RE: Larger Revolver    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Larger Revolver
Page: <<   < prev  239 240 [241] 242 243 244 245 246 247 248   next >   >>
Login
RE: Larger Revolver - 11/6/2012 1:59 PM
Cactus463
Score: 100
Last Login: 5/13/2013
Status: offline
Anyone out ther know of a source for longer throttle arms for the DLE engines-Anyone have pics of how the made longer ones?????
Hide Signatures
(in reply to Sbach342Guy)
       Post #: 6001
RE: Larger Revolver - 11/6/2012 2:13 PM
ahicks
Score: 669
Last Login: 5/20/2013
Status: offline
Cut 3 arms off an unused 4 armed servo arm?
Hide Signatures
(in reply to Cactus463)
       Post #: 6002
RE: Larger Revolver - 11/6/2012 11:14 PM
Slow and Steady
Score: 105
Last Login: 5/18/2013
Status: offline
This is the link for a 50 cc 3 D Hobby Shops Extra build manual. Page 21 has a great method for the extended throttle arm. You may want to check it out.
http://www.3dhobbyshop.com/assets/images/3DH-87EXTRA/3DH-87EXTRA-MANUAL.pdf
Incidentally, I think the carb throttle screw is 4 40. Also, I typically use a metal gear servo for the throttle due to the engine vibration transmitted by the control rod. Or you can fly till it runs out of gas, if the throttle servo gears strip.
Hide Signatures
(in reply to ahicks)
       Post #: 6003
RE: Larger Revolver - 11/7/2012 12:08 AM
ahicks
Score: 669
Status: offline
quote:
ORIGINAL: Slow and Steady
That would also be one of the better reasons to run an opti switch?
Hide Signatures
(in reply to Slow and Steady)
       Post #: 6004
RE: Larger Revolver - 11/7/2012 1:20 AM
microdon2
Score: 110
Last Login: 5/14/2013
Status: offline
... and \ or a servo-controlled choke ...
Hide Signatures
       Post #: 6005
RE: Larger Revolver - 11/8/2012 1:59 PM
Cactus463
Score: 100
Status: offline
Thanks for the info-will give ie a try
Hide Signatures
       Post #: 6006
RE: Larger Revolver - 11/9/2012 5:24 AM
Slow and Steady
Score: 105
Status: offline
Choke servo, opti switch or Ignition Battery Eliminator Circuit. Have to have a remote way to turn off engine, without delay. Some radios also allow for a throttle cut off, which lets you trim down the throttle via a secondary channel switch.
Hide Signatures
       Post #: 6007
RE: Larger Revolver - 11/11/2012 7:33 AM
ICEM@N
Score: 100
Status: offline
Hi guys , I´m back ! did not make the maiden flight yet !!! But now I bought a JR XG11 , and next week i will maiden my Rev70 !
Hide Signatures
       Post #: 6008
RE: Larger Revolver - 11/18/2012 1:53 PM
SigMan
Score: 110
Last Login: 5/6/2013
Status: offline
Larger Revolver ? there are 3 sizes now. which one does this thread pertain to ?
_____________________________
Club Saito Member #1
AMA# 542304
Hide Signatures
(in reply to lopflyers)
       Post #: 6009
RE: Larger Revolver - 11/18/2012 2:06 PM
wjcalhoun
Score: 100
Last Login: 5/17/2013
Status: offline
This is the middle sized, 70" R70 thread; the 50cc, 90", R90 is called 50ccRevolver
Hide Signatures
(in reply to SigMan)
       Post #: 6010
RE: Larger Revolver - 11/18/2012 6:24 PM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: wjcalhoun
This is the middle sized, 70'' R70 thread; the 50cc, 90'', R90 is called 50ccRevolver
wj, they will need to change this thread name to, "Middle size Revolver"
Hide Signatures
(in reply to wjcalhoun)
       Post #: 6011
RE: Larger Revolver - 11/18/2012 10:58 PM
wjcalhoun
Score: 100
Status: offline
OTOH, it is the 'larger' revolver, not the 'largest'
English teachers out there?
Hide Signatures
(in reply to Luchnia)
       Post #: 6012
RE: Larger Revolver - 11/18/2012 11:08 PM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: wjcalhoun
It is certainly larger that the small Revolver
What do we do with the other larger Revolver? Maybe that thread should be titled, "Largest Revolver to Date"
Hide Signatures
       Post #: 6013
RE: Larger Revolver - 11/18/2012 11:34 PM
wjcalhoun
Score: 100
Status: offline
But it is smaller than the 'largest revolver'
So it could be 'smaller revolver' also
Hide Signatures
       Post #: 6014
RE: Larger Revolver - 11/19/2012 12:11 AM
lopflyers
Score: 140
Status: offline
R59, R70, R90
Keep your wings level
Club Saito Member #693
Hide Signatures
       Post #: 6015
RE: Larger Revolver - 11/19/2012 1:55 AM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: lopflyers
R59, R70, R90
That might work, then when they come out with an R110?
