RE: Comp ARF Valiant    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: Comp ARF Valiant Page: <<   < prev  3 4 5 6 7 8 9 [10] 11 12   next >   >>
Login
RE: Comp ARF Valiant - 12/15/2010 9:28 PM
sc204
Score: 100
Last Login: 5/21/2013
Status: offline
There were lots of leftover parts in my bag. Meant to be used as alignment pins somewhere. I think I was told that they were a holdover from the Impact kit. Same basic bag of accessories included with all the pattern kits. I think I did use the tube portion when I added adjustable incidence to the wing.
Stuart
Hide Signatures
(in reply to wagen017)
       Post #: 226
RE: Comp ARF Valiant - 12/15/2010 9:54 PM
wagen017
Score: 100
Last Login: 5/22/2013
Status: offline
OK, makes sense. Thanks Stuart!
Volkert
_____________________________
Club Saito member #371
Hide Signatures
(in reply to sc204)
       Post #: 227
RE: Comp ARF Valiant - 12/19/2010 7:14 PM
wagen017
Score: 100
Status: offline
Update on weights: my Valiant is now completely finished except for propellor, motor, controller and battery tray. The weight is now 2.888 grams.
With my Pletty Evo30-10 (585gr), spin opto 99(105gr), RASA prop (72gr) and 2x5S Rhino 4900 (1272gr) that would leave me with 78grams to mounting all this. Looking good!
Sofar I have built the Valiant completely stock with the parts supplied. I left out all the reinforcements and "dampening" needed for YS vibrations. I can post some pictures + equipment list if there is interest.
Volkert
Hide Signatures
       Post #: 228
RE: Comp ARF Valiant - 12/19/2010 7:58 PM
rene69
Score: 100
Status: offline
Please post some pictures.
Rene
Hide Signatures
       Post #: 229
RE: Comp ARF Valiant - 12/20/2010 8:02 PM
wagen017
Score: 100
Status: offline
You want pictures, you get pictures!!
Here we go:
1. mounting cockpit. About the only part of the build where you have to think yourself....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to rene69)
       Post #: 230
RE: Comp ARF Valiant - 12/20/2010 8:18 PM
wagen017
Score: 100
Status: offline
details on wings and stabilisers. I used the same methods for the linkages.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 231
RE: Comp ARF Valiant - 12/20/2010 8:20 PM
wagen017
Score: 100
Status: offline
This is really hard work! I can only upload one picture at the time!
Here some others, I wrote the details in the pictures:
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 232
RE: Comp ARF Valiant - 12/20/2010 8:25 PM
wagen017
Score: 100
Status: offline
Equipment used:
Futuba 6008 HS receiver
JR9411 2x for ailerons
Futaba 9351 for rudder + SWG extention for extra throw
Futaba BLS153 2x for elevators
850mAh battery
Emcotech Single bat switch. I always remove the charge wire and 2nd receiver feed wire (saves 6 grams)
Volkert
Hide Signatures
       Post #: 233
RE: Comp ARF Valiant - 12/20/2010 9:29 PM
Hans Meij
Score: 100
Status: offline
quote:
ORIGINAL: wagen017
Volkert check the tightness of the connector. They can be a bit loose. A backup feedline is not bad in that respect.
Hide Signatures
       Post #: 234
RE: Comp ARF Valiant - 12/20/2010 9:40 PM
wagen017
Score: 100
Status: offline
will do!!
Volkert
Hide Signatures
(in reply to Hans Meij)
       Post #: 235
RE: Comp ARF Valiant - 12/21/2010 1:04 PM
rene69
Score: 100
Status: offline
Thanks for the pictures. The a/c looks really good. I'm in the building face right now. Will use a YS170 and JR radio.
Merry Christmas and good flights in 2011.
Regards
Rene
Hide Signatures
       Post #: 236
RE: Comp ARF Valiant - 12/26/2010 8:45 PM
wagen017
Score: 100
Status: offline
today put my Valiant together to check alignments and work on the throws. This is a great plane and I love how it looks!!!! Also the build quality is great. For those of you that like the Jason Schulman scheme, they are still available even if it is not mentioned on the website so get one while you can!!
If I take the cockpit railing as my zero the plane actually came out quite flat. A little incidence on the wing (0.2 degrees) and no incidence (0) on the elevator halves.
I wonder about the incidence measurements, anybody did measure them?
Another question on the throws. In the manual the throws are mentioned for the snaps (23 degrees aileron, elevator 14 up, 18 degrees down, rudder 20 degrees). I wonder what the normal throws are.
Volkert
Hide Signatures
       Post #: 237
RE: Comp ARF Valiant - 12/27/2010 5:45 AM
eryildirim
Score: 100
Last Login: 7/6/2012
Status: offline
Hello Volkert
The incidence of the wing must be 0.6 deg comparing to the base of the canopy.
Beveled shape of the trailing edge of the wing causes misalignment of the back leg of the measurement device So temporarily fill it with a piece of balsa and fix it with a two side tape. Then you will measure correct incidence.
