RE: 4 stroke diesels
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> RE: 4 stroke diesels Page: <<   < prev  1 [2] 3 4 5 6 7 8   next >   >>
Login
RE: 4 stroke diesels - 2/10/2004 11:33:05 PM
ajcoholic
Status: offline
Those pictures are much better at explaining... THANKS!
AJC
_____________________________
Andrew J. Coholic
Engine reviewer for FLY RC Magazine - andrewc@flyrc.com
(in reply to Motorboy)
       Post #: 26
RE: 4 stroke diesels - 2/10/2004 11:38:42 PM
Motorboy
Status: offline
Thanks!! I has taken these photos today in evening (Norwegian time).
Jens Eirik
(in reply to ajcoholic)
       Post #: 27
RE: 4 stroke diesels - 2/11/2004 1:19:53 AM
AMB
Status: offline
Bottom line Jens (IT WORKS)(YOURS) ....Looking at the drawings of the german diesel (2 Strk)
the same set up would work on 4 stroke if you could run the pump off the cam ( making a
new one and a housing would be a challenge or a 1 to 2 gear off the shaft to a second cam just my thoughts
you guys are the machinists and the crankcase would hold lube oil??
I am intriqued by the injector mini pintle and spray nozzle??I wonder if any of these engines still exist
model museum maybe ,looks like you and AJ are setting some new standards in the engine
game martin
       Post #: 28
RE: 4 stroke diesels - 2/23/2004 10:39:55 PM
Motorboy
Status: offline
Hi all folks, i has runned in my Magnum 52 4 stroke and leaned fuel, it ran nice and fast enough. Drink not much fuel. Has not tachometer to measure rpm. I used 12x6 propeller. Vibration are not much difference from methanol powered 4 stroke engines. After i had runned engine i checked inside of cylinderhead. there are complete combustion and much soot inside. More better photos of metalwork and after running in engine. Between cylinderhead and piston are at 1 mm, calculated from compresion ratio + extra volume from "energy cell" with contra piston. Compresion ratio are between 18:1-25:1.
Jens Eirik
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 29
RE: Diesel 4 strokes - 2/29/2004 4:17:01 AM
joe78586
Status: offline
WOW 4 stroke diesel!
How doese it sound(how about a video of it). And can you post some close up picks of the contrapistoncylinder?
       Post #: 30
RE: Diesel 4 strokes - 2/29/2004 9:40:56 AM
fiery
Status: offline
This is so cool.
Jens
I have an OS 52 sitting in it's box after hundred's of flights because I am bored with it and have moved on to 1/4 scale aircraft. I would LOVE to do a conversion.
You have a business opportunity here if you have the time. Any chance of offering a conversion service?
< Message edited by fiery -- 3/1/2004 8:08:03 AM >
(in reply to joe78586)
       Post #: 31
RE: Diesel 4 strokes - 2/29/2004 2:07:00 PM
AMB
Status: offline
Not a bad idea have a brand new mag 52 sitting on the shelf that would
love to "go under the knife" (transplant surgery to diesel)
< Message edited by dieseldan -- 2/29/2004 9:07:44 AM >
(in reply to fiery)
       Post #: 32
RE: Diesel 4 strokes - 3/2/2004 7:36:28 PM
Motorboy
Status: offline
To Joe78586, sorry, i has not video of it with sound ..
Here are near photo of contra piston and "energy cell".
I has maked a better design of "energy cell" than early with 2 screws as shown in other photos of Magnum 52.
Jens Eirik
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 33
RE: Diesel 4 strokes - 3/2/2004 10:50:29 PM
joe78586
Status: offline
OK I think a don't have the proper tools to make one.
How much would you charge me to make me one for an OS .26S-C car engine? It should be the same since all engine sizes use the same glowplugs right.
thanks for the pics
       Post #: 34
RE: Diesel 4 strokes - 3/3/2004 5:46:02 AM
Motorboy
Status: offline
Impossible, you must replace whole cylinderhead to increase compresion ratio with a cylinderhead maked for dieselfuel, it has contra piston inside.
My 4 stroke engine cylinder head has smaller volume after i removed material with lathe and mounted "energy cell" in cylinder head.
Jens Eirik
       Post #: 35
RE: RE: Diesel 4 strokes - 3/3/2004 1:07:50 PM
Hobbsy
Status: offline
Moto, I think the OS .26 Joe refers to is a fourstroke.
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
       Post #: 36
RE: RE: Diesel 4 strokes - 3/3/2004 2:08:53 PM
joe78586
Status: offline
Yes the .26 I am referring to is a four stroke. And I can remove the head gasket and if needed I can shave the sleeve to get more compression.
This is the engine
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPT58&P=0
(in reply to Hobbsy)
       Post #: 37
RE: RE: Diesel 4 strokes - 3/3/2004 4:59:50 PM
Hobbsy
Status: offline
Joe, when I tried to run Diesel fuel in my Saito .80 as is, it had far too much compression and I couldn't run it more than half throttle. In fact at half throttle it was making dangerous noises.
       Post #: 38
RE: RE: Diesel 4 strokes - 3/3/2004 8:23:36 PM
Motorboy
Status: offline
quote:
ORIGINAL: joe78586
This is the engine
Hi, first i thinked it was a 2 stroke carengine , yes..it is possible to convert your engine to dieselengine. You must remove material from cylinderhead and a part of crankcase for sleeve. It shall be about 20:1-22:1 compression ratio + volume of "energy cell", it shall be variable between 16:1-20:1 with contrapiston from low to max. It is not enough remove head casket to increase compresion. But you must have head casket to seal better..
Since your engine are a car engine, maybe you must add a bigger flywheel to run better in idle..
Cause too high compresion where it detonates very hard in engine, better you mount the "energy cell" as shown in photo and reduce compresion. Have you measured compresion ratio at your Saito?
Jens Eirik
< Message edited by Motorboy -- 3/3/2004 3:25:35 PM >
       Post #: 39
RE: RE: Diesel 4 strokes - 3/3/2004 10:36:09 PM
Hobbsy
Status: offline
It is 14.4 to 1
