FTE 500 solenoid issue?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
King Tech K180G
Seller:  Modellbau USA
Details:   $2,895.00   |  5/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> FTE 500 solenoid issue?
Page: [1]
Login
FTE 500 solenoid issue? - 8/20/2009 8:10 AM
sonito
Score: 100
Last Login: 5/22/2013
Status: offline
Hi new to turbines and have the following issue: I have an FTE 500 that does not get fuel to the motor checked the pump and works fine checked filters and all clear, now the solenoid for the fuel does not let the fuel into the motor, do these little guys go bad? and if so where do I get another one?
I live in the Tampa bay area if anyone can help me out here I would be glad to hear something
thanks,
Forrest
Hide Signatures
       Post #: 1
RE: FTE 500 solenoid issue? - 8/20/2009 9:56 AM
GSR
Score: 110
Last Login: 5/25/2013
Status: offline
Make sure that you have it plugged into the ECU correctly. With the RAM ECU it is easy to miss the pins making you think it is plugged in when it is not. Also make sure the black wire is oriented towards the black dot on the label. Scotty
_____________________________
"If you ain''t crashed-You ain''t flown"
Hide Signatures
(in reply to sonito)
       Post #: 2
RE: FTE 500 solenoid issue? - 8/21/2009 1:35 AM
sonito
Score: 100
Status: offline
Checked the connection and still wont work, where do i buy a new solenoid?
Hide Signatures
(in reply to GSR)
       Post #: 3
RE: FTE 500 solenoid issue? - 8/21/2009 1:40 AM
hooker53
Score: 100
Status: offline
RTI
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
       Post #: 4
RE: FTE 500 solenoid issue? - 8/21/2009 5:15 PM
B58
Score: 100
Last Login: 1/9/2011
Status: offline
You could swap it with the gas one and give it a try. Easy way to make sure. Bob
Hide Signatures
(in reply to hooker53)
       Post #: 5
RE: FTE 500 solenoid issue? - 8/21/2009 6:41 PM
Chris Smith
Score: 105
Status: offline
On mine Carlos found the circuit that controls the solenoid in the ECU was the problem not the solenoid. We did not need to fix the ECU, I chose not to run a solenoid. I use a manual fuel shutoff instead.
Chris
Hide Signatures
(in reply to B58)
       Post #: 6
RE: FTE 500 solenoid issue? - 8/23/2009 10:42 PM
E.N.T.
Score: 100
Last Login: 5/24/2013
Status: online
When thr fuel solenoid in my RAM 750 was damage, I talked to Carlos, and he told me
to try it without the solenoid. It worked so well, that since then I run iy without it. Gave
the turbine more power.
ENT
Hide Signatures
(in reply to Chris Smith)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
