Seagull Extra 260 1.80 Gas Engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ParkZone F-27Q Stryker - RTF
Seller:  nrthwing
Details:   $150.00   |  6/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> Seagull Extra 260 1.80 Gas Engine
Page: [1] 2   next >   >>
Login
Seagull Extra 260 1.80 Gas Engine - 7/31/2009 11:10 PM  1 votes
Gray Goose
Score: 105
Last Login: 6/8/2013
Status: offline
I have been following the strings abut still have no difinitive answer for the best 3D hover gas Motor for this plane. I want to purchase one but the Motor/ 3d Performance mystery still looms. Leaning toward the MLD 28, thought the Evolution 26-GX would be good but I read the MLD would be better. Lets Go Guys and settle this.
Hide Signatures
       Post #: 1
RE: Seagull Extra 260 1.80 Gas Engine - 7/31/2009 11:18 PM
helodrvr
Score: 100
Last Login: 1/28/2013
Status: offline
Have you looked at this thread.
http://www.rcuniverse.com/forum/m_7371745/mpage_1/key_/tm.htm
Hide Signatures
(in reply to Gray Goose)
       Post #: 2
RE: Seagull Extra 260 1.80 Gas Engine - 8/1/2009 12:00 AM
Gray Goose
Score: 105
Status: offline
Yes, Still no definite mention of the best 3D combo. I will guess its piolets choice. I just want to hang on the prop like my 3d Eratics
Hide Signatures
(in reply to helodrvr)
       Post #: 3
RE: Seagull Extra 260 1.80 Gas Engine - 8/1/2009 5:42 AM
helodrvr
Score: 100
Status: offline
I'm about to build one with a pumped O.S. 1.60. I'll let you know how it works.
Hide Signatures
       Post #: 4
RE: Seagull Extra 260 1.80 Gas Engine - 8/1/2009 6:29 PM
Walt and Sage
Score: 100
Last Login: 11/28/2010
Status: offline
The new DLE 30cc will be out shortly... 2.3 lbs just under 4HP
Performance:
3.7HP/8500rpm
Idle Speed: 1600rpm/min.
8.5KG Pulling Force/ 100 meters Altitude ( All Most 19Lbs)
7.5KG Pulling Force/1800 meters Altitude
Propeller: 18X8 18X10 20X8
Type of sparkplug: NGK CM6
Exhaust Amount: 30.5cm3
Diameterx stroke:36mm*30mm
Ratio of compression: 7.6:1
Ratio of lubricating capacity: 32:1
Weight: Main engine-910g. Exhaust Pipe-60g
Ignition 120g ( TOTAL 2.3lbs)
Valley View R/C will have them shortly... Walt
_____________________________
A Man''s Character is his Destiny.........
........AMA 38255 "PRO BRO 2344"
Hide Signatures
       Post #: 5
RE: Seagull Extra 260 1.80 Gas Engine - 8/1/2009 8:28 PM
Gray Goose
Score: 105
Status: offline
Walt/Sage,
Thanks for the info. Do you think this will be a good 3D fit for the Seagull Extra 260..1.80 version. Specks seem awsome, I know very little about this motor is it as good in quality as the MDL.
Hide Signatures
(in reply to Walt and Sage)
       Post #: 6
RE: Seagull Extra 260 1.80 Gas Engine - 8/2/2009 6:04 PM
Walt and Sage
Score: 100
Status: offline
Hi Goose,
If your plane is 25% , the motor was designed for that..
If it has the same quality as the DL50, 55. 100 and the 111 you will be pleased....
Hide Signatures
       Post #: 7
RE: Seagull Extra 260 1.80 Gas Engine - 8/2/2009 6:05 PM
mrbigg
Score: 155
Last Login: 6/19/2013
Status: offline
SYSSA 1.80 HP would be my choice.
Smooth, like Keith Stone.
Hide Signatures
       Post #: 8
RE: Seagull Extra 260 1.80 Gas Engine - 8/3/2009 4:39 AM
bjor
Score: 100
Last Login: 12/17/2012
Status: offline
I cannot comment on the MLD 28 or 26 GX but I had this plane with an SPE 40 and it I thought the 40 was a great combo. I friend of mine has a DZY 26 in his Seagull Extra 1.80 which flys it just O/K - but definatly NOT 3D stuff. Given a choice - I would upsize to a 40 and be done with it.
If you have to bend over more than once to pick it up - it was a bad landing
Hide Signatures
       Post #: 9
RE: Seagull Extra 260 1.80 Gas Engine - 8/4/2009 7:47 AM
Gray Goose
Score: 105
Status: offline
Purchased the DLE-30 today think the weight to hp ratio will do the job
Hide Signatures
(in reply to bjor)
       Post #: 10
RE: Seagull Extra 260 1.80 Gas Engine - 8/5/2009 5:49 AM
SRimer
Score: 100
Last Login: 6/16/2013
Status: offline
I'm currently working on one, i plane on putting crrc 40cc,
my friend is flying his with RCS 26cc, it has sport performance, it fly great.
Hide Signatures
       Post #: 11
RE: Seagull Extra 260 1.80 Gas Engine - 8/5/2009 6:29 AM
helodrvr
Score: 100
Status: offline
SRimer,
Lets us know how that CRRC 40 works out. Might do that instead of an OS 1.60. If you could, post some pics of the motor and cowl after install.
Hide Signatures
(in reply to SRimer)
       Post #: 12
RE: Seagull Extra 260 1.80 Gas Engine - 8/12/2009 8:03 PM
helodrvr
Score: 100
Status: offline
SRimer,
How is that CRRC 40cc install going???
