Vibration Problem with Skylark
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Vibration Problem with Skylark
Page: [1]
Login
Vibration Problem with Skylark - 6/25/2003 11:53:05 PM
acp63
Status: offline
Does any one no why the Model vibrates so much are the rotors out of balance and if so How do you balance them?
There tech support said it is caused by the motor but I do not belive that maybe i am wrong.
Is there a web site with tech tips on flying or seting these small copters up?
       Post #: 1
Vibration Problem with Skylark - 6/26/2003 12:01:29 AM
exspluu
Status: offline
I had the same problem, found some help here http://www.helihobby.com/html/balancing_blades.html
Also I have noticed that as the RPM's increase on the Mains that the vibration dissapears.
Also try this, as a quick way to adjust the rotors (I found this out by looking at the old posts here).
Grab the tips of the main rotors with your index and thumb and gently pull both blades apart. This should straighten the rotors out. Also make sure that you have the rotors installed tightly enough that when you hold the heli on end the blades do not droop and stay put, but at the same time do not over tighten the mounting screws to the point the rotors can't move(this is not a good condition when you have a minor rotor strike).
Hope this helps.
(in reply to acp63)
       Post #: 2
Vibration Problem with Skylark - 6/26/2003 1:12:29 AM
jeffs555
Status: offline
Are you using the training gear? I had, and have seen others report problems with the training gear resonating and amplifying even the slightest vibration. As soon as I took the training gear off, the vibration went away.
(in reply to acp63)
       Post #: 3
Vibration Problem with Skylark - 6/26/2003 1:17:01 AM
jeffs555
Status: offline
Here is a good site. Look under the "hints and tips" section.
http://www.pgoelz.com/piccolo1.html
And here is a good one on learning to fly a heli.
http://www.dream-models.com/h/flying-index.html
< Message edited by jeffs555 -- Jun 25 2003 8:30PM >
(in reply to acp63)
       Post #: 4
Jeff - 6/26/2003 1:33:43 AM
acp63
Status: offline
I do not have traing gear on I just put it together and held it in my hand and the landing gear and the tail boom were shaking quit violently
(in reply to acp63)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
