one of each side of the fuselarge.
Let me know
John
Nitro Planes
quote:
ORIGINAL: trashslammer
I have the 51.5'' wingspan P-38 Lightning. This model comes with two covers, looking like ''superchargers'' for the engines, attaching where the wing attaches to the two main fuselage pieces. These two pieces need to be shaped to fit, as the wing becomes assembled to the airplane. They are the covers that cover the elevator servos, and the screws that hold down the wing. Well I butchered my two covers. Can I buy two more please? My email is : bjbc04@suddenlink.net
Thank you;
Brian
Hide Signatures
       Post #: 16
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/30/2009 4:24 AM
nitrostaff1
Score: 110
Status: offline
I've send you a servo and replacement landing gear set.
John
Nitro Planes
quote:
ORIGINAL: emtffkev
My order number is:
Hide Signatures
(in reply to emtffkev)
       Post #: 17
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/30/2009 4:38 AM
kygah
Score: 100
Status: offline
Thank you very much, John.
Is this a different plane altogether?
http://www.nitroplanes.com/4chwaf4ucort.html
Should I expect this one to be better or same?
Thank you again,
Gregg
Hide Signatures
       Post #: 18
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/30/2009 4:39 AM
nitrostaff1
Score: 110
Status: offline
I would say this one is better than the guan li one. If you want I can exchange to this one for you.
John
Nitro Planes
quote:
ORIGINAL: kygah
Thank you again,
Gregg
Hide Signatures
(in reply to kygah)
       Post #: 19
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/30/2009 4:51 AM
kygah
Score: 100
Status: offline
That sounds good to me. Thank you for taking care of this. I'll get this one boxed up and on the way back to you tomorrow.
Respectfully,
Gregg
Hide Signatures
       Post #: 20
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 7/30/2009 4:51 PM
kygah
Score: 100
Status: offline
John,
If it's all the same to you, I'm going to just go ahead and place another order, and let you refund me rather than waiting for the extra shipping/processing time.
Thanks!
Gregg
Hide Signatures
       Post #: 21
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 8/1/2009 12:42 AM
klew0222
Score: 100
Last Login: 1/21/2011
Status: offline
quote:
ORIGINAL: nitrostaff1
John
Nitro Planes
I received my Thunder AC6 charger from Nitroplanes today and found that the unit will not power up with the AC cord. It will however power up from a 12 volt source. Is there anything I can try to correct this problem short of returning the unit?
klew0222
Hide Signatures
       Post #: 22
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 8/1/2009 1:34 AM
opjose
Score: 280
Status: offline
I don't have that charger, but by any chance is there a fuse for the AC line?
If so have you checked it?
Hide Signatures
(in reply to klew0222)
       Post #: 23
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 8/1/2009 5:03 AM
klew0222
Score: 100
Status: offline
Nothing visable and I hesitate in going into the case without knowing for sure. Doing so may preclude returning it to Nitroplanes as a last resort.
Hide Signatures
       Post #: 24
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here - 8/1/2009 6:09 PM
tremorsfsu
Score: 100
Last Login: 10/8/2009
Status: offline
I am not sure if this is the right place for this post.  I just want to alert anyone that buys a F4 70mm from C&G Hobby to check the back stabilizer piece.  It is a separate piece from the fuselage and I would hate for you to crash your brand new beautiful jet because of it separating in the air.
I am still awaiting to hear if I can get any kind of credit on another model because of this.  I've epoxied the pieces of the plane back together but it just doesn't fly right or the same way it did when it was right out of the box.  Also, the left aileron servo doesn't move smoothly like it did...it is very jerky and hits several "ticking" points when turning instead of moving along smoothly.
This is my original email that I sent in support and am still awaiting an answer from Norman:
"I ordered the 70mm EDF F-4 Phantom on 6.30.09 and received it on 7.6.09. I've flown it just a few times and love the way it handles and flies but I ran into a problem with my last flight today. On the last vertical attempt the back stabilizer that holds the rudder and stabilizer ripped off the plane in mid-flight. The rest of the plane came crashing to the ground and broke into quite a few pieces. I noticed that there wasn’t a lot of glue holding the back stabilizer piece to the fuselage of the airplane. I wanted to let you know what happened to me and hopefully this won’t happen to other people that purchase the plane. Please let me know what my options are as the crash was not due to my flying but the factory not putting enough glue on it.
Best Regards,
Anthony"
I received a response:
"Dear Customer,
Sorry, warranty voids after there is a crash.
This email is regarding NitroPlane order number yhst-17210252890263-85465.
Best Regards,
NitroPlane"
I understand that and I did check it before flying and all appeared to be fine on the ground.  Then this is my last response which I am waiting to hear back on:
"Good morning. I understand that after a crash the warranty gets void. I
just know that I've flown many airplanes and have never had this happen to
any of them. I just wish I would have checked that part of the plane on the
ground instead of that causing a crash. So really there is nothing that you
can do because of manufacturers defect - maybe even a discount if I purchase
the same plane as a kit and transfer the existing electronics to it?
It is good for you to know for future customers too...maybe mention that
they should ensure that the back stabilizer piece is glued on securely or
they should consider removing it and re-gluing.
Also, can you get spare parts for this plane? If not will they be available
in the future?
Best Regards,
Anthony
My last communication was this:
"Dear Customer,
Thank you for contacting us. Please contact us at anytime.
Regards,
NitroModels Inc. "Where high quality models are made affordable"
I've tried calling in several times and they keep telling me I need to talk to Norman or the floor manager who is never available.  I just feel this wasn't completely my fault because I did check over the plane before my flights and hope to get some type of discount or compensation on a new plane.
Thanks!
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
