RE: Larger Revolver    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Larger Revolver
Page: <<   < prev  161 162 [163] 164 165 166 167 168 169 170   next >   >>
Login
RE: Larger Revolver - 1/12/2012 7:30 PM
ICEM@N
Score: 100
Last Login: 6/2/2013
Status: offline
My Virtual Test Pilot and 5 years old Aviation Specialist ...
The only reason to stay alive , my son Lucca , my princess Bianca and my wife , the Boss , Fernanda !
(sorry , but sometimes I need a pause for my family )
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ICEM@N -- 1/12/2012 7:57 PM >
Hide Signatures
(in reply to ICEM@N)
       Post #: 4051
RE: Larger Revolver - 1/12/2012 7:33 PM
MetallicaJunkie
Score: 243
Last Login: 6/16/2013
Status: offline
quote:
ORIGINAL: ICEM@N
The Engine , engine low view , cowl and pitts and noose ready !
'how does the auto glow work? you connect it to a spare channel?
_____________________________
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
       Post #: 4052
RE: Larger Revolver - 1/12/2012 8:03 PM
ICEM@N
Score: 100
Status: offline
quote:
ORIGINAL: MetallicaJunkie
quote:
ORIGINAL: ICEM@N
Well ...
If you connect it at a spare channel , it will act only when switch is "on" , or you can only press that little button at the pannel , and the starter will glow "on" for 10 seconds ...
Ricardo
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 4053
RE: Larger Revolver - 1/12/2012 9:05 PM
microdon2
Score: 110
Last Login: 6/17/2013
Status: offline
Icemon - you have a beautiful family. But don't forget your OTHER reason to live (or "RTL", as we call it here) - RC Planes!
Hide Signatures
       Post #: 4054
RE: Larger Revolver - 1/12/2012 10:30 PM
mach2
Score: 125
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: m_gutzmer@yahoo.com
My Revolver also has that problem.  So I installed flapps.  They work great, and with no loss of roll rate.
looks like you cut about an inch off of each wing tip too huh?  see any performance increase?  maybe that's why its rolls fast with less aileron (not that these would roll slowly with a good amount of throw)
< Message edited by mach2 -- 1/12/2012 10:51 PM >
70" Revolver, DLE20
67" Goldberg Edge 540, DLE20
Hide Signatures
(in reply to m_gutzmer@yahoo.com)
       Post #: 4055
RE: Larger Revolver - 1/12/2012 10:49 PM
mach2
Score: 125
Status: offline
quote:
ORIGINAL: ICEM@N
Well , I will show my assembly ...
This is how the throtle servo and Auto Glo System where assembled .
Build's lookin clean man!
The downside to the Rev's slicks looks is that nothing cool fits under the cowl! HAHAHAHA!  At least the DLE 20 only hangs out the bottom, so it's not too bad.
Also, I like you custom "conduit intake"!!!!
70" Revolver, DLE20
Hide Signatures
       Post #: 4056
RE: Larger Revolver - 1/12/2012 10:58 PM
mach2
Score: 125
Status: offline
the dle 20 has a #4 ignition and my 30 has a #3... i put a spare stock DLE55 ignition on my 20 and timed it at 28 degrees....Now i dont have that funky idle jump... it never really bothered me much, i just thought WTH ill use my spare IGN on it
The DLE 20 came factory timed at 40 degrees
they have them for 50 bucks http://www.shop.kavarootusa.com/product.sc?productId=12
Are you able to adjust timing on the Ign? Can we run a little more and use some C12 from VP (108 oct).....
70" Revolver, DLE20
Hide Signatures
       Post #: 4057
RE: Larger Revolver - 1/12/2012 11:39 PM
ICEM@N
Score: 100
Status: offline
quote:
ORIGINAL: mach2
quote:
ORIGINAL: ICEM@N
Also, I like you custom ''conduit intake''!!!!
