Orcinus
Joined: 6/19/2003 From: Edmonton, AB, CANADA Status: offline
well, I've only had my Wild Dagger for about a month actually, and don't have much time lately to go looking for stuff to climb. Found one place that has large hills, but it's all loose topsoil. Even a T-Maxx has trouble getting to the top... And I was running the stock suspension until just a couple days ago when my new shock towers came in, so it didn't have a lot of ground clearance. I would get high-centered frequently when trying to climb rough hills. If you have a Wild Dagger, I really recommend getting shock towers that will allow you to mount some 4 inch shocks instead of the "shocks" that come with the truck (which are nothing more than a steel spring and some rubber tubing for "damping" [yeah right]). I haven't had a chance to run with the new suspension yet, but I'm going camping this weekend in the mountains and there should be plenty of solid hills to climb, I'll let you know how the motors perform. As for top speed, it's a couple miles per hour faster than a stock electric Stampede, but the accelleration is MUCH better. I can get to top speed in less than 1 second. The Stampede takes 3 or 4 seconds to reach top speed. I can't really say what my runtime is right now, because I just got a couple Sanyo 3300's, and my driving since then has been interrupted by one thing or another. Again, I'll let you know once I get some good runs in.
