RE: It's here and Looks GOOD new Hangar 9 Taylorcraft
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
TRAILER TRANSPORT SYSTEM
Seller:  Sky Jack
Details:   $119.95   |  3/13/2010   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: It's here and Looks GOOD new Hangar 9 Taylorcraft
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/10/2009 9:34 PM
rob020880
Score: 106
Last Login: 2/28/2010
Status: offline
Do you think the DLE 30cc will fit in the cowl without cutting, except for the stacks, and carb of course. I am interested in this one but would hate to ruin the scale lines.
Hide Signatures
(in reply to gade600sdi)
       Post #: 51
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/11/2009 12:34 AM
Zippi
Score: 134
Last Login: 3/22/2010
Status: offline
quote:
ORIGINAL: rob020880
It's hard to tell but it's going to be close. From the center of the crank to the edge of the carb it's 3 9/16". The cowl is 8 1/2" at the back and about 8 1/8" up front. That leaves about 4 1/16" to 4 1/4". It also depends on how far down the cylinder is to the curve in the bottom edge of the cowl. I'm hoping for the best and expecting the worst .
_____________________________
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
Hide Signatures
(in reply to rob020880)
       Post #: 52
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/12/2009 1:34 AM
fabmaster911
Score: 100
Last Login: 3/19/2010
Status: offline
I'm going to go with a Webra Bully. 35cc's That is of course if I have prop clearance. She'll swing a 20 but 18 or 19 would work alright also.
Hide Signatures
(in reply to Zippi)
       Post #: 53
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/12/2009 12:37 PM
Zippi
Score: 134
Status: offline
quote:
ORIGINAL: fabmaster911
fabmaster911,
That Webra Bully sounds like a nice engine for the Taylorcraft. Using a 20" prop will probably leave you about an inch ground clearance. I had also thought about a three blade prop. I don't know if any of the full scale Taylorcrafts used a three blade prop or not.
Hide Signatures
(in reply to fabmaster911)
       Post #: 54
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/14/2009 2:32 AM
leedees
Score: 105
Last Login: 3/15/2010
Status: offline
On this Taylorcraft, the way the elevator servos are setup there's one servo per side with the servo control arms both facing inward. In order to make this setup work using a Y extension one of the servos has to be reversed. I can't figure out how to do this with my DX7.
Do any of you guys know how to do this?
Hide Signatures
(in reply to Zippi)
       Post #: 55
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/14/2009 6:20 PM
gade600sdi
Score: 100
Status: offline
In your old version, with the 160 fx how big was your tank, and how long could you fly on that tank?
Hide Signatures
(in reply to isaygen)
       Post #: 56
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/14/2009 9:18 PM
jmohn
Score: 105
Status: offline
Leedees,
You can use a Y with and inline reverser. The only problem will be making sure they are both moving together. I have a 9303 now and it's easy to mix two servos for the elevator. I can't remember if the DX7 can do this? On the 9303 you need to go into flight mode and turn off the switch the controls the servo (AUX2) and slave that to the elevator using a mix function. That will make them move together and also let's you use sub trim to make adjustments. I think the DX7 can do this too.
Jeff
Courage is what it takes to stand up and speak; courage is also what it takes to sit down and listen.
Hide Signatures
       Post #: 57
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/14/2009 9:41 PM
gade600sdi
Score: 100
Status: offline
Leedees, I use an reversing Y harness from Expert Electronics its $8 on the Horizon website. Works great and avoids problems with trying to figure out from your manual on your radio if you can mix and use another channel or not. Just like a regular Y harness but it reverses one of the servos.
Hide Signatures
(in reply to jmohn)
       Post #: 58
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/14/2009 9:56 PM
fabmaster911
Score: 100
Status: offline
Those servo reversers are no good. As the temperature varies so does the trim on your elevator. You'll end up readjusting it before every flight dang near. The JR matchboxes do work very well but they are higher priced. Try this out. I found it on FG.
I had no trouble with this. I mixed elevator to Aux 2, using pmix 5 or 6 (this allows trims to pass through) I then zeroed out the travel for Aux 2, then I went to the servo reversing reversed aux 2, then I went to the sub trim menu and sub trimed the servo.
I used the P mix amounts to match the throws, SW: on OFFSET: 0
My elevators match perfect
Hide Signatures
       Post #: 59
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/14/2009 10:04 PM
Les Nessman
Score: 100
Status: offline
The link below shows the servo reverser I use, and have not had any issues with it so far.
http://www.futabarc.com/radioaccys/futm4150.html -
If it''''s not broke, don''''t mess with it.
Hide Signatures
       Post #: 60
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/14/2009 10:47 PM
fabmaster911
Score: 100
Status: offline
I agree but that one is also $40 not $8 or $10. There is no reason for him to buy one anyway when his radio is capable of doing the mix.
Hide Signatures
(in reply to Les Nessman)
       Post #: 61
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 3:02 AM
JoeMamma
Score: 105
Last Login: 3/21/2010
Status: offline
Hi Guys,
If anybody is interested in adding more scale details, I have more pictures of the full-scale Taylorcraft used as a model by Hanger 9 about 8-9 years ago.
When I built my Taylorcraft, I was fortunate to get in contact with the (then) current owner, Harold Hanson. He graciously took some pics and mailed me a pile of 8x10 glossies.
Joe M.
