RE: It's here and Looks GOOD new Hangar 9 Taylorcraft
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: It's here and Looks GOOD new Hangar 9 Taylorcraft
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/3/2009 4:59 PM
gade600sdi
Score: 100
Last Login: 3/19/2010
Status: offline
OK, I got it last night. As described above its awesome top quality you would expect from Hangar 9. Its a little smaller than I expected it seems slightly smaller than 1/4 scale I thought it was, maybe more like 1/5 scale I am guessing. My brother has a true vintage (non clipped wing 1/4 scale) that is my comparison.
So I have the Zenoah G26 Engine. The instructions on the engine say that the firewall needs to be 8MM thick to mount the Zenoah 26. I am a little concerned that this engine may be too big. I could get a 20cc or perhaps and Evolution 26GX (gasser) instead both those would fit also. I think the Zenoah 26 will fit with the room, but is the 3.3 pound engine too much engine on that firewall. I guess I could reinforce it somehow but its hard to do from the back hard to get in there it would have to be another flat plywood on the face of the firewall epoxied to it is the only way to really beef up the thickness.
Give me some help here I am new to this and the gas engines.
Thanks.
Hide Signatures
(in reply to gade600sdi)
       Post #: 26
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/3/2009 6:25 PM
Zippi
Score: 134
Status: offline
gade600sdi,
Your G26 should be fine. The mag version only weighs 6 oz more than the I/E which weighs 53.6 oz. The manual calls for a 20cc-26cc engine. I'm putting the new DLE 30cc on mine and it weighs 37.7 oz. What page in the manual did you see the "firewall needs to be 8MM thick to mount the Zenoah 26". I looked through the manual just breifly and didn't see that.
_____________________________
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
Hide Signatures
       Post #: 27
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/3/2009 6:32 PM
gade600sdi
Score: 100
Status: offline
Zippi, its on the manual for the Zenoah G26ei. It says make sure you mount this on a firewall of plywood consisting of 8mm thick. Well, I get around 5MM thick for the firewall the best I can tell.
I am just a little nervous and reading all the manuals because I am new to giant scale and new to gas engines. I dont want it to go soft or break up on me its a $500 plane. It says 20-26cc gas but I am wondering if they meant it for 20cc Zenoah, or 26cc Evolution GX? They only show the Zenoah as the engine on the box and don't show anything at all on the firewall markings or instructions about 26cc gas. I guess they are leaving it up to us to figure out.
Hide Signatures
(in reply to Zippi)
       Post #: 28
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/3/2009 6:42 PM
Zippi
Score: 134
Status: offline
gade600sdi,
The manual is designed around the G20 in hopes that new people to gas like you will buy the G20 from Horizon. Mount your cowl since it is pre-drilled on the cowl and the fuse. Lay a straight edge accross the front of the cowl and take a measurement from the firewall to your straight edge. Add 1/32" to 1/16" for the gap needed between the cowl and the spinner back plate. I'll have to read the manual but I'd say they are telling you to build 8mm in front of the firewall or use stand-offs as most do. What page was all that info on?
Hide Signatures
       Post #: 29
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/3/2009 7:24 PM
gade600sdi
Score: 100
Status: offline
Zippi, I understand the stand offs and the distance from the firewall to the cowl end and air gap for spinner etc. The manual in the ZENOAH ENGINE BOX clearly states that the firewall should be 8mm thick to mount the zenoah 26cc. They are not referring to the standoff depth or anything like that, but how beefy the plywood is on the firewall. Hope that clears up my question.
Hide Signatures
(in reply to Zippi)
       Post #: 30
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/3/2009 10:45 PM
Zippi
Score: 134
Status: offline
gade600sdi,
I measured my firewall and It's 1/4" thick (6.35mm). I have a Rascal 110 with a G26 and I think the firewall is the same thickness. You'll be fine. I mounted my cowl and took a measurement from the firewall to the front of the cowl where I had a straight edge accross the cowl and the dimension is 5 5/8" (142.875mm). I'll add 1/16" (1.587mm) for the gap between the cowl and the spinner back plate. How's the pilot look to everyone??? Looks like he has club feet .
