astronut30
Joined: 11/4/2002 From: Honolulu, HI, USA Status: offline
Get the Corona! It's way more stable and will be a lot easier to learn on and it's very very durable and cheap to fix. I had roughly about a $3.50-$5/per crash average with my Corona! and half of the tip overs and crashes resulted in no damage at all, just pick up straighten out and fly. The Corona is also a nice outdoor flyer, although, you should stay out of the wind while you're learning, it can be tricky with a fp heli in the wind. Assuming you don't have a radio, the Corona, if you went with the "ideal" set up: -basic Corona kit -futaba gy240 gyro -hs-81mg cyclic servos, hs-81 for tail -Hitec Laser Radio and 555 rx -cc pegasus 35 esc -atomic force motor -dean's 2 piece antenna -7 cell battery pack Of course you'll also need a charger You'll probably looking at ballpark $500+ range. The Piccolo wouldn't be that much cheaper if you started new. You could also find a used Corona or picollo and save $ but it's always really nice to build the kit yourself, that way you get to know the heli really well and troubleshooting if needed or parts replacing will be a lot easier, plus you get a better understanding for the heli, especially if it's your first. Not to mention the satisfaction Try a search on Corona, you'll find a whole lot of Corona lovers and a huge load of info on it. Also, check out Ezone, [url]www.rcgroups.com,[/url] loads of Corona flyers there. Hurry and get yourself a heli and have fun and get ready to be addicted!
_____________________________
--aloha-- Chad -
