battery plug failing on 4#3B
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> battery plug failing on 4#3B Page: [1]
Login
battery plug failing on 4#3B - 8/7/2009 2:42 PM
cenracer1
Score: 105
Last Login: 3/12/2010
Status: offline
I recently had two battery plug failures on my 4#3B batteries in the last 2 weeks... The wires on the plug end of the battery come loose from the plug.. Yesterdays incident happened while flying outside doing piro's at about 15 feet... The heli twitched a bit then fell out of the sky... luckily I was flying over grass and the only damage was to the tail.. I have a carbon stabilizer wing which broke off... other than that all is fine... The other instance was when the other battery was in my pocket.. I pulled it out and the end was off.. I hate to think what would have happened if the ends touched... I've had these batteries for about 6 months now and am hesitant to fly with the remaining 3 "good" ones... The batteries still work fine and I will install deans micro plugs on them now... at least I know the my solder skills are good... Anybody else have issues with these batteries or plugs?????? I am very careful not ot yank on the wires when charging or flying trying to disconnect the plugs...
_____________________________
If it has wheels... I''ll make it fly
Hide Signatures
       Post #: 1
RE: battery plug failing on 4#3B - 8/7/2009 3:37 PM
AtTheCross
Score: 100
Last Login: 3/10/2010
Status: offline
have you trimmed off the nubs on the sides of the connectors? also, changing to micro deans is a major plus
Hide Signatures
(in reply to cenracer1)
       Post #: 2
RE: battery plug failing on 4#3B - 8/7/2009 4:47 PM
cenracer1
Score: 105
Status: offline
No I haven't trimmed off the Nubs and wasn't planning to do so.... I would rather they were tight than loose... I will order a bunch of micro deans tonight... any good source for them that you know of?
Hide Signatures
(in reply to AtTheCross)
       Post #: 3
RE: battery plug failing on 4#3B - 8/7/2009 5:35 PM
AtTheCross
Score: 100
Status: offline
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2043
http://wowhobbies.com/microdeanspolarisedconnectors-2pcsonepair.aspx
once it's connected then you're good, i think you're degrading the connection buy having to pull so hard because of the nubs.
Hide Signatures
       Post #: 4
RE: battery plug failing on 4#3B - 8/7/2009 6:30 PM
cenracer1
Score: 105
Status: offline
thanks for the link... I will try wow hobbies.. at least they are in the USA.. I've ordered from HobbyKing before and like them but the shipping is expensive if you want something quickly...
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