I was seaching for a perfect in line air intake , but couldnt find it , so that conduit will help to increase air admission , could be helpfull. Personally I think that many little changes , but efficient ones , can , at final results , give us at last 15% or 25% more performance , and if just your brain knows it , it could give you mental advantage . I lear, this , and got this thought to my life , when I decided to be a Sport Shooter , and I lerned it at its best when I start long range rifle shooting.
Me and my brain thinks that this intake could help us ...
Hide Signatures
(in reply to mach2)
       Post #: 4058
RE: Larger Revolver - 1/12/2012 11:42 PM
ICEM@N
Score: 100
Status: offline
this is the Rx and Flightpower 8a ( I remove it ) , and will try just one LiFe 2s 2100mah batt
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4059
RE: Larger Revolver - 1/12/2012 11:51 PM
ICEM@N
Score: 100
Status: offline
Starting the Dual Tail servo modd , and it seems to be reasonbly easy , but i am afraid of it ... the shape of the new servo support seems nice .
The second pic . shows me that in this new model we do not need tail reinforcement for the tail landing gear , just becouse i find an 1" wood forming all tail base , its a big wood , Am I correct ?
And finnaly the first (left one) tail servo pannel and re-structure glued with epoxi , piece of cake !
But I'am afraid off modifing the tubes places , I try to remove one off , and one rib has cracked ( fixxed yet ) ...
Mach2 , is there any tip to do this surgery ?
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4060
RE: Larger Revolver - 1/13/2012 12:03 AM
wjcalhoun
Score: 110
Last Login: 6/19/2013
Status: offline
Ice
You are on the right track with the servo mods. Two approaches - the lite ply, as you have done, or balsa beams, as I and others have done. I don't think there is much weight difference.
If the tubes are empty, just cut them off at the former on both sides. On my airframe, they were very solidly glued in place, so there is a small part of the tube left in the former.
Hide Signatures
       Post #: 4061
RE: Larger Revolver - 1/13/2012 12:25 AM
Slow and Steady
Score: 105
Last Login: 6/18/2013
Status: offline
Micro, Metalica, Thanks for the clarification on the different ignitions. Micro, I believe the engine does need to be richened some in cold weather. I tuned my DLE in 80 degree weather and recently when it dropped to the 50s is seamed lean. Oddly enough, it ran best around 70.
Iceman, Beautiful family. You are a blessed man.
Hide Signatures
(in reply to wjcalhoun)
       Post #: 4062
RE: Larger Revolver - 1/13/2012 12:46 AM
MetallicaJunkie
Score: 243
Status: offline
quote:
ORIGINAL: mach2
unfortunately no.... but i did shift the Hall sensor over a bit to get at 28 deg.... actually i had to modify it slightly to get enough sliding room...
c-12 sounds good!
Click for fullsize
Hide Signatures
(in reply to mach2)
       Post #: 4063
RE: Larger Revolver - 1/13/2012 12:48 AM
MetallicaJunkie
Score: 243
Status: offline
quote:
ORIGINAL: ICEM@N
The second pic . shows me that in this new model we do not need tail reinforcement for the tail landing gear , just becouse i find an 1'' wood forming all tail base , its a big wood , Am I correct ?
try to leave the tube guides in place.... it will be perfect if you decide to do a pull pull on the rudder
very neat work by the way.... its interesting to see how others work...each one is unique and it works
Hide Signatures
       Post #: 4064
RE: Larger Revolver - 1/13/2012 1:23 AM
ICEM@N
Score: 100
Status: offline
Metalica , you are my help and my force !!
and I will do the pull-pull !! leave ithe tubes as they are ?
Thanks Slow&steady , they are my life , all of them ! Thanks my friend
Let the Force be with you
Hide Signatures
       Post #: 4065
RE: Larger Revolver - 1/13/2012 1:24 AM
ICEM@N
Score: 100
Status: offline
quote:
ORIGINAL: wjcalhoun
Ice
For pull-pull system ... cut them off or leave it ?
