1700SP Upgraded to Gaspar ECU    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> SimJet Turbine Direct Support >> 1700SP Upgraded to Gaspar ECU
Page: [1]
Login
1700SP Upgraded to Gaspar ECU - 7/24/2009 9:02 AM
jephry
Score: 100
Last Login: 5/6/2013
Status: offline
Hi there,
I have just completed upgrading the ECU, is there anything i should set in the ECU?
What is the Max RPM?
_____________________________
Just want to Fly!
www.rc-ms.com
Hide Signatures
       Post #: 1
RE: 1700SP Upgraded to Gaspar ECU - 7/24/2009 3:17 PM
Vampire
Score: 100
Last Login: 5/24/2013
Status: offline
The "SIMJET" values are as follows:
Full Power Speed: 120,000
Idle Speed: 30,000
Start Min. Temp 100C
Max Temp : 900C
Accel delay: 40
Decel Dealy: 15
Stability Delay 050
Pump Limit: 1000
Pump start point: Auto+2
Pump Start Ramp: 006
Glow Plug Power: 35
Satrt Gas: 100%
Low Batt. Volts: 6.2vdc
Throttle Curve: FULL Expo
For all other values: us GASPAR defaults.
Kerry J. Sterner
scaledesigner@verizon.net
Hide Signatures
(in reply to jephry)
       Post #: 2
RE: 1700SP Upgraded to Gaspar ECU - 7/24/2009 4:43 PM
jephry
Score: 100
Status: offline
Hi Vampire,
Many thanks for the info.
SJ Denmark also advise me on:
Auto+3
Fuel Ramp to 004
Just want to Fly!
www.rc-ms.com
Hide Signatures
(in reply to Vampire)
       Post #: 3
RE: 1700SP Upgraded to Gaspar ECU - 8/17/2011 12:44 PM
The Flying Scot
Score: 100
Status: offline
Hi Vampire,
I am thinking about using the Gasper ecu with my simjet 2300.
Do you see any problems with this? is it possible to use the existing RPM sensor? if not can the Gasper sensor be used to pick up the existing magnets?
Best regards
Arthur
Hide Signatures
       Post #: 4
RE: 1700SP Upgraded to Gaspar ECU - 8/23/2011 6:00 PM
Vampire
Score: 100
Status: offline
Hello Arthur,
No problem using the GASPAR ECU (605 or V.10)but the old SJ-RPM board will not work. You must use the GASPAR (IXCOY) RPM board.
Best Regards,
Kerry J. Sterner
Hide Signatures
(in reply to The Flying Scot)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
