Montague
banktoturn, Hmm, ok, you have a point about induced vs other forms of drag. And, in particular, I totally agree when you said this: quote:
In particular, you cannot assume that any wingtip that discourages the spilling of air around the wingtip is reducing induced drag. I was, in fact, making that exact leap, and I see it could be bogus. (I don't have any info to say one way or the other) However, a rounded wingtip may or may not be "high drag", but it is inefficient when it comes to generating lift. The air flowing around the wingtip will move the vortex on to the top surface of the wing, which reduces the "effective wingspan". This causes the wing to have to operate at a higher AOA, which will create more drag. I have no clue if it's signifigantly more though. I do know that the higher AOA moves you that much closer to stall, so changing wing tip shape can improve the stall charastics of a wing in a big way. I wish I could quote the source, but someone did, in fact, do a bunch of wind tunnel tests with differnet wingtip shapes to look at the tip vortex, and the results are really interesting. That vortex can really get around . If I recall, one of the better wingtip shapes from just a vortex standpoint was the "last rib" squared off tip. In that case, the vortex formed off the end of the wing instead of on the top surface. So, I was mixing up things. Speaking in terms over overall drag, I can't say what is best. Speaking in terms of overall performance, especially acrobatics and high AOA (non-stalled), I think the round wingtip can really hurt.
_____________________________
Kirk Montague Adams RCCA 560
