RE: KI-84 FRANK ESM    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ReDUCED Balsa USA Fokker DR-1 Triplane - 1/3 Scale - Kit
Seller:  JSZ
Details:   $1,500.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: KI-84 FRANK ESM
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: KI-84 FRANK ESM - 2/19/2012 9:20 PM
maukaonyx
Score: 133
Last Login: 6/19/2013
Status: offline
Just wondering how the Frank's have been doing lately! I finally began assembly of mine a couple weeks ago, and I just putter at it a little at a time. Have been working on the wings first per the plans, and have the flaps and ailerons hinged, and the 4 servos installed in the wings. Was going to install the control horns and linkages but found some 15mm washers are missing, so will go to ACE for that tomorrow. I decided on a Saito 180 for this plane after seeing a ESM Frank with this engine on You Tube, flying in Denver. Nice combo, so I went with it...found a good used 180 here on RCU. Need to get her done for our club warbird weekend during the Memorial Day weekend. Someone post up some pics or vids of their Frank to get my juices flowing more! Jon
_____________________________
Carl Goldberg Ultimate 10-300 Brotherhood #01
Club Saito #707
Hide Signatures
(in reply to RCGARY)
       Post #: 101
RE: KI-84 FRANK ESM - 2/25/2012 7:42 PM
ed42d-RCU
Score: 108
Status: offline
Even though I've had mine for a year, I'm afraid I also just started putting my Frank together. I have the wing together...used robart horns and mocked up the Sierra retracts. I just started the stabalizer. I think I'm going to use the pull-pull for the elevator even though I've heard some against them. I think I had pull-pull on my Dave Patrick Ultimate without problems. I'll be careful to keep them tight.
I'm thinking of using a new JC-28 that's been sitting since I got it around a year ago. I've heard about the bad press on these engines, but I'll test run it before I decide whether to use it or not.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to maukaonyx)
       Post #: 102
RE: KI-84 FRANK ESM - 3/4/2012 8:42 PM
Thaskins
Score: 100
Last Login: 6/13/2013
Status: offline
Where can I get this cockpit kit?
Hide Signatures
(in reply to fockewulf37)
       Post #: 103
RE: KI-84 FRANK ESM - 3/4/2012 8:59 PM
ed42d-RCU
Score: 108
Status: offline
VQ Warbirds has them.
Hide Signatures
(in reply to Thaskins)
       Post #: 104
RE: KI-84 FRANK ESM - 3/5/2012 3:39 AM
maukaonyx
Score: 133
Status: offline
ed42d, at least you got your wing halves joined. I am behind you. I used the stock horns for the ailerons, but don't like them all that much, so will use something else for the flaps and other surfaces. Maybe I can find some Robarts like yours. Doesn't attaching the Sierras to the blocks in the wings look like a little challenge? I think the laminated ply and phenolic board look like they were cut a little large for the Sierras, such that the mounting screws will be close to the edges of the wood. Jon
Club Saito #707
Hide Signatures
(in reply to ed42d-RCU)
       Post #: 105
RE: KI-84 FRANK ESM - 3/5/2012 4:15 AM
ed42d-RCU
Score: 108
Status: offline
For the Sierra's, I had to dremel the formers toward the top of the wing to get the retracts to sit square. Also the pin in the retract moves and I needed a little grove to get the pin by the former. I hope I didn't weaken the former too much.
I've mounted the JC-28 and will probably have to add cowl blocks to the cowl ring similar what I saw someone do earlier in this thread.
Hide Signatures
       Post #: 106
RE: KI-84 FRANK ESM - 3/5/2012 8:33 PM
vik
Score: 100
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: ed42d-RCU
Hi
Just a small info - the retracts as they come from Darell have the legs turned around.
But than the gear doors are not flush.
Hide Signatures
       Post #: 107
RE: KI-84 FRANK ESM - 3/5/2012 11:22 PM
ed42d-RCU
Score: 108
Status: offline
quote:
ORIGINAL: vik
thanks Vik...I didn't notice that. After looking at the other pics of the landing gear in this thread, I see what you mean. I'll have to turn them around later.
I also tried to put the cowl on to see how the engine fits. Unfortunately, the front of the engine is hitting the bottom of the front cowl. I'd have to do some chopping which I would hate to do. I may have to look at other engines like the Zenoah that other guy's have used.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to vik)
       Post #: 108
RE: KI-84 FRANK ESM - 3/6/2012 6:18 AM
vik
Score: 100
Status: offline
No problem
I'm actually building second one as the first one was lost last year.
Hide Signatures
       Post #: 109
RE: KI-84 FRANK ESM - 3/7/2012 12:30 AM
Thaskins
Score: 100
Status: offline
Thanks ed42d. Ordered and on the way.
Hide Signatures
       Post #: 110
RE: KI-84 FRANK ESM - 3/11/2012 1:04 AM
maukaonyx
Score: 133
Status: offline
Mine came turned the right way, but I am finding that with the gear in, the tires will hit the top sheeting (I don't have the well in yet), and so I am going to need to either dremel away the tip side of the mount in order to raise the tire in the well, or use shims/washers on the fuse side of the mount to accomplish the same thing. The mounts don't sit flat. ed42d is this the same problem yours had?