Click to see fullsize image.
Click for fullsize
Joe Mamma
Hide Signatures
       Post #: 62
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 3:34 AM
fabmaster911
Score: 100
Status: offline
It just so happens that I found a Vinyl cutter that does excellent work and she smokes everybody on price. I'd love to see your pics. If anyone is interested i'll have her make several and we can all scale them out. I'd let them go for whatever she charges me.
Hide Signatures
(in reply to JoeMamma)
       Post #: 63
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 3:46 AM
JoeMamma
Score: 105
Status: offline
This is how I handled the dual elevator problem on my 9-year-old Hanger 9 Taylorcraft. I used a Central Hobbies bellcrank. One less servo to worry about.
Don't know if it will work on the new Hanger 9 Taylorcraft.
Joe M.
Click for fullsize
Click for fullsize
Joe Mamma
Hide Signatures
       Post #: 64
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 9:54 AM
dale691
Score: 100
Status: offline
Nice bellcrank setup.
Anyone thinking of using a saito FG-20?
Hide Signatures
       Post #: 65
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 12:08 PM
Zippi
Score: 134
Status: offline
fabmaster911,
I see a decal behind the cabin window and one on the vertical fin. Is that all there is or is there some hidden that I don't see?
Hide Signatures
       Post #: 66
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 1:25 PM
gade600sdi
Score: 100
Status: offline
Joemamma, the bellcrank looks nice, but with all that trouble just use another servo plus then you have more protection if one goes out you at least have one.
Hide Signatures
       Post #: 67
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 1:33 PM
gade600sdi
Score: 100
Status: offline
Fabmaster, I have used the reverser with no problems and no trim issues so far. I will watch it but not sure what you are concerned with but I will keep an eye on my trim.
As far as the radio option, I have a Futaba 6EX 2.4 and it does have the ability to use channel 2 as the master and 5 as the slave. I set it up last night and I did not end up using a reverser the manual on the Futaba does not show this but I emailed Futaba and they sent me back the procedure to do this using Premix 1 and Premix 2. Granted this is an entry level radio and does not have too many bells and whistles, but it can be done. The only drawback is you do not have a sub trim, so after flying if you trim, it will only affect one side (master) so after you land you need to manually match the other elevator side (slave) by rotating the clevis. This shouldn't be a problem once set up I dont adjust trims that much after the first couple flights.
I someday hope to get a JR 9303 that has more features than the Futaba, but for now for the money the Futaba 2.4s have been absolutely flawless as far as signal reception and performance for the money I have 3 of them and they work awesome.
Hide Signatures
       Post #: 68
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 1:36 PM
gade600sdi
Score: 100
Status: offline
Hey, did anybody actually finish this model yet and fly it? What motors are you using. I am second guessing the G26 I guess due to weight. I figure the wing loading at 31 with a G20ei and 33 with a G26ei. Is this a big differnece in wing loading? Will the G20 have enough power?
I am basically adding one pound of nose weight with the G26 vs. the G20. I am concerend this thing will be very nose heavy. With an extra pound up front, I will likely have to have 3-4 long sticks of lead on the tail? Will this thing be a tank when I am done?
Hide Signatures
       Post #: 69
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 1:42 PM
leedees
Score: 105
Status: offline
Hey guys, thanks for the many solutions to the dual servo elevator setup. I did finally get it sorted out by using Aux2 and mix 5 on the DX7. Seems to work perfectly.
One of the fellows on the forum sent me this link:
http://www.spektrumrc.com/Articles/Article.aspx?ArticleID=1798
Hide Signatures
       Post #: 70
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 1:43 PM
leedees
Score: 105
Status: offline
quote:
ORIGINAL: JoeMamma
Hi Guys,
Joe M.
Hide Signatures
       Post #: 71
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 1:45 PM
leedees
Score: 105
Status: offline
quote:
ORIGINAL: JoeMamma
Hi Guys,
Joe M.
Joe,
That's a great picture. I would really appreciate it if you would post post as many pictures as practical. I have looked everywhere on the web for pictures ot the full scale airplane. If anyone has web links with more information about he full scale plane that would be great.
Lee
Hide Signatures
       Post #: 72
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 1:52 PM
leedees
Score: 105
Status: offline
The build on my Taylorcraft is going smoothly. It's a dramatic looking, solid airplane that's built like a tank once you get all the struts bolted on.
One thing I have noticed is the 'functioning landing gear' suspension doesn't have any function that I can see.
There's a fairly heavy spring on the gear struts but the struts have no spring action at all. They seem to be solid as far as I can tell.
Am I missing something?
Hide Signatures
(in reply to leedees)
       Post #: 73
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 3:40 PM
fabmaster911
Score: 100
Status: offline
Zippi, the other guy said he has all those photos so we'll have to see what else there is for graphics. There has to be tail numbers and stuff I guess.
Hide Signatures
       Post #: 74
RE: It's here and Looks GOOD new Hangar 9 Taylorcraft - 9/15/2009 4:08 PM
gade600sdi
Score: 100
Status: offline
Leedees, did you check the squareness of the fin. I bolted mine together and its off a little bit like 1-2 degree from 90. There is no easy way to fix it at this point but wondering when I get to the tail struts if you can tighten the one side to square it up at that point. If not I will have to figure some way to shim it to square up the fin.
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.297RCU1
