RE: Great Planes Sequence F3A    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Great Planes Sequence F3A
Page: <<   < prev  2 3 4 5 6 7 8 9 [10] 11   next >   >>
Login
RE: Great Planes Sequence F3A - 11/30/2012 3:41 AM
Flyer88
Score: 100
Last Login: 5/9/2013
Status: offline
I know the motor is predrilled for their Rimfire 32 which compared to some Turnigys' is kind of expensive. And there's not much room for other motors to fit without the spinner sitting away from the cowl.
But it is a good motor. No problems so far...and lots of power.
I was hoping to run a Turnigy 42/50/700kv or 650kv cause I have a few kicking around. They are bulletproof motors , great success with those also.
Ive been pulling 1500 watts on 5s out of one of the 700kv motors with no problems and well over 150 flights on my Extra300.
_____________________________
Why is there never enough time to do it right, but always enough time to do it over ?
Hide Signatures
(in reply to jeffk464)
       Post #: 226
RE: Great Planes Sequence F3A - 11/30/2012 3:45 AM
Flyer88
Score: 100
Status: offline
Thanks !!
Easy peasy !! Silver Met Spray bomb
Hide Signatures
(in reply to JSchoolcraft)
       Post #: 227
RE: Great Planes Sequence F3A - 11/30/2012 4:09 AM
69 roadrunner
Score: 100
Last Login: 5/1/2013
Status: offline
Iam telling you guys I put a efligh 46 with 5cell had to red rill but it fit and the cowl clears you cant beat the price or the power pulls strait up unlimited power. Now if I could just fly a decent pattern I fuss I will just have to keep trying. On a diff note anyone know anything about the great planes 6.5 flight simulator. I have the g4.5 and expansion pack 5 and 6 the 6.5 just came out looks good but dont know. steve
Hide Signatures
(in reply to Flyer88)
       Post #: 228
RE: Great Planes Sequence F3A - 11/30/2012 2:06 PM
JSchoolcraft
Score: 100
Last Login: 5/22/2013
Status: offline
Yeah, I just ended up buying the Rimfire .32. Here are some photos of the canopy screw I made. Kind of overkill, but wanted to make it easy to install and remove for my son without tools:
Hide Signatures
(in reply to 69 roadrunner)
       Post #: 229
RE: Great Planes Sequence F3A - 11/30/2012 2:10 PM
JSchoolcraft
Score: 100
Status: offline
I apologize for the HUGE photos.  First time using my iPad and Photobucket to post photos.
Hide Signatures
       Post #: 230
RE: Great Planes Sequence F3A - 11/30/2012 2:19 PM
Flyer88
Score: 100
Status: offline
Why so big ???
Hide Signatures
       Post #: 231
RE: Great Planes Sequence F3A - 11/30/2012 2:35 PM
JSchoolcraft
Score: 100
Status: offline
Made it that size so it's easy on the fingers when screwing it in and out.  I'm gonna make a smaller one, just haven't had the time the last few days.  It's a dubro 10-32 wing bolt, and wooden pre-threaded block underneath.  I used epoxy putty around the head to make it like a thumb screw and got carried away.....LOL
Hide Signatures
       Post #: 232
RE: Great Planes Sequence F3A - 11/30/2012 6:01 PM
picard1
Score: 100
Last Login: 5/21/2013
Status: offline
69Roadrunner,
The key to flying a good pattern is lots of practice!!! Oh yea, it helps if your retired and can spend 10-20 hours a week practicing LOL!!
By the way, love the field you guys fly at.. Nice long runway. Wish I could be a member there....
Hide Signatures
       Post #: 233
RE: Great Planes Sequence F3A - 11/30/2012 8:09 PM
69 roadrunner
Score: 100
Status: offline
You where at on time but you stood us up when you ran of with that woman. Iam telling you there nothing but trouble you will see
Hide Signatures
(in reply to picard1)
       Post #: 234
RE: Great Planes Sequence F3A - 11/30/2012 8:16 PM
kochj
Score: 143
Status: offline
Does the canopy have double magnets?? Or 1-magnet attaching to a washer?
If you place one magnet on each side, and or use larger ones....There is not way that canopy will come off...
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
       Post #: 235
RE: Great Planes Sequence F3A - 12/2/2012 5:26 PM
Flyer88
Score: 100
Status: offline
Disagree.
Have had many canopies come off with the use of magnets including a cowl. I always set a screw in the canopy now or put a canopy latch.
Hide Signatures
(in reply to kochj)
       Post #: 236
RE: Great Planes Sequence F3A - 12/2/2012 6:13 PM
abbydawn
Score: 100
Last Login: 2/19/2013
Status: offline
The magnets will hold until the first time you fail to lock in the canopy to the fusealage. Happened twice to me probably through distraction. I now use a screw at the top rear of the canopy. Also I use a bit of tape on either side of the cowl down low.
I'm on my 3rd Sequence. First one lost to an inverted low pass. Learned that down is up when coming out of it over a corn field. Almost cleared it though for an inversed loop. Second one spiralled into the top of a 60 foot tree, never did establish what failed. Chainsawed the tree into 5 peices as it kept hanging up on adjacent trees in a thickly treed forest.