Hide Signatures
       Post #: 4066
RE: Larger Revolver - 1/13/2012 2:15 AM
mach2
Score: 125
Status: offline
quote:
ORIGINAL: ICEM@N
quote:
ORIGINAL: mach2
quote:
ORIGINAL: ICEM@N
I think it will definitely get more air into the carb. Its better that it sucking it in while the air passes over the opening. Did you glue it on?
By the way, i am a bit of a rifleman myself. I just like doing long range varmint shooting. My farthest hit on a ground squirrel is 720 yards. I "cheat" a little bit though. I shoot from a bi-pod and and a rear bag filled with lead shot. My varmint rifles are a 223, 22-250 and a custom built rem 700 in 6mmBR. The other two are just factory rifles with some cutsom touches on them. Triggers, bedding and stuff like that. I use a rifle basix trigger on my 223 savage, and i use Jewel triggers in my Remingtons. I keep all my triggers the same pull (14 oz.). I also handload all my ammo to get the best accuracy out of them.
Do you shoot highpower, benchrest, F-class???
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by mach2 -- 1/13/2012 2:42 AM >
70" Revolver, DLE20
Hide Signatures
       Post #: 4067
RE: Larger Revolver - 1/13/2012 2:25 AM
mach2
Score: 125
Status: offline
quote:
ORIGINAL: ICEM@N
Hey ICE, this is my first build so these other guys are the real sourse for good help. you are better at building than me im sure. I have decided that im gonna hold off on the dual elev. servos till later.  Im just doing the basics to get her flying. Plus im not an advaced pilot (hell, im probably not even intermediate!) so i wont be flying this thing to half of its capabilities.
These dudes on here like wjcalhou, microdon and metallicajunkie have awesome information that they are willing to share!
Thanks again fellas!
70" Revolver, DLE20
Hide Signatures
       Post #: 4068
RE: Larger Revolver - 1/13/2012 2:38 AM
mach2
Score: 125
Status: offline
quote:
ORIGINAL: mach2
Are you able to adjust timing on the Ign?www.rcuniverse.com="" forum="" js="" fckeditor="" editor="" images="" smiley="" msn="" /> Can we run a little more and use some C12 from VP (108 oct).....www.rcuniverse.com="" forum="" js="" fckeditor="" editor="" images="" smiley="" msn="" />www.rcuniverse.com="" forum="" js="" fckeditor="" editor="" images="" smiley="" msn="" />www.rcuniverse.com="" forum="" js="" fckeditor="" editor="" images="" smiley="" msn="" />
c-12 sounds good!
Oh shnaps! I'm a gearhead and didnt even think about shifting the the sensor over. Thats a good idea. how far did you move it? Or how did you figure out just how many degrees you moved it?  Its a small diameter. Not quite like using a timing wheel on a V8. And how did you know what the stock timing was set at?
It probably wont add much power since the "tuning" is "as is" with the DLE20 (and they only recommend 87-93 octane), but im running 100 octane Sunoco (i used to run it in my 96 camaro SS when i had the blower and methanol injection on it).
I guess its kinda like my buddy who used to run premium fuel in his Chevy avalanche with a stock tune. I used to tell him that he is throwing his money away, but he swore that he got better fuel mileage HAHAHA!
Thanks!
70" Revolver, DLE20
Hide Signatures
       Post #: 4069
RE: Larger Revolver - 1/13/2012 2:46 AM
ICEM@N
Score: 100
Status: offline
Mach2 , Iam a begginer !! Learning to fly , with my instrucutor , but why not fly with the Rev with my instructor ?
And this is my first build too !!
About rifles....
I love 22-250 , and .223 ...
I shoot a FMJ , 162g boat tail .308 Winchester , is a Open Class Rifle , and my trainning target is a 6 inches ( a balloon) at 1.000 meters , with a 4 inches group in 10 shoots .