Club Saito #707
Hide Signatures
(in reply to vik)
       Post #: 111
RE: KI-84 FRANK ESM - 3/11/2012 2:29 AM
ed42d-RCU
Score: 108
Status: offline
Haven't done much with the retracts except to mount them. I had to dremel some of the formers to get the retract to sit. I haven't tried to use the well. I may just paint the inside of the wing and not use the well.
I'm about finished with the tail surfaces and mounted the cockpit. I only added a pilot to keep it simple.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ed42d-RCU -- 3/11/2012 3:10 AM >
Hide Signatures
       Post #: 112
RE: KI-84 FRANK ESM - 3/11/2012 6:42 AM
maukaonyx
Score: 133
Status: offline
Your landing gear plate might not lay flat on the wood mounts when you turn your struts around. That is what I mean by mine not laying flat. I think I will go to ACE tomorrow for washers (for shims) and wood screws to mount the LG. Where'd you get the pilot...is he the right scale? I need to get one. Jon
Club Saito #707
Hide Signatures
       Post #: 113
RE: KI-84 FRANK ESM - 3/12/2012 11:03 PM
ed42d-RCU
Score: 108
Status: offline
My son gave me that pilot. He did the paint work. It seems to fit ok.
ESM has a 1/6 scale pilot which I also have. It's a little larger and would need to be cut down at the base.
I got that here:
TBM
Hide Signatures
       Post #: 114
RE: KI-84 FRANK ESM - 3/13/2012 1:29 AM
maukaonyx
Score: 133
Status: offline
ed42d, thanks for the tip on the pilot at TBM! I am going to get one. Jon
OOPS, the shipping is more than the cost of the pilot! Trapped again.
Club Saito #707
Hide Signatures
       Post #: 115
RE: KI-84 FRANK ESM - 3/23/2012 7:31 AM
vik
Score: 100
Status: offline
Hi Guys
Can you help me with this:
what is the dimensions TY is mentioning in the build video (part 2) for the cockpit cut?
Is it 1/4¨rear and 1/16¨ up front?
Thank you
http://www.youtube.com/watch?v=CLPJYlpb0NM
Hide Signatures
       Post #: 116
RE: KI-84 FRANK ESM - 3/23/2012 3:49 PM
glazier808
Score: 291
Status: offline
Vic,
Yak se mash!
He says 1/4" at the rear, and 9/16 at the front.
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to vik)
       Post #: 117
RE: KI-84 FRANK ESM - 3/24/2012 8:58 PM
vik
Score: 100
Status: offline
Thank you Casey
Jak se mam? dobre
Hide Signatures
(in reply to glazier808)
       Post #: 118
RE: KI-84 FRANK ESM - 3/24/2012 9:23 PM
glazier808
Score: 291
Status: offline
Neruzamin? lol its been too long since I've tried to speak your language. But I still remember the beautiful girl who taught me... Lol
glad I could help
Casey
Hide Signatures
(in reply to vik)
       Post #: 119
RE: KI-84 FRANK ESM - 4/1/2012 6:31 PM
vik
Score: 100
Status: offline
Hi All,
This is from my Mk.II
New hatch for batteries and ESC placement
I'm considering respraying it as well. But I might do it later in the year if it will survive the season
Hide Signatures
       Post #: 120
RE: KI-84 FRANK ESM - 4/2/2012 12:40 AM
captainron
Score: 100
Last Login: 6/15/2013
Status: online
Hey guys,
I have one of these RTF......I want to sell..........6 flights on it.
email me, I'll give ya all the info.
Hide Signatures
(in reply to vik)
       Post #: 121
RE: KI-84 FRANK ESM - 4/4/2012 5:39 PM
maukaonyx
Score: 133
Status: offline
My progress is still slow, but I have the Sierra retracts temporarily mounted in the wings now. I can tell this will give lots of toe-in. I think I see just one bolt that holds the strut to the casing...it is in the center of this pic. Is that what I use to rotate the strut to remove some of the toe-in? Thanks. Jon
Club Saito #707
Hide Signatures
(in reply to captainron)
       Post #: 122
RE: KI-84 FRANK ESM - 4/4/2012 5:45 PM
vik
Score: 100
Status: offline
yes that is correct
You have to only permit it slightly. Than you will be able to rotate the leg or take it out.
Hide Signatures
       Post #: 123
RE: KI-84 FRANK ESM - 4/5/2012 7:23 AM
vik
Score: 100
Status: offline
Hi All,
This is the pilot I got from Ty. I thing it is some sort of universal, but fits nicely.
Hide Signatures
(in reply to vik)
       Post #: 124
RE: KI-84 FRANK ESM - 4/8/2012 6:33 AM
John Sohm
Score: 100
Status: offline
quote:
ORIGINAL: fockewulf37
Hey guys here is an early mock up of the cockpit kit.......
I don't have any more of these pilots ....
Ty
Ty, what pilot figure is that you are using? Are they still available?
J F Sohm - AMA# 192350 - IMAA# 15145
=> If you’re not catching any flak, you’re not over the target. <=
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.297RCU1
