RE: ASM F-7F Tigercat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: ASM F-7F Tigercat
Page: <<   < prev  17 18 19 20 21 22 23 24 25 [26]
Login
RE: ASM F-7F Tigercat - 12/17/2012 12:41 PM
wathoshebumps
Score: 100
Last Login: 4/27/2013
Status: offline
Thanks for your comments Brad. The tail dragger idea is based on the concept that the Wellington bomber was a tail dragger with a single fin. I'm not sure if a single fin would have enough steering authority at ground handling speed on a model. I won't rush into it unless I am satisfied !!
Hide Signatures
(in reply to Brad330l)
       Post #: 626
RE: ASM F-7F Tigercat - 12/17/2012 1:01 PM
Staggerflyer
Score: 100
Last Login: 5/15/2013
Status: offline
The Wellington Bomber had a completely different wing position and cg/main gear mounting position. Also, as a model design, this model does not have the internal structure needed to support a taildragger design. Any weight added to the tail to allow this change would require large amounts of weight in the nose to compensate.
I have done tail dragger conversions on other aircraft, but those were sport/GA style aircraft, where the structure and basic design allowed for it, including room for the main gear to be moved forward of the cg, as well as supporting structure in the fuselage/tail section. This model has none of that.
Good luck.
Don
Hide Signatures
(in reply to wathoshebumps)
       Post #: 627
RE: ASM F-7F Tigercat - 12/17/2012 1:37 PM
wathoshebumps
Score: 100
Status: offline
Thanks Don. I included the preference for a tail dragger design to see if I got any feedback. Your comment about the strength and weight at the rear end of this model is a major consideration.
Hide Signatures
       Post #: 628
RE: ASM F-7F Tigercat - 12/17/2012 6:02 PM
Staggerflyer
Score: 100
Status: offline
Welcome. I hope you don't think I was trying to stop innovation, far from it. I love taildraggers myself. In fact, this aircraft is one of only two trike geared aircraft in my present flying inventory, which totals 14, plus two mini copters.
Even with the structural repairs/strengthening we've done throughout this thread, the tail section is still extremely weak, as there is no continuous framework inside. The skin is literally all that holds the tail where it is. I keep my manuevers big and open to keep the "G" stresses low on the tail, for this reason. I believe it is weak enough that a hard elevator pull/push at speed would rip the whole tail section off the fuse, right behind the wing. Some of those stresses occur just in taxiing a taildragger on rough ground.
Your other ideas sound great. Because of your conditions, if you follow the strengthening suggestions in this thread, before the first flight, you should be able to really enjoy this aircraft. One thing I would suggest, as you intend to go with fixed gear, is leave all the gear doors off, or better yet, glue them in the closed position.
Enjoy
Don
I might add, that as you are going with the fixed gear option, which does not have the shock absorbing oleos that are available with the retracts, you may find a lot more sresses in taxiing. so keep a close eye on the structure, especially after any hard landing. There are more and more add-on oleos becoming/already available. Maybe something to look into?? The beautiful "greased" landings you see in the videos posting are 95% the effect of these oleos we (the other pilots on this thread) have on our models. I have made a few landings that would have resulted in major relaunches back into the air if I had standard fixed gear, but looked real good with little or no bounce because of these oleos. Just a suggestion.
Hide Signatures
       Post #: 629
RE: ASM F-7F Tigercat - 12/17/2012 6:26 PM
wathoshebumps
Score: 100
Status: offline
Your reasoning is good Don. I've just been studying the threads on strengthening  the fuselage and I can see what you mean !! I'll concentrate on sourcing some good glue for now.
Hide Signatures
       Post #: 630
RE: ASM F-7F Tigercat - 12/17/2012 6:39 PM
Staggerflyer
Score: 100
Status: offline
quote:
ORIGINAL: wathoshebumps
If you come up with some better ideas, or additional ones, be sure and post them. We can use all the help we can get.
Hide Signatures
       Post #: 631
RE: ASM F-7F Tigercat - 12/19/2012 12:01 AM
wathoshebumps
Score: 100
Status: offline
My ASM Tigercat arrived today and a brief inspection of the fuselage shows that the glued joints between the wood and the ABS skin are pretty good. The wood to wood joints are quite good with some missed areas. Overall the build quality is quite good for an ARTF but I get  the impression of a very light construction for a plane of this size. So the first target is to get some more strength into it without significant weight increase - which requires a lot of thought.
 I've located a glue supplier who says they can supply some glue which sticks ABS to wood and fibreglass so I said I would order a small quantity and run some tests. The Dragon lady on the other end of the phone said I don't need to because they have already tested it and it works!  Time will tell .
It will be New Year before I make any further progress. Happy Christmas to all.
Hide Signatures
(in reply to Staggerflyer)
       Post #: 632
RE: ASM F-7F Tigercat - 1/26/2013 4:46 AM
wathoshebumps
Score: 100
Status: offline
After studying all 26 pages of this subject it stands out that the joint between the tail and the fuselage on the Tigercat is weak. On the full size aircraft the hatch over the wing is part of the main structure, whereas on the model the hatch provides no strength at all. Therefore I decided the change this by making the hatch cover part of the structure. I have run a 4mm dia carbon fibre tube almost the full length of the fuselage as high up as possible, attached to the skin with flexicyano glue ( from 5 star adhesives ) - . The hatch cover has been strengthened with 10mm x 3mm spruce and the whole structure is connected by bolt on wooden plates. The front plates are completely removable to allow the wings to be removed.
The plan is that this will increase the overall strength of the joint between the tail section and the main fuselage. Apart from this I have only added flexicyano to any badly glued joints - The overall weight increase is 30 grams. I will add some strength in the area of the nose wheel attachment but basically my thinking is that adding more general strengthening will encourage the ABS fuselage to shatter on impact .
