RE: Skymaster ARF Plus 1:5 scale F-104G    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Skymaster ARF Plus 1:5 scale F-104G
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Skymaster ARF Plus 1:5 scale F-104G - 3/16/2012 2:20 PM
757Driver
Score: 100
Last Login: 5/21/2013
Status: offline
Please don't release it until its got all the issues worked out and the details completed.
< Message edited by 757Driver -- 4/6/2012 1:03 AM >
_____________________________
Thanks, Jason
I love it when my airplane is on fire...as long as the fire stays inside the engine!
Hide Signatures
(in reply to pilot tw)
       Post #: 101
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/3/2012 4:52 PM
pilot tw
Score: 103
Status: offline
Hi, all
here is Video for the second prototype of F-104 maiden flight, we make strong contruction for the slat , now dry weight 18.5kg included speed brake with all gear doors. Powered by K-170,
http://youtu.be/fysPmb_C9IU
http://youtu.be/fz_QM0WDC60
Best Regards
Anton
owner - Skymaster Jet
X-Treme Jets
Hide Signatures
       Post #: 102
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/3/2012 6:15 PM
jetpilot
Score: 110
Status: offline
Did you not retract the gear?
Why?
Scott
Scott C. Marr
Hide Signatures
       Post #: 103
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/3/2012 7:12 PM
pilot tw
Score: 103
Status: offline
quote:
ORIGINAL: jetpilot
Why?
Scott
yes, retracted the L/G and closed the all gear doors in the sky,
X-Treme Jets
Hide Signatures
(in reply to jetpilot)
       Post #: 104
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/3/2012 8:16 PM
David Searles
Score: 115
Status: offline
Anton,
Doesn't it make sense, that if you're going to post videos of aircraft in development, for marketing reasons, that SkyMaster make an investment in a higher quality video camera?! I am very interested in this model, but the quality of the video is very disappointing.
Congrats on the successful flight!
David S
Hide Signatures
       Post #: 105
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/3/2012 9:17 PM
jetpilot
Score: 110
Status: offline
Me as well.
How about less 80mph 2 minute flights and more 200mph 8 minute flights with rolls and loops?
the video quality and test flying style is tiresome.
Scott
Scott C. Marr
Hide Signatures
(in reply to David Searles)
       Post #: 106
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/3/2012 10:37 PM
David Searles
Score: 115
Status: offline
quote:
ORIGINAL: jetpilot
Me as well.
Scott
Agreed. Please also test this aircraft with a 200 class turbine, as that is most likely what the majority of these jets will be powered with in the field. I'd like to know that the structure can handle the stress of a more powerful turbine than the 170.
David S
Hide Signatures
       Post #: 107
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/3/2012 11:35 PM
Springbok Flyer
Score: 100
Status: offline
Anton,
How much throttle we're you using during that flight? The ground handling is certainly better now, but it is still sitting too low at the front. Is it possible to get the nose a bit higher?
Could you please post some photo's showing all the hatches you have on the jet - it will be good to know how much working space and also installation space there is.
Thanks for sharing your developments with us, it certainly is a lot more than most other manufacturers will do.
Cheers,
Jan
''''It is always pilot error.''''
Hide Signatures
       Post #: 108
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/4/2012 3:22 AM
pilot tw
Score: 103
Status: offline
Hi, all
Thank you for your suggested,
That poor weather conditions and air pollution seriously I almost lost the F-104, because i can not see it in the sky well, some time i want to guess aircraft posture, Fly less than 200 meters is almost unknown aircraft position even the camera could not capture it,
Flying through the air when I had used the 2/3 to 3/4 thrust,
I will be flying again after the F-104 painted, this time only test the slat for take off and landing,
Best regards
Anton
X-Treme Jets
Hide Signatures
(in reply to Springbok Flyer)
       Post #: 109
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/4/2012 3:30 AM
pilot tw
Score: 103
Status: offline
quote:
ORIGINAL: Springbok Flyer
Anton,
Cheers,
Jan
yes, we put the too much air in the hydrupic main Oleo legs , the Main Oleolegs little hard and nose oleo leg little soft , i will suggest to Likai about the nose weight and dry weight for adjust the air inside,
i will post some pictures here, Thank you,
Best regards
Anton
X-Treme Jets
Hide Signatures
       Post #: 110
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/5/2012 8:25 AM
etibedossa
Score: 100
Status: offline
Hello Anton,
Congratulations for your superb F104.Do you have gyros on the flight controls ? are they necessary ?
