Flex shaft spacing problems...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> Flex shaft spacing problems... Page: [1]
Login
Flex shaft spacing problems... - 8/20/2009 7:38 PM
miniature_business
Score: 103
Last Login: 10/12/2010
Status: offline
I've got a Dumas deep vee 40 with an OS 46 in it and I'm concerned with the spacing of the flex shaft near the engine u-joint. How much space should there be between the u-joint and the brass tube? I'm concerned that there is too much space which is what caused my last flex shaft to kink. As well, is 3/16ths a good gap between the drive dog and the strut? Thanks
Hide Signatures
       Post #: 1
RE: Flex shaft spacing problems... - 8/20/2009 7:46 PM
Dan S
Score: 115
Last Login: 5/7/2013
Status: offline
between the drive dog and strut spacing should be the thickness of your flex cable, so if your cable is 3/16, than yes, 3/16 is good (no less).
as for the U-joint, I don't know, maybe a pic of the problem could help.
Dan.
_____________________________
F-41 Stryker Cat 260 Full Mod - Whiplash GV NFS 260 - FireFighter 18 - Miss Vegas CVRM 18
Futaba FASST
Hide Signatures
(in reply to miniature_business)
       Post #: 2
RE: Flex shaft spacing problems... - 8/21/2009 12:05 AM
black talon
Score: 100
Last Login: 12/26/2012
Status: offline
if the last one kinked, i would say it's too much.
One day at a time, it''''''''''''''''s not always a race.
Hide Signatures
(in reply to Dan S)
       Post #: 3
RE: Flex shaft spacing problems... - 8/21/2009 2:15 AM
Square Nozzle
Score: 105
Last Login: 5/18/2013
Status: offline
You should'nt be using a 'U' joint with a flex cable. There is no support for the shaft at the engine. You should use a cable collet at the engine. The gap is then created at the strut and as stated by Dan, should be equal to the shaft diameter.
John
Hide Signatures
(in reply to black talon)
       Post #: 4
RE: Flex shaft spacing problems... - 8/21/2009 2:27 AM
miniature_business
Score: 103
Status: offline
Cool, that's what I thought. Now the gap between the u-joint and the brass tube is about half an inch. I was thinking, I should get a longer nylon tube that goes the length of the shaft so there is no gap between the u-joint and brass tube. I'm not too sure how secure the nylon tube will be, it's just something to keep it all in line. As well, can I un-solder the kinked shaft from the ferrule and re-solder a new cale to it? If so, how is this done, and what's the best solder to use. I figure it's like plumbing soldering. Thanks all
Hide Signatures
       Post #: 5
RE: Flex shaft spacing problems... - 8/21/2009 3:12 AM
Dan S
Score: 115
Status: offline
Silver solder.
Dan.
Futaba FASST
Hide Signatures
       Post #: 6
RE: Flex shaft spacing problems... - 8/21/2009 5:19 AM
black talon
Score: 100
Status: offline
the higher the silver content the stronger the joint.
Hide Signatures
(in reply to Dan S)
       Post #: 7
RE: Flex shaft spacing problems... - 8/21/2009 6:20 AM
Square Nozzle
Score: 105
Status: offline
Repeat! Get rid of the U joint and put a cable collet on the engine. U joints are intended for solid shafts not flex shafts.
John
Hide Signatures
       Post #: 8
RE: Flex shaft spacing problems... - 8/21/2009 6:41 AM
unclecrash
Score: 110
Last Login: 5/19/2013
Status: offline
I modded my whole boat deepv 60 it had a submerged dive. But I just changed it over to surface drive handles much better. Also moved the engine as low as possible so the boat wasn't top heavy..and it barely has a bend in the stuffing box.
I Ain''''''''t Buildin No TuG Boats
Hide Signatures
(in reply to Square Nozzle)
       Post #: 9
RE: Flex shaft spacing problems... - 8/21/2009 6:53 AM
miniature_business
Score: 103
Status: offline
Great thanks! I think I'm gonna try and unsolder it. The shaft is no use to me anymore so I might as well. Whoever built it decided to switch out the recommended hardware (solid shaft with a sumberged u-joint) with a flex shaft and u-joint at the engine. I'm not sure if the guy used a u-joint because the flex shaft doesn't line directly up with the engine but I'll check. If it does I'll change it out. The only thing I'm wondering is if the flex shaft lines up with the engine and the u-joint spins straight, why would this cause a problem? I understand the first one probably went because I ran it with an unbalanced prop and flipped it and over rev-ed it. Would having the nylon tube butt up with the u-joint provide any more stability?
Hide Signatures
       Post #: 10
RE: Flex shaft spacing problems... - 8/21/2009 8:12 AM
Ron Olson
Score: 1175
Status: offline
quote:
ORIGINAL: Square Nozzle
OK, what he said twice. The OS .46 is threaded for 1/4"-28TPI. It's a common flex collet size available from Octura and Aeromarine. This will be tied to a 3/15" flex cable.