The landing gear is to be " own design" and I have downgraded my engine spec to ASP 75 two stroke glow converted to Rcexl ignition ( like all my other glow engines ) to minimise vibration.
I will have to study how to add pictures as I've failed at this time !
Hide Signatures
       Post #: 633
RE: ASM F-7F Tigercat - 4/18/2013 4:46 PM
elojim
Score: 100
Last Login: 4/19/2013
Status: offline
Hi all,
Iam pleased to send you this video. This is the second flight of my Cat. http://youtu.be/kc1B1LQ4TvE
Thank you to all the contributors on this forum who have helped me to improve the construction of my plane.
Do not hesitate to contact me if you would like information on the sliding glass (show on the video).
Elojim
Hide Signatures
       Post #: 634
RE: ASM F-7F Tigercat - 4/18/2013 5:10 PM
Staggerflyer
Score: 100
Status: offline
Very nice. Excellent camera work too. I like the slow motion for the landing. Love how the struts work on damping the bumps!
Thanks for sharing.
Sliding canopy very nice!
Don
Oh, good airmanship on the sticks, too.
Hide Signatures
(in reply to elojim)
       Post #: 635
RE: ASM F-7F Tigercat - 4/18/2013 6:14 PM
Rocketman_
Score: 110
Last Login: 5/25/2013
Status: offline
Sounds like a video worth watching but I'm in Hawaii for 3 weeks with just a tablet on wi–fi and no PC. I tried to watch it but You Tube sald "the owner has not made this video available on mobile".
_____________________________
NORTHEAST R/C MODEL CLUB
http://www.nrcmc.org/
Hide Signatures
       Post #: 636
RE: ASM F-7F Tigercat - 4/18/2013 7:13 PM
Lebus1
Score: 100
Last Login: 4/24/2013
Status: offline
I have fixed gear and would like to install the robart straight and offset struts . The wire size is 5mn for the mains and 4mn for the nose gear. What size would I need?
Nothing Runs Like a Deere
Hide Signatures
(in reply to Rocketman_)
       Post #: 637
RE: ASM F-7F Tigercat - 4/18/2013 7:45 PM
Staggerflyer
Score: 100
Status: offline
quote:
ORIGINAL: Lebus1
The Robarts come with an insert to fit the strut. If I remember correctly, both sizes are in the package. If not, they can be drilled to fit. I had to drill mine on my P-40. Order them to fit the plane first, then strut size. Since they do not come as a set, but rather individually, and if they also list strut size, in each class, (my memory failing me at the moment,) then order them that way.
They are worth every penny. I always thought they were to expensive, but after using them on one plane, I've pinched the pennies to afford them for two more. They really soak up the bumps and protect the airframe on rough fields. And, they really make your landings look better!!
Don
Hide Signatures
(in reply to Lebus1)
       Post #: 638
RE: ASM F-7F Tigercat - 4/18/2013 8:06 PM
Lebus1
Score: 100
Status: offline
Thats what I need. Some help in the survive the landing area.
Hide Signatures
       Post #: 639
RE: ASM F-7F Tigercat - 4/18/2013 8:16 PM
Staggerflyer
Score: 100
Status: offline
Just went and measured mine. I have the ASM retracts and strut kits on mine. (BTW, Hobby People still have the retracts available, for $199.00, but, as far as I can tell, no strut kits. Thinking about ordering a set myself as spares.) The struts are 0.47 nose and 0.48 mains, so you want to get the 1/2" Robart struts, which are rated 18-25 lbs, which is correct for this plane. Get 1 each straight for the mains. The axle can be mounted either way for left and right. For the nose, you want an offset one. Measure your wheel, and get the one that fits. Or, you can order a complete steerable nose gear strut assy with nose mounting block. Hope that helps.
Don
Hide Signatures
       Post #: 640
RE: ASM F-7F Tigercat - 4/18/2013 8:19 PM
Lebus1
Score: 100
Status: offline
Thanks. I want to get this plane in the air more this year and enhancing the landing gear will help. DB
Hide Signatures
       Post #: 641
RE: ASM F-7F Tigercat - 4/19/2013 11:18 AM
elojim
Score: 100
Status: offline
Hi,
thank you pour your comment.
Indeed, slow motion lets see how the aircraft landed. How the struts work is very instructive !
Elojim
Hide Signatures
       Post #: 642
RE: ASM F-7F Tigercat - 5/5/2013 8:40 AM
Brad330l
Score: 140
Status: offline
Seven more excellent flights with the Cat under my belt. I have been a bit quiet lately in the way of flying but I know I can drag the Cat out and go fly it any time.
Still loving it and I even had helicopter guys applaud my last landing.
Cheers,
Brad
Visit pilbaraaeromodellers.com
Spitfire Brotherhood # 5
Hide Signatures
       Post #: 643
RE: ASM F-7F Tigercat - 5/6/2013 12:22 AM
Rocketman_
Score: 110
Status: offline
quote:
ORIGINAL: elojim
Hi all,
Iam pleased to send you this video. This is the second flight of my Cat. http://youtu.be/kc1B1LQ4TvE ...
Elojim,
Back from a 3-week vacation and I'm now able to see your F7F video on my PC. That was a good show especially with the sliding canopy and smooth landing. It appears that you did not use the flaps for takeoff and landing and the plane performed very well without them. I used the flaps once for a takeoff and the plane leaped into the air after a very short run from a paved runway. I never used them again for takeoff or landing.
Can you tell me the title of the song that played during your flight and name of the artist?
Brad,
It is good to hear that you're still trying to wear out you Tigercat with all of that flying.
Hide Signatures
       Post #: 644
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
