Motorboy
Joined: 2/7/2004 From: Bergen, NORWAY Status: offline
quote:
ORIGINAL: hobbsy To run standard model Diesel fuel you need lower compression not higher, I tried it in my Saito .80 and the compression is too high, it will start stone cold and run at idle and slighty above. Beyond that it begins to sound way overcompressed. I calculated and removed material in the cylinder head and crankcase and come up to about 20:1 compression ratio, then i maked the combustion cell/lanova and i regulate compression ratio between 14:1 and 19:1 with contrapiston in combustion cell/lanova. Works very well.. quote:
A longer rod is not feasable anyway because most fourstroke pistons come to the very top of the cylinder. It is not possible, because the cylinder head has to big combustion camber and less compression ratio. Therefore i removed the material in cylinder head. Jens Eirik
_____________________________
Jens Eirik All landings are just controlled crashes!