Hide Signatures
       Post #: 13
RE: Seagull Extra 260 1.80 Gas Engine - 8/27/2009 4:12 AM
sjwilliams8604
Score: 100
Last Login: 12/21/2012
Status: offline
Hi,
I was interested in buying the seagull extra 260 180 size, and wanted to put a gasoline engine in also.. I have a few quetions if you dont mind. I see you said you bought the new dle30. I looked up the  instructions for the plane but they did not give any info for a gasoline engine. Could you tell me exactly how you did this. was it off center, did the firewall already have right thrust etc. also how is the preformance with the dle30. Thanks for your time!
Hide Signatures
       Post #: 14
RE: Seagull Extra 260 1.80 Gas Engine - 8/27/2009 9:16 PM
helodrvr
Score: 100
Status: offline
< Message edited by helodrvr -- 8/28/2009 6:15 AM >
Hide Signatures
(in reply to sjwilliams8604)
       Post #: 15
RE: Seagull Extra 260 1.80 Gas Engine - 10/18/2009 7:54 AM
Brett72
Score: 100
Last Login: 6/15/2013
Status: offline
How has the DLE 30 worked for this plane? What prop are you using? Thanks
Hide Signatures
       Post #: 16
RE: Seagull Extra 260 1.80 Gas Engine - 10/24/2009 2:49 PM
3DDino
Score: 100
Last Login: 3/24/2012
Status: offline
YA, I like to know too
Hide Signatures
(in reply to Brett72)
       Post #: 17
RE: Seagull Extra 260 1.80 Gas Engine - 10/25/2009 7:39 AM
nitro wing
Score: 125
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: helodrvr
SRimer,
besides fuel cost the OS 160 will outperform this 40 anyday. Its lighter and just flies better. there are some good torque imrovements on the gasser, down low. If you like to hover and give up other character,buy the gasser. Overall the OS is the winner INMO.
Hide Signatures
       Post #: 18
RE: Seagull Extra 260 1.80 Gas Engine - 11/16/2009 4:56 AM
Brett72
Score: 100
Status: offline
How has the crrc 40 worked on this plane? Any pictures?
Hide Signatures
       Post #: 19
RE: Seagull Extra 260 1.80 Gas Engine - 11/23/2009 6:51 PM
3DDino
Score: 100
Status: offline
ya how was everything
Hide Signatures
       Post #: 20
RE: Seagull Extra 260 1.80 Gas Engine - 12/6/2009 4:08 AM
dschroeder
Score: 105
Last Login: 6/17/2013
Status: offline
have you considered one of the supertigre gas conversions? i have a ST3000 that was converted to gas (electronic ignition) that i will be putting in mine. weighs the same as the glow engine basically, and with the smaller fuel tank it evens out the weight of carrying the ignition battery.
Ultra Sport brother #44
Hide Signatures
(in reply to 3DDino)
       Post #: 21
RE: Seagull Extra 260 1.80 Gas Engine - 5/5/2010 5:02 AM
boombaby
Score: 100
Last Login: 6/10/2013
Status: offline
hi guys just put one together, i have a brand spanking new st 3000 just in the process of running it in, (10% dynaglo and a graupner g-sonic 20-10 prop, its showing promis at 6200 rpm which is in my opinion just right for the prop etc) this is not a gas convertion and it rand for ages on just one tank which surprised me as i would of though it would be like my moki 2.10 and drink fule like it was going to die tomorrow lol but it lasted a good 20 mins on a 600 cc tank were as the moki would drink that in 10,
 however for 3d performance i reckon this is the crown jewl, im not the biggest fan of st but it sure as hell would take off vertical and from the point of veiw this is the first time its had fule through it i was impressed and still thinking it can only get better with some more runs.
i do however need to no if anyone had problems with tail servo instalation and weather anyone has hovered this so i can get an idea of how she behaves on an average basis =]
holla back peeps
Hide Signatures
(in reply to dschroeder)
       Post #: 22
RE: Seagull Extra 260 1.80 Gas Engine - 5/5/2010 7:29 PM
skysfallin
Score: 135
Last Login: 5/20/2013
Status: offline
I have this plane with an OS160 and power is not an issue, it does very well. Will hover all day and pull out whenever you want. If I was to do it again I would try the DLE 30 just to see the difference. I am very impressed with the DLE engine. I have a DLE55 in my Aeroworks YAK and it will yank that plane all over the sky.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to boombaby)
       Post #: 23
RE: Seagull Extra 260 1.80 Gas Engine - 9/29/2010 4:30 PM
warhawk demon
Score: 105
Last Login: 4/25/2013
Status: offline
i have the same problem!!!!!!!!  i think im going with the DLE 30 it is the exact same weight as the evalution 26 i have.
Hide Signatures
       Post #: 24
RE: Seagull Extra 260 1.80 Gas Engine - 2/16/2012 3:06 PM
escapade60
Score: 100
Last Login: 5/9/2013
Status: offline
I just recentley got a seagull extra 260 180 size and am putting a DLE 30 on it. I was wondering how you measure where to put the stand offs on the firewall. I bought a drill jig for the stand offs but I don't know how far to offset the stand offs to acheive some right thrust. On my great planes cap 232 there are lines to show you where to mount it at. I've looked at the manual and there is nothing in the manual that says where to mount it at. Any help would be greatly appreciated
Hide Signatures
(in reply to warhawk demon)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
