Filling balsa?
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Filling balsa?
Page: [1] 2   next >   >>
Login
Filling balsa? - 8/14/2009 4:58 PM
DJokr
Score: 100
Last Login: 2/8/2010
Status: offline
What's the best way to fill dents in balsa?
Hide Signatures
       Post #: 1
RE: Filling balsa? - 8/14/2009 5:24 PM
Trax540
Score: 100
Last Login: 3/17/2010
Status: offline
I always use Modeling magic balsa filler,
although ive heard of alot of people using different household puttys and spackles. Also automotive fillers for various jobs.
Hide Signatures
(in reply to DJokr)
       Post #: 2
RE: Filling balsa? - 8/14/2009 6:04 PM
big max 1935
Score: 100
Last Login: 3/16/2010
Status: offline
If it is just dents try to get most of them out first. Lay a real wet rag or paper towel on them for a hour or so & then take your covering iron on high & iron over the wood . Most will come out . If you need to fill them I use the balsa colored Model Magic . Good Luck , MAX H.
Hide Signatures
(in reply to Trax540)
       Post #: 3
RE: Filling balsa? - 8/14/2009 6:14 PM
MinnFlyer
Score: 228
Status: offline
I've tried them all, and I keep coming back to this
Click to see fullsize image.
Click for fullsize
_____________________________
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don''t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to big max 1935)
       Post #: 4
RE: Filling balsa? - 8/14/2009 6:16 PM
RCPAUL
Score: 111
Last Login: 3/15/2010
Status: offline
I'm with MinnFlyer.
Paul
Gosh, model airplanes are not a matter of life and death - they''re more important than that!
Hide Signatures
(in reply to MinnFlyer)
       Post #: 5
RE: Filling balsa? - 8/14/2009 7:22 PM
Gray Beard
Score: 161
Status: offline
I have used the Elmers like Mike uses, as I recall it was pretty good stuff. I seem to always go back to the DAP Fast N Final light weight spackling. It's pretty much the same thing. in the store I always open the lid to check out what ever I'm going to buy to make sure it is fresh!! Items sit on the shelves a very long time and dry out. Even when dry you just add water and stir it up but why bother doing that when it's new.
The stuff I'm using is white and can show through some coverings. The Elmers comes in different wood shades so you can avoid this little problem.
I even use it as a fill for small gaps, I push it into the gap and let it dry, sand it then hit it with some thin CA. holds just like iron.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to RCPAUL)
       Post #: 6
RE: Filling balsa? - 8/14/2009 10:36 PM
foodstick
Score: 119
Status: offline
I use a lightweight spackle from home depot , can't think of the name,It comes in a white red and black plastic container..
Heres a tip if you are using a white colored spackle. Buy some acrylic hobby paint in the squirt bottle in a balsa color, when you are ready to do some fill work mix a tiny bit of paint with your filler in a second cup and your spackle will be tinted brown. Also I don't think the paint dries up and ruins the filler, I believe you can premix it to use at a later date.
< Message edited by foodstick -- 8/14/2009 10:58 PM >
A builder can not be broken ..only his airplanes can !
Self proclaimed RC addict member #1
Hide Signatures
(in reply to Gray Beard)
       Post #: 7
RE: Filling balsa? - 8/14/2009 10:48 PM
edmoor
Score: 100
Status: offline
i been using clear dope mixed with talcum powder for years....it bonds very well....
if it aint broke...ya aint flyin low enough
Hide Signatures
(in reply to DJokr)
       Post #: 8
RE: Filling balsa? - 8/14/2009 11:05 PM
Gray Beard
Score: 161
Status: offline
quote:
ORIGINAL: edmoor
Yes it does but it really stinks!!
Hide Signatures
(in reply to edmoor)
       Post #: 9
RE: Filling balsa? - 8/15/2009 4:06 AM
Dsegal
Score: 111
Status: offline
For small dents just moisten them and steam the wood with your covering iron. Works like magic.
Dave Segal
Hide Signatures
(in reply to DJokr)
       Post #: 10
RE: Filling balsa? - 8/17/2009 3:05 AM
FLYBOY
Score: 100
Status: online
I too use the light spackle. I have used many brands. They are all pretty good.
Fly it till the wings come off.
Hide Signatures
(in reply to Dsegal)
       Post #: 11
RE: Filling balsa? - 8/17/2009 3:55 AM
foodstick
Score: 119
Status: offline
Minnflyer,isn't that elmers wood filler REALLY heavy compared to light spackle and model magic? Obviously a small dent doesn't take much, But I was thinking that I have used the Elmers, and it was much heavier by volume?
Hide Signatures
(in reply to FLYBOY)
       Post #: 12
RE: Filling balsa? - 8/17/2009 4:12 AM
tailskid
Score: 143
Last Login: 3/12/2010
Status: offline
Minnflyer said: "I've tried them all, and I keep coming back to this"
Does that mean you keep getting dents????
# 93 in Club Saito
Hide Signatures
(in reply to foodstick)
       Post #: 13
RE: Filling balsa? - 8/17/2009 4:35 PM
MinnFlyer
Score: 228
Status: offline
quote:
ORIGINAL: tailskid
No, it means I build a lot (Don't forget, I've been building for about 50 years).
quote:
ORIGINAL: foodstick
Yes, the Elmer's is really heavy compared to those light-weight fillers, BUT...
