RCFreakInFL
Joined: 6/10/2003 From: Orlando, FL, USA Status: offline
This is my pride and joy: TMAXX 2.5, 1 1/2 mos old Aluminum lower suspension arms Velocity 6 40 series w/Pro Line Big Joe 40's! Alum front and rear bumpers w/alum mounts Blue aluminum chassis braces Blue aluminum tranny cover Blue aluminum servo protector Airtronics 94357 steering servo (120oz torque, .07sec speed)! Pro-Line blue alum anodized servo saver Robinson Racing hardened steel 72 tooth spur w/blue alum disc plates (ball bearing, very nice!) Robinson steel tranny gears Custom aftermarket air filter (larger air flow, and removable element for cleaning) 2.5 pull start (junked the EZ START after gears crapped out!). Atomic painted "water camo" body! I still have my upper alum arms coming in the mail, as well as my blue alum front+rear RPM skid plates. I also just got today, my aluminum front+rear stabalizer bars, to prevent rollovers during turning at high speeds (which hardly happens). This truck is WICKED FAST! I have played with the shocks on it, and got the perfect oil/piston combo on it, and this thing rides great! Not bad for only a month and a half old truck.....with about 1/2 gallon through the motor.....just got broken in!