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 31
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/4/2009 1:02 PM
gade600sdi
Score: 100
Status: offline
OK Zippi thanks for the input I will go with the G26 Zenoah. I may have to get different length standoffs (shorter) for the G26 because the distance from the back to the drive washer is probably longer than on the G20.
I love the tail how it goes together...quick. The plane is nice. Hangar 9 never disappoints me as far as the kit quality.
Hide Signatures
(in reply to Zippi)
       Post #: 32
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/4/2009 6:13 PM
Zippi
Score: 134
Status: offline
I have not had a chance to do anything with mine except open the box and trial fit all the components. Sunday I should have some time so I'll start with the fuse and re-shrink the covering and add epoxy to all the credical points I can reach. I'll be using Hitec HS-645MG servos which I'm getting ready to order from Tower for $29.00 ea. Pretty good price. I know it's a little over kill but I like it that way. Hate for a gear to strip out or not have enough torque. Don't ask me how I know but that was years ago. I'll probably be slow on this build as I only get a little time here and there to work on it.
The G20 measures 120mm from the back of the flat mount to the end of the prop hub and the G26 measures 139mm. Since the Taylorcraft comes with 28mm stand-offs you'll need stand-offs that measure 9mm. Hope I did the math correct .
Hide Signatures
       Post #: 33
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/4/2009 11:12 PM
Zippi
Score: 134
Status: offline
quote:
ORIGINAL: Old Fart
Nice looking.Can you include the measurement from the firewall to the cowl front?
The cowl is pre-drilled and the fuse as well. I mounted the cowl and measured from the firewall to the outer edge of the cowl with a straight edge accross the cowl and it's 5 5/8". The manual doesn't give any dimensions that I could find.
Hide Signatures
(in reply to Old Fart)
       Post #: 34
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/5/2009 6:59 PM
isaygen
Score: 100
Status: offline
I plan to purcahase H9 T.Craft. ( I still have old version with OS 160 twin ) but I could not give to decision engine choice between OS 160 twin or Fuji 24 BTEİ.I have no any experience with gas engines but I know less fuel cost , easy to adjust. Any info will be usefull. Thanks in advance.
Hide Signatures
       Post #: 35
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/6/2009 12:02 AM
Zippi
Score: 134
Status: offline
quote:
ORIGINAL: isaygen
There are a host of gas engines that will fly this plane. Just depends on how you want to fly it. If you want it to fly scale then I'd go with the recommended G20. If you want it to be a full out aerobatic plane then step up to the G26 or like I'm doing and install the new DLE 30cc gasser.
Hide Signatures
(in reply to isaygen)
       Post #: 36
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/6/2009 12:23 AM
Old Fart
Score: 115
Status: offline
Hi zippi and thanks for the info.Can you tell me how wide the cowl is? i'd like to fit a saito 182 flat twin and it's 196mm (roughly 8") across the heads,without cutting the cowl.Good luck with yours.
Watch out for the ground eh?
Hide Signatures
(in reply to Zippi)
       Post #: 37
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/6/2009 12:31 AM
Zippi
Score: 134
Status: offline
quote:
ORIGINAL: Old Fart
Hi zippi and thanks for the info.Can you tell me how wide the cowl is? i'd like to fit a saito 182 flat twin and it's 196mm (roughly 8'') across the heads,without cutting the cowl.Good luck with yours.
Old Fart,
I have the cowl fastend on at the moment but I measured the firewall the other day and at the widest part of the firewall its 8". That saito 182 flat twin should really sound nice.