My Sniper Rifle is a Custom made German Mauser , with titanium lockout firing pin , Cryogenic 30" bull barrel (7,5 kg ) 10:1 twist , Timney trigger , the aimimng systems are a Mapped Burris 36x Benchrest Scope and a 1200 yards laser green dot with triger action , all glass bedded in a wood basically PSG stock and a Haris bipod and steel pin at the rear , all assembly with a torquimeter and got the weight off 13kg , so I only shoot with bipod . Standing up is impossible . I shoot only this rifle , and this is one off three things I do better in my life . I love tho explod ballons...
Some day I will find some mini rocket system to install in my rc airplanes ... will be a must
Hide Signatures
(in reply to mach2)
       Post #: 4070
RE: Larger Revolver - 1/13/2012 2:55 AM
microdon2
Score: 110
Status: offline
Now if you guys ever married your two hobbies together - planes and shooting - I just hope you capture it on video.
Hide Signatures
       Post #: 4071
RE: Larger Revolver - 1/13/2012 3:13 AM
MetallicaJunkie
Score: 243
Status: offline
quote:
ORIGINAL: ICEM@N
quote:
ORIGINAL: wjcalhoun
Ice
i used them for my pull pull... i used the antena tube and the rudder tube... and if you cut them its no biggie, based on your abilities im sure you can work around it
Hide Signatures
       Post #: 4072
RE: Larger Revolver - 1/13/2012 3:19 AM
MetallicaJunkie
Score: 243
Status: offline
quote:
ORIGINAL: mach2
quote:
ORIGINAL: mach2
Are you able to adjust timing on the Ign?www.rcuniverse.com='''' forum='''' js='''' fckeditor='''' editor='''' images='''' smiley='''' msn='''' /> Can we run a little more and use some C12 from VP (108 oct).....www.rcuniverse.com='''' forum='''' js='''' fckeditor='''' editor='''' images='''' smiley='''' msn='''' />www.rcuniverse.com='''' forum='''' js='''' fckeditor='''' editor='''' images='''' smiley='''' msn='''' />www.rcuniverse.com='''' forum='''' js='''' fckeditor='''' editor='''' images='''' smiley='''' msn='''' />
c-12 sounds good!
It probably wont add much power since the ''tuning'' is ''as is'' with the DLE20 (and they only recommend 87-93 octane), but im running 100 octane Sunoco (i used to run it in my 96 camaro SS when i had the blower and methanol injection on it).
Thanks!
hehe................i find top dead center, then use a degree wheel this video is helpful http://www.youtube.com/watch?v=z0fvY210-Fo
this is useful too http://www.youtube.com/watch?v=GBXFpxWg7vY&list=FL7zQ69qsMN8hcvcjs_khPDA&index=136&feature=plpp_video
Hide Signatures
(in reply to mach2)
       Post #: 4073
RE: Larger Revolver - 1/13/2012 4:53 AM
ShuttleAU
Score: 100
Status: offline
 Hi All
Maiden flight today for mine.  Finished it a while back but weather ,work etc got in the way.
Engine is a DLE 20 , standard servo locations in the centre with dual elevator servos.
Given how much fuel the DLE engines uses, it will take sometime work through 5 litres for breakin.
Great model and flies well. I found the controls a bit "soft" , possibly because I have too much expo.  Everyone was impressed. I did notice the delay to idle but no great drama with it.
Initial start was a challenge as the engine was bone dry of fuel. Ended up putting a little in the cylinder to get fuel flow started. This was hint from two long term gasser pilots who dabble in IMAC.
If the weather holds , back to the field tomorrow, and the next day.
Has anyone here flown the smaller version as an electric ?
Shuttle.
Hide Signatures
       Post #: 4074
RE: Larger Revolver - 1/13/2012 6:18 AM
microdon2
Score: 110
Status: offline
ShuttleAu - Congrats on your Maiden. What prop are you using? How was your vertical and speed? Any problems? How were your landings?
Hide Signatures
(in reply to ShuttleAU)
       Post #: 4075
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.938RCU1