Hide Signatures
       Post #: 237
RE: Great Planes Sequence F3A - 12/2/2012 6:23 PM
plaurence
Score: 100
Status: offline
Flew my Sequence for the first time yesterday. My first pattern airplane. Winds were a direct crosswind at 10 to 15mph
Need some help.
The plane felw nose heavy within the recommended cg envelope. Had to place the battery as far back on the tray as possible and then added a little weight at he tail. It flew better. However, when I powered back slightly, the nose still dropped more than what i think it should have.Inverted need lots of up elevator.
This is my first pattern plane. I,ve been flying a .60 size revolver with a DLE 20. It no bad habits.
Any help on those is appreciated.
Hide Signatures
       Post #: 238
RE: Great Planes Sequence F3A - 12/2/2012 7:01 PM
Flyer88
Score: 100
Status: offline
I believe this plane has an incidence problem which causes it to pitch with the nosedown.
I checked the incidences and came up with some really weird numbers.
I believe a set of incidence adjusters on the main wing would really help.
For what it's worth I just posted a link on incidence adjusters from Hobby King
Hide Signatures
(in reply to plaurence)
       Post #: 239
RE: Great Planes Sequence F3A - 12/3/2012 2:55 AM
plaurence
Score: 100
Status: offline
quote:
ORIGINAL: Flyer88
Thanks. I'll give them. Look
Hide Signatures
       Post #: 240
RE: Great Planes Sequence F3A - 12/5/2012 6:55 AM
AWorrest
Score: 115
Status: offline
I have a question for those Sequence owners who are using the Rimfire 32 motor. I flew my Sequence for the first time yesterday and this is my first experience with the Rimfire motor. There is a high pitch whine apart from the prop noise. I’ve used the same APC 12x8 prop on my Vanquish and it’s not this noisy. I almost suspect there may be a bearing problem. Have others experience this?
Allan
Hide Signatures
       Post #: 241
RE: Great Planes Sequence F3A - 12/5/2012 2:55 PM
69 roadrunner
Score: 100
Status: offline
I have used several rimfire motors they are alittle noisey. I have also had a few just lock up on first flight not my motor of chose. Good luck Steve
Hide Signatures
(in reply to AWorrest)
       Post #: 242
RE: Great Planes Sequence F3A - 12/5/2012 4:18 PM
abbydawn
Score: 100
Status: offline
quote:
ORIGINAL: 69 roadrunner
Not my choice either, worse is the Silver 7 ESC which comes with the Sequence if ordered RTF. Arming the ESC is rather scary for some as you have your TX at full throttle in doing so. Many forget how to arm them thinking something is wrong and then need help.
Hide Signatures
       Post #: 243
RE: Great Planes Sequence F3A - 12/5/2012 5:16 PM
plaurence
Score: 100
Status: offline
My rimfire seems to sound normal. Plenty of power for this plane.
Hide Signatures
(in reply to abbydawn)
       Post #: 244
RE: Great Planes Sequence F3A - 12/5/2012 9:35 PM
JSchoolcraft
Score: 100
Status: offline
Well Flyer88 you seem to be spot on with the incidence problem.  I think I'm gonna be ordering some of those adjusters today!!
Hide Signatures
       Post #: 245
RE: Great Planes Sequence F3A - 12/5/2012 11:34 PM
Flyer88
Score: 100
Status: offline
Yes I thought the numbers were way out. What numbers did you get ??
Hide Signatures
       Post #: 246
RE: Great Planes Sequence F3A - 12/6/2012 2:26 AM
Bob Pastorello
Score: 126
Status: offline
quote:
ORIGINAL: JSchoolcraft
Couple things - 1) Link for the adjusters?   2)  How do you handle incidence change on the wing with the inset fuse recess for the root rib?
It really shouldn''t be this hard....
Hide Signatures
       Post #: 247
RE: Great Planes Sequence F3A - 12/6/2012 2:30 AM
Bob Pastorello
Score: 126
Status: offline
quote:
ORIGINAL: AWorrest
Allan
Allan - I use that Rimfire, been on three planes (two crashes), no noises and plenty of poop on a good 4S.  I did find running a 13.5 x 6 is a really good prop, doesn't go too fast, pulls on dead corners pretty well - but at wide open it is very close to max amps on the RImfire, so I upped the ESC to a 80 A, just to be sure it wouldn't ever cook.  Max I ever measure with a fresh charge is about 65A, so I wanted some overhead capacity in the ESC.
I also am using a pretty rapid spool up throttle curve, so the low end has some guts to it...
Hide Signatures
       Post #: 248
RE: Great Planes Sequence F3A - 12/6/2012 2:48 AM
Flyer88
Score: 100
Status: offline
This plane requires some carving out .....setting the incidence ....then gluing in a ply doughnut.
But then again, if you have the patience to get it done....adjusters can be done !
Hide Signatures
(in reply to Bob Pastorello)
       Post #: 249
RE: Great Planes Sequence F3A - 12/6/2012 3:43 AM
Flyer88
Score: 100
Status: offline
Canopy set screw
Rib removed for battery access and set screws for cowl.
Hide Signatures
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
