RE: ESM Fairey Swordfish    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: ESM Fairey Swordfish
Page: <<   < prev  10 11 12 13 14 15 16 17 18 [19]
Login
RE: ESM Fairey Swordfish - 11/19/2012 8:14 AM
ramboman
Score: 100
Last Login: 5/21/2013
Status: offline
Hello, I will build my swordfish this winter.
Already assembled: a 12s2p a123 pack to go under the cowl, full forward.
The pack is charged in place, it's never removed from the plane.
She will get an old Cyclon 160: 2500W continuous, with a CC ICE2 120.
Planning folding wings as real plane...
Hide Signatures
(in reply to AZThud)
       Post #: 451
RE: ESM Fairey Swordfish - 11/26/2012 5:14 PM
Destroyer of Airplanes
Score: 100
Last Login: 3/9/2013
Status: offline
Ramboman, I would be interested in seeing your design for the wing hinges. Also How would you connect the wing spars?
_____________________________
Best Regards
Paul
Hide Signatures
(in reply to ramboman)
       Post #: 452
RE: ESM Fairey Swordfish - 11/26/2012 5:33 PM
Score: 100
Status: offline
I did manage to get some time to work on the Swordfish. I installed a Williams Brothers 1/6 scale Wasp over the Rimfire1.60.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Best Regards
Paul
Hide Signatures
(in reply to Destroyer of Airplanes)
       Post #: 453
RE: ESM Fairey Swordfish - 11/26/2012 11:09 PM
AZThud
Score: 100
Last Login: 6/18/2013
Status: online
That motor looks very nice, its a big imprprovment.   One of the problems I had, was that to move the weight up to where it needs to be, the front end of my machine is full or batteries and motor.    I was lucky enough to have this picture taken when I was out at the field (thanks Rafael), as you can see the your motor would be a huge improvement.   Still she looks nice in the air and draws a big crowd at the field.   Good Luck with yours!
Cheers
Click for fullsize
Rick,
Hide Signatures
       Post #: 454
RE: ESM Fairey Swordfish - 11/26/2012 11:32 PM
Score: 100
Status: offline
AZ,
I suppose you could always stuff the front end of the torpedo with lead. Since I am building her as a MK III I will have a radar dome under the nose. This will also be a great place to put lead.Here are a couple more shots of the motor mounting method.
Paul
Click for fullsize
Click for fullsize
Best Regards
Paul
Hide Signatures
       Post #: 455
RE: ESM Fairey Swordfish - 11/27/2012 5:59 AM
ramboman
Score: 100
Status: offline
Look at this...
Build the wings as usual
Don't use the wingtubes
Pivot on back mast
Ues two locks at front...
Click for fullsize
Hide Signatures
       Post #: 456
RE: ESM Fairey Swordfish - 11/27/2012 1:33 PM
Robert Bishop
Score: 100
Last Login: 3/17/2013
Status: offline
Hey Ramboman, Best of luck with your hinged wing idea. Looking forward to see how you will do it. One thing for sure is the need to make the center section mountimg more substantial. The existing design relies on the bottom wing and flying wires keeping the top wing aligned with the bottom. Keep us informed of your progress.
Hide Signatures
       Post #: 457
RE: ESM Fairey Swordfish - 11/27/2012 2:33 PM
ramboman
Score: 100
Status: offline
OK
Hide Signatures
(in reply to Robert Bishop)
       Post #: 458
RE: ESM Fairey Swordfish - 11/27/2012 3:44 PM
AZThud
Score: 100
Status: online
Paul I did something similar to mount an engine in my H9 P-47 Razorback (the old one) what you did with the crankcase is exactly what I did too.    What you did diferently and waht I think is better is mount the engine to the motor mount.    I mounted mine to the cowl, centered it, centered the motor, trial and fit, followed by more trial and fit or "fits" as it were.     Putting the false engine directely onto the motor mount, is genius!   Next time  I will do it your way!!
Cheers
Rick
Rick,
Hide Signatures
       Post #: 459
RE: ESM Fairey Swordfish - 11/27/2012 3:59 PM
Score: 100
Status: offline
AZ, thanks for the kind words. What surprised me the most is it fit correctly the first time. I couldn't believe it. I never get stuff right the first time.
The only thing had to do was remove most of the lower half of the cowling support ring. As you know the cowl is quite a bit smaller in the back and the motor slightly larger but with a bit of flexing the cowl it went through.
