RE: Custom Piston Rings    Gallery
Logged in as Guest
    Search This Thread
Printable Version
O.S. Engines O.S. FT-300 Twin
Seller:  thunderbolt-RCU
Details:   $600.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Custom Piston Rings
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: Custom Piston Rings - 4/22/2011 4:07 AM  1 votes
the Wasp
Score: 110
Last Login: 5/19/2013
Status: offline
thank you Frank !!,, on thing,, while Honing should we Lube the Liner, if yes, what should we use ?? (2 stroke oil, motor oil, WD)???
thanks again !!
Jim
Hide Signatures
(in reply to Frank C. Bowman)
       Post #: 151
RE: Custom Piston Rings - 4/22/2011 5:23 PM  1 votes
Frank C. Bowman
Score: 140
Last Login: 11/1/2012
Status: offline
Lite oil WD fine, Karosene, etc. Take care, Frank
_____________________________
Frank C. Bowman
Hide Signatures
(in reply to the Wasp)
       Post #: 152
RE: Custom Piston Rings - 12/2/2011 1:17 AM
captinjohn
Score: 247
Last Login: 5/20/2013
Status: offline
Frank....I am going to call you soon.      Thanks  Capt,n
I never met a engine I did not like !
Hide Signatures
       Post #: 153
RE: Custom Piston Rings - 12/4/2011 4:46 AM
captinjohn
Score: 247
Status: offline
I put a Frank Bowman piston ring in a SuperTiger .75 engine and I broke my favorite prop, so I put a 14x8 prop on the .75 and to my surprize it turned it real good. I have the engine on a Funtana 100X. It flew good! Also I am sure that the engine with the Bowman ring is much better on glow fuel! Capt,n    PS   Frank...some photos!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to captinjohn)
       Post #: 154
RE: Custom Piston Rings - 12/4/2011 1:24 PM
Frank C. Bowman
Score: 140
Status: offline
I did have to raise my price on rings I make due to increases in cast iron, tooling, and shipping. The price list is listed below. I also made a mistake in last posting, I heat treat rings to 1,850 degrees F. not 850 degrees F. Thanks to all and have a Merry Christmas. Frank Bowman
Standard Rings up to .29 = $9.00 ea. USD
" " .30 - .65 = $10.00 ea. "
" " .66 - 1.999" bore = $11.00 ea. USD
" " 2.0" - 2.999" bore = $12.00 ea. USD
Dykes Ring up to .29 = $10.00 ea. USD
" " .30 - .65 = $11.00 ea. USD
" " .66 - 1.999" bore = $12.00 ea. USD
" " 2.0" - 2.999" bore = $13.00 ea. USD
Frank C. Bowman
Hide Signatures
       Post #: 155
RE: Custom Piston Rings - 12/5/2011 2:26 PM
captinjohn
Score: 247
Status: offline
That is still a real good deal when you compare it to the price of about anything RC or even a small bag of food products at a nearby store.  Best Regards    Capt,n
Hide Signatures
       Post #: 156
RE: Custom Piston Rings - 12/21/2011 12:12 PM
Hobbsy
Score: 650
Status: offline
Frank, I'd like to contact you for a ring for a Webra .91 and a SuperTigre 4500 pinned. Could you post you contact info one more time and I'll save it Thanks, Dave
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 157
RE: Custom Piston Rings - 12/21/2011 12:45 PM
wattmeter
Score: 110
Status: offline
his Contact is on the first post of this forum.
When You Go Up You Have To Come Down
AMA 922511 http://tcss.zoomshare.com/
Hide Signatures
(in reply to Hobbsy)
       Post #: 158
RE: Custom Piston Rings - 12/21/2011 12:51 PM
Frank C. Bowman
Score: 140
Status: offline
Hello Dave, I have both rings in stock at $11 ea. Postage $4 First Class or $5.65 Priority. My contact info. email: ringmaster46@msn.com Phone # (505) 327-0696 Merry Christmas
Frank C. Bowman
Hide Signatures
       Post #: 159
RE: Custom Piston Rings - 1/6/2012 6:18 AM
3D Romeo
Score: 100
Last Login: 4/24/2013
Status: offline
When I got my first DLE-30 engine (side carb) I was told that replacing the stock ring with a Bowman ring would help quicken the break-in period, as well as improve the compression, ease of starting, and engine running temperature. After reading through allot of threads on the side carb version I figured it would be a good idea to replace the stock ring with a Bowman ring. I don't know how the engine would have run with the stock ring, but I know it starts great, and runs great with the Bowman ring, and I couldn't be happier.
Since then I've accumulated a few more DLE engines (DLE-20, (2) DLE-30's, and a DLE-55), and I'm wondering for somebody low on funds (or out of funds in my case lol) would a Bowman ring be necessary to achieve all the things listed above, or do the newer rear carb DLE engines run good out of the box with the stock rings?