Stabs are 0 deg.
For stall turn you need a high deflection of rudder.
My rudder touches to elevators on both side.
Ahmet Eryildirim
Hide Signatures
       Post #: 238
RE: Comp ARF Valiant - 12/27/2010 4:02 PM
wagen017
Score: 100
Status: offline
Here with the picture, couldn't upload it yesterday!
Volkert
Click for fullsize
< Message edited by wagen017 -- 12/27/2010 5:42 PM >
Hide Signatures
(in reply to eryildirim)
       Post #: 239
RE: Comp ARF Valiant - 12/27/2010 5:41 PM
wagen017
Score: 100
Status: offline
quote:
ORIGINAL: eryildirim
Hello Volkert
Stabs are 0 deg.
Ahmet Eryildirim
Right on the money! You were right about the trailing edge. Now I measured 0,5 degrees positive.
My rudder comes about parallel on the elevator halves, but I cannot get it further. What do you need to sand away to get it like that? I tried around the junction, but it did not make a difference.
Volkert
Hide Signatures
       Post #: 240
RE: Comp ARF Valiant - 12/27/2010 8:49 PM
pattratt
Score: 100
Status: offline
Volkert
I had to open up the hinge slots. Keep moving it back and forth you will be able to see where you need to clearance. It's a great flying aircraft.
Dick
Hide Signatures
       Post #: 241
RE: Comp ARF Valiant - 1/5/2011 5:30 AM
kochj
Score: 143
Status: offline
flyncajun
Or anyone else that did the chin per-manual....
How exactly does it work?
Do you FOrce the two pins (bolts) throught the wire?? Which moves the wire out of the way to allow the rounded bolts out/in ??
Or do you make a slot on the outside of the fuse so it slides??
Do you then pull the wire on both sides and then pull the chin out???
Could you show some pictures of a finished example..???
It would be very helpfull and most appreciated...
Justin..
Click for fullsize
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
       Post #: 242
RE: Comp ARF Valiant - 1/19/2011 12:00 AM
Tangy Tom
Score: 100
Last Login: 2/19/2011
Status: offline
Hi,
Can anyone tell me what diameter the wing tube and tail plane tubes are for the Valiant?
Hide Signatures
(in reply to kochj)
       Post #: 243
RE: Comp ARF Valiant - 1/19/2011 12:48 AM
Mastertech
Score: 108
Status: offline
You make small slots in the fuse side where the wire goes through. Do not force them in or out.
Tim
Be a kid forever, fly models.
Hide Signatures
(in reply to kochj)
       Post #: 244
RE: Comp ARF Valiant - 1/19/2011 3:11 AM
sc204
Score: 100
Status: offline
I know the wing tube is 30mm but not the most accurate of tubes. Poor quality compared to other wing tubes, and heavy.
Hide Signatures
(in reply to Mastertech)
       Post #: 245
RE: Comp ARF Valiant - 1/19/2011 12:59 PM
Tangy Tom
Score: 100
Status: offline
Hello,
Yes I was looking at the weights some of you guys posted and it does seem heavy. I am going to order a 30mm PBG tube which should save me around 50g.
Does anyone else know the diameter of the tail tube as I am going to purchase a PBG tail tube as well.
Hide Signatures
(in reply to sc204)
       Post #: 246
RE: Comp ARF Valiant - 1/19/2011 2:38 PM
Torben Parsberg
Score: 100
Last Login: 3/14/2013
Status: offline
hallo
I have order a new tube from PBG
they made it for me 68cm long dia 3cm and a weight at 64g
comp arf tube 126g and its not round ,,
Hide Signatures
(in reply to Tangy Tom)
       Post #: 247
RE: Comp ARF Valiant - 1/19/2011 3:18 PM
sc204
Score: 100
Status: offline
I also replaced the wing tube with an aftermarket version. I had to add some clear packing tape to make it fit better as you are right the original is not perfectly round. Half of the weight difference was lost due to this. I realized I can not measure the stab tube as I have the stab glued in to minimize any slop.
Stuart
Hide Signatures
(in reply to Torben Parsberg)
       Post #: 248
RE: Comp ARF Valiant - 1/19/2011 7:26 PM
wagen017
Score: 100
Status: offline
Tom, maybe you can measure the stab tube on your Valiant and let us all know!
I read somewhere a discussion regarding stiffness of wingtube and its effect on plane alignment during flight. There must be a reason for this massive wingtube. I was surprised the first time I saw it.
Volkert
PS: I am still awaiting my new motor; once I have it I will post final weights
< Message edited by wagen017 -- 1/19/2011 8:21 PM >
Hide Signatures
(in reply to sc204)
       Post #: 249
RE: Comp ARF Valiant - 2/1/2011 5:30 PM
H
Score: 100
Last Login: 2/19/2013
Status: offline
Hi Does anyone have the supplier contact details for the pbg wing and tail tubes in the US please.
Adrian
Hide Signatures
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