Hide Signatures
       Post #: 6016
RE: Larger Revolver - 11/19/2012 3:39 AM
microdon2
Score: 110
Status: offline
I number mine. Since my Revolver fleet (when in full compliment) number two 59's and two 70's, I named them Rev 591, Rev 591, and Rev 701 and Rev 702. (and write the appropriate "1" and "2" in permanent marker on the underside of the fuse and inside edge of each wing. Else, chaos could ensue...)
Truth be told, only the Rev 702 is anywhere NEAR RTF at this moment, but I've got the boys on the line (myself) working overtime to rectify that.
And - one day - the Rev 901!!
Hide Signatures
       Post #: 6017
RE: Larger Revolver - 11/19/2012 7:16 AM
SigMan
Score: 110
Status: offline
R59, R70, R90
AMA# 542304
Hide Signatures
(in reply to microdon2)
       Post #: 6018
RE: Larger Revolver - 11/19/2012 1:06 PM
mike early
Score: 125
Last Login: 5/19/2013
Status: offline
Tell me you got a new Saito, SigMan!
Saito Club Member #578
P-40 Brotherhood #62
Hide Signatures
       Post #: 6019
RE: Larger Revolver - 11/19/2012 3:33 PM
edwal07
Score: 100
Status: offline
There is a good thread on the R90 or 50cc if you are interested.  I have one and love it.  Flys like a dream!
Ed Waldrop
Hide Signatures
(in reply to mike early)
       Post #: 6020
RE: Larger Revolver - 11/19/2012 4:25 PM
SigMan
Score: 110
Status: offline
quote:
ORIGINAL: mike early
Actually Mike im trying out an XYZ 20cc gas engine on it. my first gas engine.
AMA# 542304
Hide Signatures
       Post #: 6021
RE: Larger Revolver - 11/19/2012 4:35 PM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: SigMan
Ah, I made my foray over to gas and so far, I love it! I still keep some glows and I fly them. The glows have a place and the gas as well....its all good!
Hide Signatures
       Post #: 6022
RE: Larger Revolver - 11/22/2012 1:42 PM
Granpooba
Score: 110
Status: offline
Presently I am putting the finishing touches to my second R-70 with a DLE-20 installed. My first one has a Saito 91.
Have been looking for my next winter project and have even considered the R-59 with an OS fuel engine. But while looking at what OS has to offer in their engine lineup, I came across their gas OS GT 22.
Thinking that all I have read about and seen pictures of are of the folks that have put a DLE-20 into the R-70. Now, I am starting to think, why not a OS GT 22 in an R-70 ? Has anybody seen or done this combo yet ? Could prove to be an interesting combo.
Hide Signatures
       Post #: 6023
RE: Larger Revolver - 11/22/2012 2:12 PM
ahicks
Score: 669
Status: offline
You still don't have that thing in the air? I thought I was slow...
I have no brand loyalty, not scared of any of the 20's I'm familiar with. My thought is any of them will probably outlast me with proper care care and feeding. That thought in mind, suggest you find and go with the lightest available? You've been around for a while, so thinking you might want to consider moving the CG back about 1/2" from suggested once you start settling in after the test flights. That lighter engine will be a big help doing that? Not knowing this ahead of time, I used an RCG which is about 3oz heavier than the DLE. To get the CG where I wanted it, I even had to go to a plastic spinner? FWIW, -Al
Hide Signatures
(in reply to Granpooba)
       Post #: 6024
RE: Larger Revolver - 11/22/2012 11:00 PM
Granpooba
Score: 110
Status: offline
quote:
ORIGINAL: ahicks
I have no brand loyalty, not scared of any of the 20's I'm familiar with. My thought is any of them will probably outlast me with proper care care and feeding. That thought in mind, suggest you find and go with the lightest available? You've been around for a while, so thinking you might want to consider moving the CG back about 1/2'' from suggested once you start settling in after the test flights. That lighter engine will be a big help doing that? Not knowing this ahead of time, I used an RCG which is about 3oz heavier than the DLE. To get the CG where I wanted it, I even had to go to a plastic spinner? FWIW, -Al
People aren't slow. Just have lots of time on their hands and way to many other models to fly. Finish one, then whats next ? Besides, perfection takes time.
Also its getting cold here in upstate NY. Thinking about changing hobbies over to snowblowing and skiing.
Hide Signatures
       Post #: 6025
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
