dgrant
Joined: 12/3/2001 From: Clovis, CA, USA Status: offline
Someone.....you shouldn't just leave your radio on to cycle...this drains batteries to zero, and some cases less then zero. If by some chance you had a bad cell, it might not return to the capacity that other cells do. In which case your pack will be left with insufficient capacity. The SuperTest will drain them down to a set point every time and no farther, and in doing this it checks the capacity for you and will have a reading of it, and that reading is what you record, and that will tell you what kind of life your getting from your packs, and the condition of your pack. Myself, I use the AccucyclePlus, it seems to do everything I need, and more. Sirius is said to be one of the best, and the whole system is good, however for my money, I went with AccucyclePlus. It's a very decent unit, and you can get the adapter to field charge if you need to. I use my AC+ for all charging, most of the time I just plug it in night before. It automatically has 50mah charge(same as the wall-wart that your radio comes with), and that lasts 24hrs, then it switches to a 2mah (yes 2), so you can actually leave it alone. I only use the quick charge features when I want a ..yes "quick charge, or when I'm cycling, other then that, I don't need to pump the batteries up that fast. I still have not seen anyone with an excellent reason why the Sirius is better, although I have no reason to doubt, I have seen these in action, and borrowed one a time or two at the field, but my AC+ works fine, and has several different parameters I can choose.
