RE: Larger Revolver    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Ziroli SBD Dauntless - RTF
Seller:  misfit
Details:   $3,000.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Larger Revolver
Page: <<   < prev  192 193 [194] 195 196 197 198 199 200 201   next >   >>
Login
RE: Larger Revolver - 5/3/2012 1:59 PM
sudi9
Score: 100
Last Login: 6/11/2013
Status: offline
Hi Luchnia
Please excuse me for my ignorance, but what did you mean by "clear plastic Fiji bottles with Viton tubing" ?
Regards,
Udi.
Hide Signatures
(in reply to Luchnia)
       Post #: 4826
RE: Larger Revolver - 5/3/2012 3:56 PM
Luchnia
Score: 193
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: sudi9
Hi Luchnia
Please excuse me for my ignorance, but what did you mean by ''clear plastic Fiji bottles with Viton tubing'' ?
Regards,
Udi.
Fiji bottles are clear water bottles that we have available here in the US. Some folks have taken them and used them for gas tanks. Viton tubing is tubing made from pure Viton that can be used for a number of proposes and also used for fuel tubing. It is extremely flexible in cold temps and last a long time. If you do a google search you can find it uses.
Hide Signatures
(in reply to sudi9)
       Post #: 4827
RE: Larger Revolver - 5/3/2012 5:56 PM
mach2
Score: 125
Last Login: 5/12/2013
Status: offline
sudi9, if you cut the engine mounts at the firewall, you can slide the engine back and close up that inch gap between the cowl ring and spinner backplate.
Click to see fullsize image.
Click for fullsize
_____________________________
70" Revolver, DLE20
67" Goldberg Edge 540, DLE20
Hide Signatures
(in reply to sudi9)
       Post #: 4828
RE: Larger Revolver - 5/3/2012 7:41 PM
sudi9
Score: 100
Status: offline
Hi Mach2
Thanks for the advise, i have noticed that in of the build threads on youtube after mounting the engine already.
Yes there is quite a gap from the cowl.
By the way did you try the spiner nut in the kit on the DLE, it's of a different thread size ? Doesn't fit?
I have ordered a nut spiner instead
Thanks!
Hide Signatures
(in reply to mach2)
       Post #: 4829
RE: Larger Revolver - 5/3/2012 7:51 PM
sudi9
Score: 100
Status: offline
Well noted thanks
Hide Signatures
       Post #: 4830
RE: Larger Revolver - 5/3/2012 10:35 PM
mach2
Score: 125
Status: offline
you can use a 8x1 adapter. i had to open up the spinner's hole for the adapter screw. not a big deal though.  its a nice looking spinner and fits the look of the cowl perfectly!
www3.towerhobbies.com/cgi-bin/wti0001p
opps, that's not the right size. but that's what you'll need. i got mine from a buddy who had one laying around.
Jeremy
Click for fullsize
Click for fullsize
70" Revolver, DLE20
Hide Signatures
(in reply to sudi9)
       Post #: 4831
RE: Larger Revolver - 5/3/2012 10:46 PM
mach2
Score: 125
Status: offline
im having a hard time finding one for you. you would have to find a screw to go through the spinner into the nut. The one with the Revovler's spinner kit may work....
www.hangar-9.com/Products/Default.aspx
Jeremy
70" Revolver, DLE20
Hide Signatures
(in reply to mach2)
       Post #: 4832
RE: Larger Revolver - 5/3/2012 11:17 PM
microdon2
Score: 110
Last Login: 6/17/2013
Status: offline
Sudi - The DLE 20 drive-shaft threading is 8x1.00mm. Here's a TH link - just check that the nut length is correct for you (I dont' recall which one I used). http://www3.towerhobbies.com/cgi-bin/WTI0001P?I=LXB962&P=8
Also, there's an encyclopedic amount of information \ experience \ feedback about the DLE 20 on this other RCU thread:
http://www.rcuniverse.com/forum/m_9863953/mpage_1/key_/tm.htm
And that first post is used as a "sticky" or repository of very valuable information.
Hide Signatures
(in reply to mach2)
       Post #: 4833
RE: Larger Revolver - 5/4/2012 2:29 AM
mach2
Score: 125
Status: offline
Mike, how'd you find that?  I searched TH too. I guess I dont have search skills like you...
Sudi9 - there's lots of good info on there, so I'd read the first few pages thoroughly. But be aware that there are a couple guys that follow that thread who like to give people a hard time. They will often give a rude "use the search function before asking questions" answer if there is a question that's been answered somewhere within the 217 pages. It's funny how they have enough time to float around on here all day looking for a chance to make snide remarks, but they dont seem to have enough time to help someone out. I guess they got into the hobby knowing everything before hand.....
Jeremy
70" Revolver, DLE20
Hide Signatures
(in reply to microdon2)
       Post #: 4834
RE: Larger Revolver - 5/4/2012 2:36 AM
microdon2
Score: 110
Status: offline
mach2 - I used Google. The Tower search stinks cause you have to have the exact text string that they use.
Sudi - mach2 makes a good point. That DLE 20 thread is great, but there are a few cranky old-timers on it who'll jump all over you if your question isn't esoteric enough.
Hide Signatures
(in reply to mach2)
       Post #: 4835
RE: Larger Revolver - 5/4/2012 5:11 AM
mach2
Score: 125
Status: offline
yeah, i noticed that the TH search is finiky. Its gotta be exact. Ill start using the google more. I knew TH had one of those cause id seen it before, but i searched 8x1mm adapter instead of 8x1.00mm adapter...
