RE: .12 Rigger Kits for CHEAP!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: .12 Rigger Kits for CHEAP!
Page: <<   < prev  68 69 70 71 72 73 [74] 75 76 77   next >   >>
Login
RE: .12 Rigger Kits for CHEAP! - 12/15/2012 9:02 PM
mike walker
Score: 100
Last Login: 5/18/2013
Status: offline
I got it !! but not telling
_____________________________
alcohol is for drinkin. gasoline is for cleanin . NITRO is for racin
Hide Signatures
(in reply to mike walker)
       Post #: 1826
RE: .12 Rigger Kits for CHEAP! - 12/16/2012 5:20 PM
mike walker
Score: 100
Status: offline
quote:
ORIGINAL: Joe Petro
That is a JAE 12G3 hull. I see two obvious clues in Mike's picture above.
If anyone can tell me what those two are, I will send them a free 12G epoxy glass cowling...
Mike Walker is not eligible. He builds far too many of these...
Joe
HINT!
# 1 Could it have some thing to do with that thing hanging on the right sponson? maybe I just don't know
Hide Signatures
(in reply to Joe Petro)
       Post #: 1827
RE: .12 Rigger Kits for CHEAP! - 12/16/2012 6:41 PM
advanced builder
Score: 105
Last Login: 5/23/2013
Status: offline
I know.but I'm not saying.
Stoney Pond Model Boat Club, Canandaigua, NY
International racer
Hide Signatures
       Post #: 1828
RE: .12 Rigger Kits for CHEAP! - 12/16/2012 7:04 PM
mike walker
Score: 100
Status: offline
quote:
ORIGINAL: advanced builder
I bet you do
He said I couldn't play. Is he going to let you play, you have done one or two also
Hide Signatures
(in reply to advanced builder)
       Post #: 1829
RE: .12 Rigger Kits for CHEAP! - 12/16/2012 8:38 PM
Tombsy
Score: 100
Status: offline
Man I'm not getting it, unless the tub and sponsons are narrower? It might just be the angle of the picture.
Brian
Namba District 16
Hide Signatures
       Post #: 1830
RE: .12 Rigger Kits for CHEAP! - 12/16/2012 9:15 PM
advanced builder
Score: 105
Status: offline
quote:
ORIGINAL: mike walker
I bet you do
Mike ,
I'll send you a PM with my answers. But I have never built a gen 3 hull. Mine has the original tab on right the end. For the Solinger mount. Gen 1
I have done many gen 2
International racer
Hide Signatures
       Post #: 1831
RE: .12 Rigger Kits for CHEAP! - 12/16/2012 9:48 PM
Joe Petro
Score: 108
Last Login: 5/17/2013
Status: offline
One answer is correct, one hinted at, but nobody has put them together.
All of the clues are in the pic posted by Mike.
Keep trying...
Joe
-Zippkits-
People make this a great hobby!
Hide Signatures
       Post #: 1832
RE: .12 Rigger Kits for CHEAP! - 12/16/2012 9:54 PM
Joe Petro
Score: 108
Status: offline
quote:
ORIGINAL: john d in texas
quote:
ORIGINAL: Joe Petro
Joe
Joe, Could it be the front half of the sponson bottom is one piece not two piece at different angles and looks like rear Boom tube is lower going thru the hull or maybe the bulkhead tabs look smaller/thinner ???
We have a winner! I am going to give it to John.
The other clue is the right sponson has only two dowels for the turn fin, but it is not easy to tell this unless you know.
John, please send me an email at support@zippkits.com
Congratulations John!
Joe
-Zippkits-
Hide Signatures
(in reply to john d in texas)
       Post #: 1833
RE: .12 Rigger Kits for CHEAP! - 12/16/2012 10:01 PM
john d in texas
Score: 100
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: Joe Petro
quote:
ORIGINAL: Joe Petro
Joe
Thanks Joe, Address Sent !!!! John D...
