IDLE UP & GYRO.SW    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> IDLE UP & GYRO.SW
Page: [1]
Login
IDLE UP & GYRO.SW - 8/31/2009 9:16 PM
qraphic
Score: 100
Last Login: 9/11/2009
Status: offline
I'm a beginner. Also i have Belt Cp v2 with ET6I Transmitter.
What's the position of IDLE UP Switch (N or 1) and GYRO.SW (0 or 1) for a normal fly.
Hide Signatures
       Post #: 1
RE: IDLE UP & GYRO.SW - 9/1/2009 4:58 AM
pgroom_68
Score: 100
Last Login: 11/15/2011
Status: offline
quote:
ORIGINAL: qraphic
Hey again Graphic,
If you are a newbie to flying - my advice is that a CP heli is a lot to handle straight out of the gate - it costs a lot of man-hours and $ to repair WHEN you crash! A FP (such as the Honeybee2 FP) would have been a better choice for an absolute beginner. It teaches you HOW to handle orientation changes and throttle control. Then, when you do graduate to a CP it doesn't take very long to adapt! If I have got it wrong, I apologize in advance.
To answer your question (well I can answer half anyway) the IDLE UP switch (as you have probably guessed by now ) should be at N for normal when flying rightway up - the only time that I have used the "1" setting is when in inverted flight. DON'T FLICK IT BY ACCIDENT - the headspeed goes to near full throttle when the throttle stick is at it lowest point!
[What it is for is: when inverted, flicking this switch to "1" and moving the throttle to its mid-point gives (if you have set it up so) 0º pitch and as you vary the throttle stick around this mid-point it inputs more or less pitch (usually +10º - -5º) to vary your altitude. Essentially, it lets you vary the pitch angle of the blades - while keeping the headspeed the same high rpm]
As I don't have a Belt, I won't speculate on the GYRO switch settings - someone that owns one, please help us out here!
Peter
_____________________________
HK-450GT (Incognito Mosquito), DX6i (highly modded) ...check out www.RC450.com
Hide Signatures
(in reply to qraphic)
       Post #: 2
RE: IDLE UP & GYRO.SW - 9/1/2009 5:38 AM
erdnuckel2
Score: 100
Last Login: 12/17/2011
Status: offline
quote:
ORIGINAL: pgroom_68
... DON'T FLICK IT BY ACCIDENT - the headspeed goes to near full throttle when the throttle stick is at it lowest point!
Peter
Something that I already learned very painfully - my ONLY experience with the Belt up to now - which made me the lucky owner of a brand new gear, as I shredded the original one beyond recognition ...
Hide Signatures
(in reply to pgroom_68)
       Post #: 3
RE: IDLE UP & GYRO.SW - 9/5/2009 2:06 PM
wzak29
Score: 113
Last Login: 2/15/2011
Status: offline
quote:
ORIGINAL: qraphic
Not sure what the gyro switch is for but the manual says up is the normal position
According to my calculations the problem does not exist
Hide Signatures
       Post #: 4
RE: IDLE UP & GYRO.SW - 9/5/2009 5:09 PM
Blitzer Fan
Score: 100
Last Login: 8/20/2010
Status: offline
think it turns the gyro on and off(iv tried it before...cant even keep it up with it on the 1 slides around WAY to much then)
// Esky Belt CP V2 CopterX Head + Tail // Tamiya Stadium Blitzer // HPI Firestorm 10T //
Hide Signatures
(in reply to wzak29)
       Post #: 5
RE: IDLE UP & GYRO.SW - 9/9/2009 2:01 AM
gnd2
Score: 100
Last Login: 11/9/2011
Status: offline
It doesn't turn the gyro off. It's nearly impossible to hover without the gyro.
It actually switches the gyro between heading hold mode and rate mode. Heading hold is the more stable of the two (and probably what the manual refers to as "normal") so most people just fly in that mode all of the time.
Heading hold mode tries to keep the heli pointing in the same direction (unless you give it input). If wind or something turns the heli the gyro will keep correcting until the heli is pointed back in the original direction again.
Rate mode just tries to keep the heli from turning, without concern to the specific direction it's pointing. If wind turns the heli the gyro will correct only until it stops turning, regardless of what direction it ends up pointing.
To give you an example in flight, if you're hovering tail in and "slide" to the left using left cyclic, in HH mode the heli will continue to point in the same direction but in rate mode the tail will drift around until the nose is pointing to the left. In rate mode the tail follows a turn almost like an airplanes tail does, in HH mode you need to fly the tail with the rudder stick in a turn.
Esky Lama V4, Blade CP+, Esky Honey Bee King 2, Trex 450SE, Trex 600N
Hide Signatures
(in reply to Blitzer Fan)
       Post #: 6
RE: IDLE UP & GYRO.SW - 1/15/2012 1:27 AM
mossman77
Score: 100
Last Login: 6/6/2012
Status: offline
gnd2, so what is the normal switch position for the gyro?  Should it be set to 0 or 1 for us beginners?
Hide Signatures
(in reply to gnd2)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