I still would like to replace all the stock rings with Bowman rings in the future, as funds become available. But if they aren't necessary for a good starting, good running, engine (out of the box) I'd like to hold off on ordering them for now until I can better afford them.
Any advice on this matter would be greatly appreciated.
Thank you
Mark
See I told you I was a good Pilot...Doh!...Never mind...
Hide Signatures
       Post #: 160
RE: Custom Piston Rings - 1/7/2012 5:17 PM
av8tor1977
Score: 665
Status: offline
The Chinese rings tend to be hard and take a good while to break in, but many, many people are using the DLE engines with the stock rings without problems. You could always use the engines you have as they are, and then change them over to Bowman rings at some time in the future.
I too am a big fan of Bowman rings, but they are not absolutely necessary if you can't afford them at this time.
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to 3D Romeo)
       Post #: 161
RE: Custom Piston Rings - 1/7/2012 6:03 PM
3D Romeo
Score: 100
Status: offline
Thanks for the reply AV8TOR.
I was kind of hoping that was the case. I just wanted to make sure before making a decision.
Mark
Hide Signatures
(in reply to av8tor1977)
       Post #: 162
RE: Custom Piston Rings - 1/7/2012 6:55 PM
karolh
Score: 310
Status: offline
Just can't seem to be happy if my engine is not running on a Bowman ring
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 163
RE: Custom Piston Rings - 1/8/2012 2:36 AM
captinjohn
Score: 247
Status: offline
Frank...look for some future orders from Florida.  I went too a Pylon race and spilled the beans...HA!   Capt,n
Hide Signatures
(in reply to karolh)
       Post #: 164
RE: Custom Piston Rings - 8/27/2012 11:39 PM
bigphil
Score: 100
Last Login: 5/9/2013
Status: offline
Anyone know if Frank is still doing rings? I've emailed him but haven't received a response... Need a ring for a Webra 1.20 if anyone knows of any other source.
Big Phil
AMA 6762
Hide Signatures
       Post #: 165
RE: Custom Piston Rings - 8/28/2012 12:50 AM
Frank C. Bowman
Score: 140
Status: offline
Hello Phil, I'm still making rings and do have the Webra 1.20 Dykes rings. Email me at ringmaster46@msn.com
Frank C. Bowman
Hide Signatures
(in reply to bigphil)
       Post #: 166
RE: Custom Piston Rings - 8/28/2012 2:30 AM
bigphil
Score: 100
Status: offline
Thanks Frank, email sent!
Big Phil
AMA 6762
Hide Signatures
       Post #: 167
RE: Custom Piston Rings - 9/17/2012 9:48 PM
captinjohn
Score: 247
Status: offline
My friend has 2 Webra 1.20 engines. From brand new one would hand start. The other engine needed to be started with a electric starter. I replaced the stock ring with a Ring from Frank Bowman...and it hand started first try. It had much more compression and ran great. Best rings on the planet for our RC engines.  Capt,n
Hide Signatures
       Post #: 168
RE: Custom Piston Rings - 9/18/2012 12:15 AM
bigphil
Score: 100
Status: offline
I'm already a believer John. I've repaired my friends Webra with new bearings and Frank's ring. Runs awesome!
Hand starts easily, always has...
Big Phil
AMA 6762
Hide Signatures
       Post #: 169
RE: Custom Piston Rings - 9/18/2012 1:08 AM
karolh
Score: 310
Status: offline
Hey Capt,n,
I just spoke with Frank and he has rings for the M22 plus others, so I'm just waiting for TDA to hopefully give the green light for me to take the plunge.
Karol
Hide Signatures
       Post #: 170
RE: Custom Piston Rings - 10/1/2012 1:08 AM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: karolh
Hey Capt,n,
Karol
That sounds good too me and I am sure Franks rings will be kind to the plating and not wear on it!   Capt,n
Hide Signatures
       Post #: 171
RE: Custom Piston Rings - 12/10/2012 8:25 PM
captinjohn
Score: 247
Status: offline
I just read in another forum, a guy installed a Frank B. piston ring in a Mintor 22cc engine and gained over a 1000 RPM. Capt,n
Hide Signatures
       Post #: 172
RE: Custom Piston Rings - 12/17/2012 12:11 AM
vatechguy3
Score: 100
Status: offline
What about a ring for the new dle 35 rear exhaust?
Tony
Hide Signatures
       Post #: 173
RE: Custom Piston Rings - 12/17/2012 2:02 AM
w8ye
Score: 318
Status: offline
quote:
ORIGINAL: vatechguy3
Tony
Send your piston and cylinder to Frank and he will make you a custom one.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to vatechguy3)
       Post #: 174
RE: Custom Piston Rings - 12/18/2012 2:13 AM
captinjohn
Score: 247
Status: offline
Just email Frank. Some engines have the same bore size...a metric size and a lot of rings are the same width. He may have one already.  He may need to make sure if the ring is pinned & provide for that.  Capt,n
Hide Signatures
(in reply to w8ye)
       Post #: 175
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: Custom Piston Rings
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