Hide Signatures
       Post #: 38
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/6/2009 6:30 PM
Zippi
Score: 134
Status: offline
I did get a little work done on the Taylorcraft today and the only thing I don't like is the way the landing gear cuffs fit to the fuse. I have already split one trying to fit it all the way to the fuse. I also got to looking at the pilot that came with the plane and remembered from the review video that the pilot is suppose to be the same one that comes with the 1/4 scale cub and it's not. I have contacted Horizon about this.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Zippi)
       Post #: 39
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/6/2009 7:24 PM
mobyal
Score: 105
Status: offline
I picked mine up on Friday and got it unpacked and inspected yesterday. It really looks good. There was no shipping damage, even though the box had some crushed places and a hole punched through the top. No wrinkles at all in the covering. Everything fits together well, though I haven't yet messed with the gear. I'll probably start on it tomorrow and, contrary to the sequence in manual, will do the wings first. I plan to use a solder clevis on the servo horn and the screw-on clevis on the aileron rather than the way the manual shows. I simply don't trust any control surface secured by a screwon clevis at both ends. Don't care how many jam nuts you put on there, it'd be just my luck to have one of the rods vibrate loose. The way shown is probably OK, but it's just me. I prefer the solder clevis. Then servos in the fuse and I'll mount the gear and the tail surfaces and probably will use epoxy as well as the bolts on the tail. Again, just me. Belt and suspenders. Still not sure what I'll power it with. I have an EVO 1.0 NIB, and the new EVO 120 looks tempting, particularly at $70 less than the OS 120 2-cycle. Wonder how those will fit the predrilled firewall holes, if at all.
All in all, great job, H9!
Al
MobyAl
Hide Signatures
(in reply to Zippi)
       Post #: 40
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/6/2009 9:59 PM
Zippi
Score: 134
Status: offline
Here are a couple more pics. I'm as far as I can go until my servos get here which I ordered today and Ralph get my DLE 30cc finished. Once all the wing struts are in place it makes everything very strong. This plane is like a little tank .
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to mobyal)
       Post #: 41
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/7/2009 1:14 PM
Old Fart
Score: 115
Status: offline
Hi zippi good choice on the servos i run a 2500mh eneloop pack with them.If you get time could you give me an accurate measurement across the cowl about 2" back from the front please? yes i think the 182 would suit this plane especially with a couple of th headers pointing straight out the bottom of the cowl or one of keleo creations beautiful pitts style mufflers
Hide Signatures
(in reply to Zippi)
       Post #: 42
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/7/2009 1:50 PM
Zippi
Score: 134
Status: offline
quote:
ORIGINAL: Old Fart
Hi zippi good choice on the servos i run a 2500mh eneloop pack with them.If you get time could you give me an accurate measurement across the cowl about 2'' back from the front please? yes i think the 182 would suit this plane especially with a couple of th headers pointing straight out the bottom of the cowl or one of keleo creations beautiful pitts style mufflers
It's hard to measure inside the cowl but I'm getting about 8 1/8" around 2" inside the front of the cowl. The back of the cowl measures 8 1/2". Hope this helps.
Hide Signatures
       Post #: 43
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/8/2009 12:56 PM
Old Fart
Score: 115
Status: offline
Many thanks for the measurements zippi,i'm keen enough to look for a kit over here and measure it,that aeroplane is nice and may have to sacrifice a cowl cheek.
Hide Signatures
(in reply to Zippi)
       Post #: 44
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/10/2009 2:38 AM
dale691
Score: 100
Status: offline
Haven't had time to get to mine. Is anyone getting into the build yet?
Hide Signatures
       Post #: 45
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/10/2009 2:47 AM
Zippi
Score: 134
Status: offline
quote:
ORIGINAL: dale691
dale691,
Mine is all together. Just waiting on the servos and the engine.
Hide Signatures
(in reply to dale691)
       Post #: 46
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/10/2009 3:36 AM
mobyal
Score: 105
Status: offline
quote:
ORIGINAL: dale691
Starting on mine tomorrow am
MobyAl
Hide Signatures
       Post #: 47
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/10/2009 12:04 PM
dale691
Score: 100
Status: offline
What motor is everyone going with. Also has anyone tried these XYZ engines, I have heard they are little down on power but thats not going to be a problem if I use the 26cc one. I think it will still have plenty of go in it.
Hide Signatures
       Post #: 48
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/10/2009 12:25 PM
Zippi
Score: 134
Status: offline
quote:
ORIGINAL: dale691
I'm waiting on the new DLE 30cc to come in from RC Igintions.
Hide Signatures
       Post #: 49
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/10/2009 1:16 PM
gade600sdi
Score: 100
Status: offline
I'm using the Zenoah 26 cc gasser with electonic ignition.
Hide Signatures
(in reply to Zippi)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
10.875RCU1