Best Regards
Paul
Hide Signatures
       Post #: 460
RE: ESM Fairey Swordfish - 12/5/2012 10:08 PM
jmpups
Score: 101
Status: offline
I read your advice on the Swordfish . I am considering purchasing one of these kits from A local flyer. Can you tell me, did you epoxy both the upper and bottom wings to make two full wing panels . Also I have built two ESM kits, the T28 and the Aiachi Val. Both were A royal pain to properly assemble the elevator joiner, as well as the tailwheel assy to the rudder on the Val, mainly due to such A tight space. Am I looking for the same problems with the Swordfish ? Any advice you can give me is most appreciated. Thanks, Joe
Hide Signatures
(in reply to ispirit99)
       Post #: 461
RE: ESM Fairey Swordfish - 12/6/2012 12:19 AM
AZThud
Score: 100
Status: online
Hi I did not join the wings, I rely on the bottom screw to hold on both sets of wings,   I cannot transport the plane unless it is apart so glueing the wings was not an option but if you have something big enough glueing the wings at the top would something that you could do.     If you can't transport it in one piece I would say leave the wings removable.    The horizontal stab is one piece and you will not be revisiting the tail joiner tube nightmare :-)
Good Luck,
Cheers
Rick,
Hide Signatures
(in reply to jmpups)
       Post #: 462
RE: ESM Fairey Swordfish - 12/6/2012 3:27 PM
Score: 100
Status: offline
jmpups, The tail wheel is easy. I used a du-bro large scale tail wheel and mounted it on a piece of plywood. I also put it in a scale location.
Click for fullsize
Click for fullsize
Best Regards
Paul
Hide Signatures
       Post #: 463
RE: ESM Fairey Swordfish - 12/11/2012 5:14 PM
Score: 100
Status: offline
Last evening while installing the tail section I found a problem. The struts that support the horizontal stab are screwed int balsa wood on the wing training edge and the balsa wood spar. In the fuselage they screw into fiberglass fuselage. If in fact these struts are functional as I presume they are the prescribed method of attachment will most likely lead to failure. I thought about trying to harden the balsa around the screw hole with thin CA, but there is really no way of knowing if it will be sufficient. My solution was simple I used a dremmel tool to remove about 1/4 inch of material on the wing's trailing edge and spar into which I epoxied a small piece of 1/4 inch ply. I also epoxied a small square of wood behind the fiberglass. Now the struts are functional and very strong.
Click for fullsize
Best Regards
Paul
Hide Signatures
       Post #: 464
RE: ESM Fairey Swordfish - 12/11/2012 8:01 PM
AZThud
Score: 100
Status: online
I just added a couple of bits of wood to the inside of the fuse at the strut attachement points.     As the horizontal stap is a single piece my conclusion is that the struts are pretty much decoration and did not put a lot of thought into them.    I have no intention of anything other than scale flight for mine and unless I crack it up the last thing I am worried about is the tail breaking :-)
I had her out to the field this weekend and our club prez was there with his video camara, he put together a video of the plane our field and club, its mostly of the swordfish and if you would like to take a look, many thanks to Jim for putting this together.
http://www.youtube.com/watch?feature=player_detailpage&v=t0-hQtP-P64
Rick,
Hide Signatures
       Post #: 465
RE: ESM Fairey Swordfish - 12/11/2012 8:14 PM
Score: 100
Status: offline
AZ, Great video, very nice field too. Boy on final with that hill in the background she becomes a little difficult to see. Could make for some very interesting approaches.
Best Regards
Paul
Hide Signatures
       Post #: 466
RE: ESM Fairey Swordfish - 2/10/2013 8:15 PM
Electroyal
Score: 100
Last Login: 2/10/2013
Status: offline
This question is regarding the hardware that comes with the ESM P-51, 71" Glamorous Glen model.  It has a pull pull control system with a thin wire cable to hook up the rudder and elevator.  Has anyone flown this plane with the original hardware or does anyone suggest replacing the wire cable with a rigid control rod and if so what size?
Chuck
Hide Signatures
       Post #: 467
RE: ESM Fairey Swordfish - 5/27/2013 12:10 PM
mackone
Score: 100
Last Login: 5/27/2013
Status: offline
I got mine in the air on the weekend , and must say thankyou to all on this thread , It was a big help to get mine airbourne .
And what a great flyer is is as well .
It was quite and engineering feat to get the Fake radial in , my solution which was a combination of all of the above , was to fill it with 800gms of lead !
so in my cowl i have 1 4s 5000 pack + 130amp esc + the fake williams bros radial with the lead . Inside the fuse i have 2 more 4s 5000mah packs which all
join in series , with a very load noise . The motor is Hyperion 55-45 150 kv which i have had for years and the Prop is a 19.9 x 14 x 3 vario prop .
Hide Signatures
(in reply to Electroyal)
       Post #: 468
RE: ESM Fairey Swordfish - 5/27/2013 12:11 PM
mackone
Score: 100
Status: offline
My Maiden
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to mackone)
       Post #: 469
RE: ESM Fairey Swordfish - 5/28/2013 4:31 AM
rcflying007
Score: 100
Last Login: 6/16/2013
Status: offline
mackone , thanks for sharing the pictures, looks beautiful.
Love others you''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''ll be loved.
Hide Signatures
       Post #: 470
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