Joe
Hide Signatures
       Post #: 1834
RE: .12 Rigger Kits for CHEAP! - 12/17/2012 4:28 AM
tdrake694
Score: 100
Last Login: 3/8/2013
Status: offline
finally got er done...here are a few pics...any recommendations on a starting point for pipe length?? novarossi 5 port W/ a mac 2.5 pipe
thanks Tony
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1835
RE: .12 Rigger Kits for CHEAP! - 12/17/2012 5:02 PM
advanced builder
Score: 105
Status: offline
What is your pipe length now ? You look long. Your pipe bracket will need to be moved. Looks like. Great job on the build. No water lines needed the .12 NR loves it hot. Glenn sells a airplane head with fins.
International racer
Hide Signatures
(in reply to tdrake694)
       Post #: 1836
RE: .12 Rigger Kits for CHEAP! - 12/17/2012 8:42 PM
tdrake694
Score: 100
Status: offline
My pipes at 5 1/2 inches. I understand a long pipe will have more torque and a shorter pipe will have more top end. What will the effects be if I cut to much off
Hide Signatures
       Post #: 1837
RE: .12 Rigger Kits for CHEAP! - 12/17/2012 11:48 PM
advanced builder
Score: 105
Status: offline
One of my buddy's run a longer pipe. fire her up and let her loose. Use snap ties on the coupler. you don't want to loose that pipe. If you like the way she runs ,good.
International racer
Hide Signatures
       Post #: 1838
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 12:02 AM
Joe Petro
Score: 108
Status: offline
5-1/2 inches would put the maximum diameter just behind the blue coupler...
Measure from the glow plug, around the center of the header, to the max diameter.
7 inches is a good starting point. This will be about 3 inches shorter than you have it now, by the looks of it...
Joe
-Zippkits-
Hide Signatures
       Post #: 1839
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 12:05 AM
Joe Petro
Score: 108
Status: offline
It should look closer to this...
(Ron Olson build)
Joe
Click for fullsize
-Zippkits-
Hide Signatures
       Post #: 1840
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 3:37 AM
advanced builder
Score: 105
Status: offline
The .12 NR can be a pain in the butt to break in. Keep touching the head when started. Don't launch until the head warms up. When we launched Propcircles .18 , we went 1/8 lap to a 1/4 lap and so on many times. Finally after 1/2 a day messing. The engine finally loosened up and ran several good laps. What prop are you using?
International racer
Hide Signatures
       Post #: 1841
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 6:52 AM
tdrake694
Score: 100
Status: offline
Joe sorry I should have been more specific...my pipe length is 5 1/2 measured from glow plug to the widest part on the pipe.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1842
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 6:55 AM
tdrake694
Score: 100
Status: offline
If i measure from the header to the max diameter of the pipe its about 10 inches
Click for fullsize
Hide Signatures
       Post #: 1843
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 1:37 PM
mike walker
Score: 100
Status: offline
Get a piece of wire, cut it to 7 inchs put a bend in it and go from the glow plug rite down the center of the header pipe and go to the large point of the pipe and see what you get
Hide Signatures
       Post #: 1844
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 4:21 PM
Joe Petro
Score: 108
Status: offline
Cut 3 inches off the pipe and/or the header...
Joe
-Zippkits-
Hide Signatures
       Post #: 1845
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 4:23 PM
Joe Petro
Score: 108
Status: offline
show us, Mike Walker...
Joe
-Zippkits-
Hide Signatures
       Post #: 1846
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 5:03 PM
mike walker
Score: 100
Status: offline
Ok the first pic is my boat and home made pipe
Second pic is a mac 1110 pipe and a Rossi header 1 1/2 off the header and 2 in off the pipe get me 7 in
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1847
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 5:39 PM
Joe Petro
Score: 108
Status: offline
Excellent...
Joe
-Zippkits-
Hide Signatures
       Post #: 1848
RE: .12 Rigger Kits for CHEAP! - 12/18/2012 7:20 PM
tdrake694
Score: 100
Status: offline
Ok guys thanks for all the help. Just finished up joes prop that came with the kit and waiting on one of marks 1440 to come in the mail and I will be ready to hit the water
Hide Signatures
       Post #: 1849
RE: .12 Rigger Kits for CHEAP! - 12/19/2012 7:38 AM
tdrake694
Score: 100
Status: offline
has anybody had any luck with grimracer props..(36x55-38x55)?
Hide Signatures
       Post #: 1850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
