sushi2me
Score: 100 Joined: 12/9/2004 Last Login: 3/22/2010 From: Middletown,
DE, USA Status: offline
OKAY - if you go to rvmshop.com, you get "Under Construction" - so I agree, I REALLY don't know where you got that email addressl BUT as long as it works and is getting you to the right people - hey, who cares? Has this Herman guy been helpful at all? I mean, really? Now, it seems like we end up answering our own questions more often than not, helping each other out, which is kind of what a forum is for. Now, he's Customer Service, maybe we need the address for the Technical Support person? I answered my own previous question about antenna placement for 2.4GHz by looking at a lot of other 2.4GHz receivers - most of which had two (2) very short antennas that were obviously INSIDE the boat (if it was a boat - that's my interest although, as I've indicated before, I do also have the Eurgle 2.4GHz 6-Channel Airplane Tx & Rx (and an extra receiver buty you have to make your settings for this one ON the personal computer, having loaded their software from mini-CD and I need to go back and look at THAT system's antennas. If you're getting the length of two football fields put together for the 3 Channel pistol grip, that's all I really need by way of distance/range for my boats HOWEVER if you stack that vertically, that should give me plenty of ceiling for most of my aerobatic flights (except for gliders, if I EVER, ha ha, get into those, but my eyes are so bad at my age and with my medical conditions As I may have mentioned before, I had said that I'm disabled, totally and permanently, but RC is what keeps me going: having had 13 surgeries and 2 medical pain control devices implanted in my body that are controlled by RC - one is a morphine pain pump, also known as an intrathecal infusion device, and I CAN'T control that one - only the doctor or his physicians assistant who do that by radio telemetry; the second is a neurostimulator which sends small electrical charges into the nerves in my neck via left and right probes which each have 4 electrodes, with cables running for the control unit under my hip, I can use a remote control to adjust various parameters: pulse width, rate, amplification - I can't select the different electrodes - the medical technician worked me up a bunch of programs that give me varied combinations that I can adjust but they replaced the old unit because the lithium battery in that one was 5 years old before it malfunctioned and it felt like I'd stuck my finger in an electrical outlet. I had to wait FOUR WEEKS for the surgery and in the interim, all he gave me was a higher dose of Vicodin pain killer on top of the morphine/bupivacaine 2:1 ratio in the pain pumps reservoir, anyway,, even with bifocals, and sometimes seeing better without them, I don't want any of my RC models that far away that I can't make out the orientation! Happy trucking/boating, guys, sushi2me/Dave
Hide Signatures
