futaba 3PJ FM to PCM possible?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Radio Equipment >> futaba 3PJ FM to PCM possible?
Page: [1]
Login
futaba 3PJ FM to PCM possible? - 6/29/2003 11:39:21 AM
hpl
Status: offline
can i convert my 3PJ FM to PCM? does buying a new PCM module and receiver makes it? coz i noticed there's a setting in the transmitter of PPM>PCM.
       Post #: 1
futaba 3PJ FM to PCM possible? - 6/29/2003 3:29:43 PM
flatfour
Status: offline
No need for a "conversion" PCM is already built in.
First you need a PCM receiver. (R113iP is one model)
Then, in the menu you already found, change the setting to PCM.
After changing this, you need to turn the TX off then on before it takes effect.
The same crystals and module are used.
_____________________________
Jim in Chicagoland
(in reply to hpl)
       Post #: 2
futaba 3PJ FM to PCM possible? - 6/29/2003 8:48:52 PM
hpl
Status: offline
thanks.
but i got another question...
my module has the model number as FP-TJ-FM. since it finishes by FM, isn't that a FM module? or it is still as you said, i only need to change the receiver? and the crystals there's only one in my receiver side and not in my module. is that normal?
i'm quite new into this radio stuff...
(in reply to hpl)
       Post #: 3
futaba 3PJ FM to PCM possible? - 6/29/2003 10:26:16 PM
flatfour
Status: offline
PCM is also sent via FM. No module change needed.
There is a crystal in your module, you just cant see it.
Jim in Chicagoland
(in reply to hpl)
       Post #: 4
futaba 3PJ FM to PCM possible? - 7/2/2003 9:27:28 AM
Kuma
Status: offline
My father's 3PJ is so sick, I kept offering to buy it off him and he refuses. I'm sure it has PCM since I don't recall seeing a crystal on it and he uses it on two of his elec cars and nitro truck. That radio is so much nicer than my newly obtained 3PDF.
- OFNA Hyper 7 / Hyper 21 8P (soon RB WS7-II)
- HPI RS4 Nitro MT / Sirio SP12TRP (2-speed)
(in reply to hpl)
       Post #: 5
futaba 3PJ FM to PCM possible? - 7/2/2003 7:26:46 PM
flatfour
Status: offline
[QUOTE]I'm sure it has PCM since I don't recall seeing a crystal [/QUOTE]
The FM and PCM radios use the exact same crystal. It is inside the TJ module.
Jim in Chicagoland
(in reply to hpl)
       Post #: 6
RE: futaba 3PJ FM to PCM possible? - 8/8/2005 7:15:48 PM
jr1414
Status: offline
So, do I understand correctly that by changing that setting, we can use the 3PJ with any synthesized receiver?
(in reply to hpl)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU3
