RE: CGRCJets A-10 Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: CGRCJets A-10 Build Thread
Page: <<   < prev  15 16 17 18 19 20 21 22 [23] 24   next >   >>
Login
RE: CGRCJets A-10 Build Thread - 7/18/2011 8:29 PM
wowplanes
Score: 106
Last Login: 5/2/2013
Status: offline
Chris
How many cells are the Midi Fans running on?
Fahim
_____________________________
http://www.wowplanes.com
Hide Signatures
(in reply to cgrcjet)
       Post #: 551
RE: CGRCJets A-10 Build Thread - 7/19/2011 5:43 AM
cgrcjet
Score: 100
Status: offline
Hi Fahim
I believe it was 9s. Weight came in just under 24 pounds. Dexters will be 4 pounds lighter than Marks running couple tj90's. I lightened the layups and structure on his, so it should be a nice glider.
chris
WWW.CGRCJets.com
Hide Signatures
(in reply to wowplanes)
       Post #: 552
RE: CGRCJets A-10 Build Thread - 8/19/2011 5:30 PM
tulz161
Score: 105
Last Login: 6/19/2013
Status: offline
I just found what I'll be using to transport mine when I actually get my hands on one.
Money isn''''t everything... but everything makes me want it.
Hide Signatures
       Post #: 553
RE: CGRCJets A-10 Build Thread - 4/18/2012 2:24 PM
cgrcjet
Score: 100
Status: offline
I have started and updated version of the A-10 and you can follow along here. I will be reconfiguring the airframe and adding extra details to make a faster building and more scale kit.
http://www.rcuniverse.com/forum/m_11046459/anchors_11046680/mpage_1/key_/anchor/tm.htm#11046680
Chris
WWW.CGRCJets.com
Hide Signatures
(in reply to tulz161)
       Post #: 554
RE: CGRCJets A-10 Build Thread - 11/25/2012 6:41 PM
J.F
Score: 100
Last Login: 6/16/2013
Status: offline
In the final stages of finishing mine now, there's flight at the end of the tunnel
Little video of the first synchronised start of the two mw44 kerostarts.
http://vimeo.com/54228030
I think this is going to be plenty of power.
When installing it all, I remembered someone saying that 2 turbines are 4 times as much work. It is very true!! But we'll worth it.
Hide Signatures
       Post #: 555
RE: CGRCJets A-10 Build Thread - 11/25/2012 11:35 PM
cgrcjet
Score: 100
Status: offline
Nice James! That thing wants to get in the air. Please make sure cg is correct. An inch out may be a bad thing. Also, did you fix the rear wing incidence on this one?
Good luck and do post some video!
thanks
chris
WWW.CGRCJets.com
Hide Signatures
(in reply to J.F)
       Post #: 556
RE: CGRCJets A-10 Build Thread - 11/26/2012 8:48 AM
J.F
Score: 100
Status: offline
Hi chris,
This kit was bought from another guy in the uk, who purchased it from Lowell, who said that the incidence had been done. So assume its all ok.
What's the recommened cofg at present? She'll no doubt be nose heavy on take off from all the fuel, then more so when that landing gear goes up/forward.
J
Hide Signatures
       Post #: 557
RE: CGRCJets A-10 Build Thread - 11/26/2012 9:07 AM
Dave Wilshere
Score: 108
Status: online
J
Looking forward to this
D
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to J.F)
       Post #: 558
RE: CGRCJets A-10 Build Thread - 11/26/2012 12:12 PM
J.F
Score: 100
Status: offline
Glad you are....I'm cr*pping myself!
The pipes the Ilja (Grummania) made are v.good!
J
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 559
RE: CGRCJets A-10 Build Thread - 11/26/2012 7:43 PM
cgrcjet
Score: 100
Status: offline
quote:
ORIGINAL: J.F
Hi chris,
J
Send me a pic of underside of tail section. Good to be sure. Cofg is 4 inches back from leading edge. May want to try little less for first flight to se how it handles. Maybe just 1/4 inch less. I built a second one for john and lowell and john had cg back 1 inch to far and thought it would be fine but lost control after takeoff. Where is fuel located?
Do you have a pic of the new thrust tubes?
chris
WWW.CGRCJets.com
Hide Signatures
(in reply to J.F)
       Post #: 560
RE: CGRCJets A-10 Build Thread - 11/26/2012 10:57 PM
J.F
Score: 100
Status: offline
HI Chris,
if i balance at 4" with wheels down and no fuel then i'll be fine.
i have 3/8 between bottom of fus and underside of tail.
thruist tubes are a scaled down version of the ones Ilja makes for the skymaster A10 - good quality, good price, and fast turnaround.
If all goes well with the maiden I'll be ordering a full set of weapons off you!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 561
RE: CGRCJets A-10 Build Thread - 11/26/2012 11:28 PM
cgrcjet
Score: 100
Status: offline
quote:
ORIGINAL: J.F
HI Chris,
if i balance at 4'' with wheels down and no fuel then i'll be fine.
Just dont get too nose heavy. Depending on where the mains are fixed, it may take a bit to rotate. May want little extra stretch to take off from to be safe.