Jeremy
70" Revolver, DLE20
Hide Signatures
       Post #: 4836
RE: Larger Revolver - 5/4/2012 12:09 PM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: mach2
Jeremy
Ain't it the truth! They forget that had to learn once like everyone else....well except those that came out of the womb flying RC. You know they have all knowledge and know all things RC...can't tie thier shoes though.
I think most of us desire to help others as best we can. Sometimes I do struggle with the "new" texting crap. Makes me want to hurl. Call me "old school" but I am over the sorry way that kids today speak, write, type, text, etc. I can really rant on that one.
We will have grown a total bunch of idiot losers in our current generations of children! You think they could even figure out how to put together a Rev 70 even with detailed instructions? I need to stop before I explode!
Hide Signatures
(in reply to mach2)
       Post #: 4837
RE: Larger Revolver - 5/4/2012 2:01 PM
microdon2
Score: 110
Status: offline
Hey - we were kids once, just like them...
Hide Signatures
       Post #: 4838
RE: Larger Revolver - 5/5/2012 2:10 AM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: microdon2
Yeah, however when I came up we did not get away with quite as much. We did try though
Hide Signatures
       Post #: 4839
RE: Larger Revolver - 5/5/2012 12:16 PM
kerwin50
Score: 105
Last Login: 6/16/2013
Status: offline
Yeah and I walked 3 miles to school up hill both ways.
Hide Signatures
       Post #: 4840
RE: Larger Revolver - 5/6/2012 1:34 AM
Oldbob
Score: 105
Status: offline
This kind of self-ego nonsense is what kills kills kills a good topic I’m out of here, by-by.
Oldbob, smart enough to know dung when I see it.
Hide Signatures
(in reply to kerwin50)
       Post #: 4841
RE: Larger Revolver - 5/6/2012 1:48 AM
Luchnia
Score: 193
Status: offline
I am chuckling because I have no clue what I missed nor what was read into those post by oldbob! Can we not even have fun anymore on the forum? Oldbob, hang in there and stick around, every now and then we fire on all cylinders
Now back to the Rev 70. I flew mine again today and had a blast. I cannot emphasize enough just how smooth this bird is! Again today I heard those familiar comments about how good the Rev 70 looks when she flies.
Hide Signatures
(in reply to Oldbob)
       Post #: 4842
RE: Larger Revolver - 5/6/2012 2:15 AM
lopflyers
Score: 140
Status: offline
Dang, I want one so bad
Keep your wings level
Club Saito Member #693
Hide Signatures
       Post #: 4843
RE: Larger Revolver - 5/6/2012 3:38 AM
microdon2
Score: 110
Status: offline
Oldbob - actually nothing kills a thread faster that a weird and inappropriate first post like yours. Good to hear you're so smart, though.
Hide Signatures
(in reply to lopflyers)
       Post #: 4844
RE: Larger Revolver - 5/6/2012 5:59 AM
mach2
Score: 125
Status: offline
on the top of page 190, he asked a question about mounting the DLE20. a couple of us answered. He never responded. then i asked him we were any help. he said yes and thanks.
Then the last post.
In a thread that is almost 200 pages long, there is bound to be a lot of off topic talk.....
70" Revolver, DLE20
Hide Signatures
       Post #: 4845
RE: Larger Revolver - 5/6/2012 6:01 AM
mach2
Score: 125
Status: offline
quote:
ORIGINAL: lopflyers
ive been on an ebay selling bender keeping one..... Its worth is if you can somehow come up with the funds!
70" Revolver, DLE20
Hide Signatures
       Post #: 4846
RE: Larger Revolver - 5/6/2012 6:49 AM
sudi9
Score: 100
Status: offline
Here are some pics from saturday flying with the guys .
I had the chance to fly my REV70 twice, until i had some engine trouble, imust say that the Rev70 was faster than all of my compition over here .
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4847
RE: Larger Revolver - 5/6/2012 6:58 AM
sudi9
Score: 100
Status: offline
quote:
ORIGINAL: sudi9
Could not get the engine to idle properly, and was difficult to start,still after some adjustmentsno success.
Decided to take the engine out and look for the problem.
As you can see in the pics, the carb was full of debris in the net filter.
Thats a good lesson for not using a good fuel filter !!!!!!
Udi.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sudi9)
       Post #: 4848
RE: Larger Revolver - 5/6/2012 11:33 AM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: mach2
Then the last post.
Total agreement with you. This is a huge thread and we do occasionally pull it aside. I don't see the damage in that as long as it is in moderation.
Oh, BTW, I was flying the Rev 70 yesterday and I was doing a vertical and just going straight up at will. One of the guys said, "What kind of engine is that?" I said 91FX. If the 91FX will pull this thing straight up like a rocket I cannot imagine the 20 DLE. I know one thing this plane will get questions asked even with the higher dollar planes flying.
We had much more elaborate and expensive planes at the field yesterday, yet no matter she still gets responses. That speaks much for the GP Revolver. I have several gas planes, glow, etc, but so often the Revolver has a place in the van when I go to the field
Hide Signatures
(in reply to mach2)
       Post #: 4849
RE: Larger Revolver - 5/6/2012 11:35 AM
Luchnia
Score: 193
Status: offline
sudi9, thanks for posting the pictures. You have a very nice setup and looks like you and your fellow flyers had a great time together flying. It is always nice to see the various airplanes and our fellow flyers from other places
Hide Signatures
(in reply to sudi9)
       Post #: 4850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
