12 FG Delta programming    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Futaba Radios Direct support forum >> 12 FG Delta programming
Page: [1]
Login
12 FG Delta programming - 7/27/2009 6:57 PM
Hajo77
Score: 100
Last Login: 2/13/2013
Status: offline
Hi!
I checked the search function, but got no result on it. My problem is as follows: I am trying to programm a Eurofighter model with 2 Servos working as Aileron and Elevator. I chose the Glider programm with Ailvator for those flying surfaces - now, I cannot get the aileron trim to work. The trimming for the Elevator function works properly though.
Can anyone help me out? Flying is really difficult with no Ail trimming
Hide Signatures
       Post #: 1
RE: 12 FG Delta programming - 7/28/2009 6:46 PM
Bax
Score: 169
Last Login: 5/23/2013
Status: offline
Normally, you'd use one of the "Flying Wing" setups. That will combine elevators and ailerons properly, trims and all. Ailevator is intended to use 2 elevator servos in 3D-types of models, where some aileron action is desired. Aileron trim doesn't affect the ailevator function.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to Hajo77)
       Post #: 2
RE: 12 FG Delta programming - 7/29/2009 12:19 PM
lesterpk
Score: 100
Last Login: 10/8/2012
Status: offline
Bax, having just done this with a slope model, I found that by far using ailevater was the easiest way to set the throws for each surface, but like above the ail trim doesnt work. I simply used a Pmix with T1 as the master, one of the aileron channels as a slave, turned on the link and gave it a small mix percentage. Works perfectly fine and I have full and easy control over throws.
Hide Signatures
(in reply to Bax)
       Post #: 3
RE: 12 FG Delta programming - 7/29/2009 6:26 PM
Bax
Score: 169
Status: offline
And that's another way to do it. There are quite a number of ways to do the same thing in the 12FG, 12Z and 14MZ transmitters...they are that versatile!
Hide Signatures
(in reply to lesterpk)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