Rear horizontal stab looks fine.
How much for the thrust tubes?
chris
WWW.CGRCJets.com
Hide Signatures
(in reply to J.F)
       Post #: 562
RE: CGRCJets A-10 Build Thread - 11/26/2012 11:49 PM
cgrcjet
Score: 100
Status: offline
I wish your engine nacelle looked like someone shot it with a shotgun a few times like this one. This is my new unfinished plug for the new version. 4 days just on rivets. The mold is now finished and im actually laying it up as we speak. I will be posting some updates on the new thread soon.
Click for fullsize
Click for fullsize
Click for fullsize
WWW.CGRCJets.com
Hide Signatures
       Post #: 563
RE: CGRCJets A-10 Build Thread - 11/28/2012 6:13 PM
J.F
Score: 100
Status: offline
Looks awesome Chris, you have more patience than me!
Not sure on the retail price for the thrust tubes and "cones" from Ilja - prob best to send an email, as don't think he has on his web shop yet.
Hide Signatures
       Post #: 564
RE: CGRCJets A-10 Build Thread - 11/28/2012 6:20 PM
invertmast
Score: 193
Status: online
Damn chris, those nacelles look great! I get to be a beta tester right
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to J.F)
       Post #: 565
RE: CGRCJets A-10 Build Thread - 11/29/2012 12:53 AM
cgrcjet
Score: 100
Status: offline
Trust me, i dont have patience. I have to learn to deal with my impatience. I cant wait until this thing is done, but if i do, i know it will turn out a nicer kit.
When do you think you will maiden? Now im getting impatient, lol!
Thomas
Take your vacation and come down for couple weeks. You can stay at my house and you can help me finish up faster. We can make you 2 of them, and you could beta test both of them, i dont care. Could throw in some gas money if you wanted to drive down.
chris
WWW.CGRCJets.com
Hide Signatures
(in reply to invertmast)
       Post #: 566
RE: CGRCJets A-10 Build Thread - 11/29/2012 1:08 AM
invertmast
Score: 193
Status: online
Chris,
When my vacation comes around i will take you up on that offer! Lol. Ive gotcha some glass cut, i just have to find the time to ship it
Thomas W.
Hide Signatures
       Post #: 567
RE: CGRCJets A-10 Build Thread - 11/29/2012 2:16 AM
Ron101
Score: 116
Status: offline
That looks great man!
great work Chris.... can't wait to see it all done
"It''''s not personal, Sonny. It''''s strictly business."
Hide Signatures
       Post #: 568
RE: CGRCJets A-10 Build Thread - 11/29/2012 2:36 AM
cgrcjet
Score: 100
Status: offline
By that time i will be finished with it! Yes, i will use that glass on my wings. Maybe you could just bring it down when you come down on vacation next week.
I should be posting this on the new thread but i thought i would try and tease you a bit.
chris
Click for fullsize
Click for fullsize
Click for fullsize
WWW.CGRCJets.com
Hide Signatures
(in reply to Ron101)
       Post #: 569
RE: CGRCJets A-10 Build Thread - 11/29/2012 2:38 AM
cgrcjet
Score: 100
Status: offline
Engine Nacelle tomorrow!
chris
WWW.CGRCJets.com
Hide Signatures
       Post #: 570
RE: CGRCJets A-10 Build Thread - 11/29/2012 2:43 AM
invertmast
Score: 193
Status: online
quote:
ORIGINAL: cgrcjet
chris
LOL... probably true! I'll send you my address so you can just ship parts as you get them.
Thomas W.
Hide Signatures
       Post #: 571
RE: CGRCJets A-10 Build Thread - 12/13/2012 12:48 AM
cgrcjet
Score: 100
Status: offline
Hows it coming along James? No flight yet?
chris
WWW.CGRCJets.com
Hide Signatures
       Post #: 572
RE: CGRCJets A-10 Build Thread - 12/13/2012 8:32 AM
J.F
Score: 100
Status: offline
No not yet!
Two steps forward, one step back at the moment!
Hide Signatures
       Post #: 573
RE: CGRCJets A-10 Build Thread - 12/28/2012 1:45 PM
J.F
Score: 100
Status: offline
It flies!
Maiden flight today at a Uk jet meet.
Weather was typically British, wet,cold & blustery wind , but she flew fine.
Many thanks to dave for doing the maiden.
Flew at half throttle for entire flight.
Just a few tweaks to do and she's perfect.
Things to change are- reduce the throws of the nose wheel as it was very sensitive (not helped by a bit of crosswind).
And get the main gear to stay up, will increase air pressure or next flights.
Lengthen the nose gear just a tiny bit.
I'll post some photos once I've been sent, and hopefully a video also.
Sounded cool with the twin mw44's!
J
Hide Signatures
(in reply to J.F)
       Post #: 574
RE: CGRCJets A-10 Build Thread - 12/28/2012 9:48 PM
Dave Wilshere
Score: 108
Status: online
J
Yep, balance was good and control travel and expo guess spot on! Power is plenty, so looking forward to some real A-10ing...maybe at Duns...
D
Hide Signatures
(in reply to J.F)
       Post #: 575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
