avance_x
Joined: 6/1/2003 From: Tsuen WanNew Territories, HONG KONG Status: offline
Initially I had the 3 pins connected (B+,B-, signal) from Gyro to the tail esc, the tail motor could not just compensate (seems like it lacks power) at HH mode. When I tried to disconnect the supply (B+, B-) and just use the signal wire, at HH mode (AVCS) the tail motor is just too stong that it starts to rotates before the main rotor could. When I set the AVCS to off, it's works fine but his would defeat my goal of having a rock solid tail By the way, I already played around with the gain and this didn't help either. I was really wanting to buy the CSM HLG200 but on our side of the world, GY240 is like $80 only .