1 - It's no heavier than the original wood (or at least not much heavier)
2 - You're not going to use a whole lot of it.
3 - Most important in MY book - I tried those light weight fillers when they first came out. I was VERY impressed with how light they were. But then I applied covering over wing fillet that had a lot of filler and the filler melted under the heat of the covering iron.
I would rather use something heavy than something that melts - besides, like it says in #2, you're not talking about using more than a few grams. Hell, a whole tub of it will
Now I only use the light-weight stuff on all-foam airplanes only.
Mike B.
Hide Signatures
(in reply to tailskid)
       Post #: 14
RE: Filling balsa? - 8/17/2009 4:49 PM
sebo
Score: 100
Status: offline
For small dents I put rubbing alcohol on them.
The wood returns to it's original shape (as does with your method) and it evaporates quickly so you can get on with your build.
No need to iron. ...........Ron
Hide Signatures
       Post #: 15
RE: Filling balsa? - 8/18/2009 6:51 AM
Luftwaffe Oberst
Score: 109
Last Login: 12/21/2009
Status: offline
quote:
ORIGINAL: MinnFlyer
Everyone who builds kits at my club use the same thing you do. It's tried and true. Dave, a elder in my club keeps telling me that back in the old day (Before CA and all those fancy glues came out on the market) he used to build with regular white glue. Don't laugh guys, he has a kit plane that's 37 years old with the original covering, and he flew it last Sunday!
Yep he built that with white glue and Elmers Filler. Wow!
"The Hun in the Sun" AMA# 856404
Radio Aero Modelers Club-Pulaski, NY
Hide Signatures
       Post #: 16
RE: Filling balsa? - 11/21/2009 5:38 AM
ivyspoppy
Score: 100
Last Login: 3/14/2010
Status: offline
Red Devil light weight spackle is the same as Model Magic. I have used it for years.
Hide Signatures
       Post #: 17
RE: Filling balsa? - 11/21/2009 6:15 AM
Andrewmc
Score: 105
Status: offline
For less minor dings (knocked the LE of H stab about 3mm deep on edge of bookshelf) try epoxy and micro balloons, mix the epoxy as normal (30min not 5min) then keep adding micro ballons until the consistancy of peanut butter and it will not flow. press into the ding and let dry.
The glass of the microballoons allows the epoxy to be sanded really easily to a super finish and has stuctural strength too.
Cosmetic, and shallow dings I use balsa filler. One of my collegues uses baking powder and thin CA, I have not tried this though.
Hide Signatures
(in reply to ivyspoppy)
       Post #: 18
RE: Filling balsa? - 11/21/2009 12:35 PM
OldScaleGuy
Score: 105
Status: offline
Elmer's Wood Filler and sometimes Hobbico Hobbylite Filler. Light weight spackle IMHO just doesn't hold up well.
Hide Signatures
(in reply to Andrewmc)
       Post #: 19
RE: Filling balsa? - 11/21/2009 1:18 PM
HighPlains
Score: 105
Status: online
Dents in balsa is easy. Do you know how to get rid of dents in carpet when you move furniture?
Ice cubes.
- Supplementary insipid innocuous inane vacuous proclamation
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 20
RE: Filling balsa? - 11/21/2009 3:56 PM
jaka
Score: 114
Status: offline
Hi!
Best way is a mix of brown micro balloons and either 24 hour epoxy resin or polyester resin.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Jan Karlsson Airracing products
MVVS, Motul "Micro" all synthetic oil
Hide Signatures
(in reply to DJokr)
       Post #: 21
RE: Filling balsa? - 11/21/2009 5:08 PM
DavidAgar
Score: 114
Status: offline
The stuff from the Home Depot is called Paint and Patch. I have been using it for years, Great stuff. Good Luck, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
(in reply to jaka)
       Post #: 22
RE: Filling balsa? - 11/21/2009 8:06 PM
Gray Beard
Score: 161
Status: offline
quote:
ORIGINAL: DavidAgar
Just depends on if I go to 48s or 20s what brand name I buy, the same stuff and works great. Years ago I used to use resins or epoxy but the fillers sand way to easy to be fooling around with it. If minn would stop using that mono stuff and come over to the light side he can turn down his iron!! One thing I really liked about the wood colored fillers is they don't show through the covering when using light colors like the white does. Years ago I used to usea product called plastic balsa, just came in a tube like glue, never did stick all that well and it would always dry before you were finished. I still know a number of builders using the white Elmers wood glue, works just as well as the titebonds.
Hide Signatures
(in reply to DavidAgar)
       Post #: 23
RE: Filling balsa? - 12/15/2009 8:16 PM
Leroy Gardner
Score: 100
Status: offline
Heard about the adding talcum powder in dope but can't find pure talc. Does it matter if there are addatives in it?
Hide Signatures
       Post #: 24
RE: Filling balsa? - 12/17/2009 5:50 AM
ram3500-RCU
Score: 115
Status: offline
Red Devil brand light weight filler/Spackle (almost no water content so it doesn't shrink) is the best, if you can find it, and less expensive than the stuff packaged for the hobby industry. The formula feathers better and powders when sanded instead of balling up like some of the other brands. For added surface strength, you can go over it with thin CA. It is very strong when soaked this way. I'm a carpenter as well and have been using it for decades now.
Hide Signatures
(in reply to Leroy Gardner)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