Best regards and see you at next JetPower.Etienne.
Hide Signatures
       Post #: 111
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/5/2012 4:55 PM
jetpilot
Score: 110
Status: offline
I suspect what happened in Florida was a gyro going haywire.
Scott
Scott C. Marr
Hide Signatures
(in reply to etibedossa)
       Post #: 112
RE: Skymaster ARF Plus 1:5 scale F-104G - 4/6/2012 3:49 AM
jet time
Score: 120
Last Login: 5/20/2013
Status: offline
Nice looking bird... Great detail. Looking forward to seeing it in person.
Lowell Wexler
RC Jets Direct, Fly Eagle, Global Jet Club, Jet Cat
Hide Signatures
       Post #: 113
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/9/2012 10:36 PM
PDR200
Score: 100
Status: online
Hi Anton,
Any updates on the production F104 ??
Could we see some more photos, Hatches, Engine bay and Tailplane drive system???
Paul.
Hide Signatures
       Post #: 114
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/10/2012 4:40 AM
pilot tw
Score: 103
Status: offline
quote:
ORIGINAL: PDR200
Hi Anton,
Paul.
my F-104 now installing the servos with turbine, here are same pictures....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
X-Treme Jets
Hide Signatures
(in reply to PDR200)
       Post #: 115
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/10/2012 9:56 AM
Springbok Flyer
Score: 100
Status: offline
Anton,
Very nice. But don't you think that you will loose some cooling around the jet pipe with the exhaust setup. Can't see that too well, please take a photo from the back to show us how you are mounting the exhaust nozzle. It will also be good to see th nose section closer.
Regards,
Jan
Hide Signatures
       Post #: 116
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/10/2012 11:23 AM
pilot tw
Score: 103
Status: offline
Anton,
Regards,
Jan
we made the super scale detail for the inner of nozzle. and before paint job, i already test flight this F-104 , no problem for the cooling air,, this will make more scale nozzle for F-104,
when i test fly this F-104 again, i will note the temp of tailcone, TKS for suggested.,
Click for fullsize
Click for fullsize
Click for fullsize
X-Treme Jets
Hide Signatures
       Post #: 117
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/10/2012 11:28 AM
pilot tw
Score: 103
Status: offline
i just found the pic of nozzle , i think my paint factory did the wrong color, i want to ask them repaint the nozzle again !!
Click for fullsize
X-Treme Jets
Hide Signatures
       Post #: 118
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/11/2012 5:05 AM
757Driver
Score: 100
Status: offline
I think the black is more accurate. Someone scrubbed that one clean and the flash tends to brighten and wash out colors.
Thanks, Jason
Hide Signatures
       Post #: 119
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/19/2012 3:14 PM
pilot tw
Score: 103
Status: offline
Hi, all
my new F-104G finished the paint job, and we made the speed brake and openning canopy,
http://youtu.be/XRVAfxWo8fs
Best regards
Anton
X-Treme Jets
Hide Signatures
(in reply to 757Driver)
       Post #: 120
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/19/2012 3:32 PM
PDR200
Score: 100
Status: online
Hi Anton,
Is there a removable nose cone on the F-104?
I think I can see on the video.
Cheers,
Paul
Hide Signatures
       Post #: 121
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/19/2012 3:54 PM
pilot tw
Score: 103
Status: offline
test flight Video: http://youtu.be/4Y3BL4GlGZw
X-Treme Jets
Hide Signatures
       Post #: 122
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/19/2012 4:02 PM
pilot tw
Score: 103
Status: offline
quote:
ORIGINAL: PDR200
Hi Anton,
Cheers,
Paul
yes, but i now has problem with internet for upload the pictures, please wait a few hour that i will try upload again.
X-Treme Jets
Hide Signatures
       Post #: 123
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/19/2012 4:08 PM
PDR200
Score: 100
Status: online
Great Video Anton!!!!!!
What is the finished weight? and in this video what engine did you use? (how much thrust?)
Cheers,
Paul.
Hide Signatures
       Post #: 124
RE: Skymaster ARF Plus 1:5 scale F-104G - 5/19/2012 4:17 PM
pilot tw
Score: 103
Status: offline
quote:
ORIGINAL: PDR200
Cheers,
Paul.
dry weight 19.5kg powered by K170
X-Treme Jets
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