If you have to, redo everything to make it work as it will be worth the time and money.
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
       Post #: 11
RE: Flex shaft spacing problems... - 8/27/2009 2:07 AM
miniature_business
Score: 103
Status: offline
well I have taken your advice and I'm replacing the u-joint with a collet and I've unsoldered the ferrule. I have one last question.. I think I can figure the rest out by myself. Seeing that the prop shaft and flex shaft are one peice, do I cut the old flex shaft as close to the prop shaft as possible and then resolder? Thanks
Hide Signatures
(in reply to Ron Olson)
       Post #: 12
RE: Flex shaft spacing problems... - 8/27/2009 2:40 AM
Square Nozzle
Score: 105
Status: offline
Typically when you buy a new flex shaft it comes with the prop shaft already installed. You cannot cut the old flex shaft from the prop shaft and butt solder a replacement back on. It will not be strong enough to take the prop torque. Just buy the correct diameter flex shaft, cut it to length so you have 1 cable diameter gap between the front side of the prop drive dog and the strut and full engagement into the cable collet on the engine. It is recommended that you fill the engine end of the cable with silver bearing solder like Sta Brite before you cut it to final length so it doesn't crush when you tighten the collet. Wash the cable end in acetone or MEK to get the oil out, Flux the cable end real well and then melt in the silver solder so it fills the gaps between the strands of the cable. Don't just lay the solder on the surface. It has to soak in. You can remove the excess with a file or a hobby knife.
John
Hide Signatures
       Post #: 13
RE: Flex shaft spacing problems... - 8/27/2009 10:46 AM
miniature_business
Score: 103
Status: offline
so then the whole point of the ferrule is to brace the prop thrust on the flex shaft, not to connect the flex shaft to the prop shaft. Please bear with me, I am new to this whole flex shaft world. I just feel like I got mislead when I bought my new hardware.
Hide Signatures
       Post #: 14
RE: Flex shaft spacing problems... - 8/27/2009 11:48 AM
unclecrash
Score: 110
Status: offline
Dont want to confuse you but they make a ferrule that is soldered to the flex shaft it has 2 allen screws to hold the prop shaft on to the flex. It uses bushing wiith a bearing in front at the ferrule and at the rear for when the prop loads onto the rear of the strut. My rigger is made this way.
Hide Signatures
       Post #: 15
RE: Flex shaft spacing problems... - 8/27/2009 4:15 PM
Square Nozzle
Score: 105
Status: offline
Can you get a photo of your installation? What Unclecrash is saying is correct if you have an open ended shaft housing that goes from the hull to the strut but ends before the strut. In this case a ferrule is soldered on to the aft end of the flex cable and butts against the front of the strut. The prop shaft then goes through the strut and slides into the ferrule where it is locked in place with set screws. If the shaft housing come out of the bottom of the hull and attaches to the strut, then you have no ferrule. The prop shaft is typically designed with a hole in the forward end to accept the soldered or brazed in flex cable.
John
Hide Signatures
       Post #: 16
RE: Flex shaft spacing problems... - 8/29/2009 2:24 AM
miniature_business
Score: 103
Status: offline
Hey everybody! Sorry this has been so confusing. I had my information all mixed up. The strut is a Dumas strut with a needle bearings. What my boat was set up with was a universal joint on an OS 46 max and what I was referring to as the "ferrule" was a brass tube soldered to the flex shaft. This was installed behind the needle bearings to prevent the shaft from sliding out. Since I'm gonna be using a collet, no more brass tube. I was wondering, The guys from my LHS set me up with some teflon bearings, flange reducers and some brass tube to reduce it. I was wondering, is there anything wrong with using the needle bearing set up?? The prop shaft is machined far enough so that the needle bearings run on a smooth surface. I can't see why I would go through the trouble converting... Sorry for all the confusion and thanks again guys!
Hide Signatures
       Post #: 17
RE: Flex shaft spacing problems... - 8/29/2009 5:33 AM
Square Nozzle
Score: 105
Status: offline
I assume the teflon bearings are supposed to go into the strut to replace the needle bearings. If they are to put on the shaft in front of the prop drive dog as thrust bearings then I would suggest that you dont use them. The thrust bearing system works well with a square drive but not with a cable collet. As we have told you, there should be 1 shaft diameter gap between the drive dog and the strut. Without that gap, when the shaft "shrinks" under load it's likely to fail. I have used teflon bearings in the strut and also used needle bearings. Teflon tends to hammer out if the system (prop and shaft) is not well balanced. Needle bearings will eventually wear into the prop shaft if you are not diligent about lubrication. Choose your poison.
< Message edited by Square Nozzle -- 8/29/2009 4:58 PM >
John
Hide Signatures
       Post #: 18
RE: Flex shaft spacing problems... - 8/29/2009 7:30 AM
miniature_business
Score: 103
Status: offline
Thanks a lot for the great info! I have my plan and a much better understanding of the strut/prop shaft assembly.
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.699RCU1
