mvvs 58 TOO NOISEY!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> JTEC / RADIOWAVE Support >> mvvs 58 TOO NOISEY!
Page: [1]
Login
mvvs 58 TOO NOISEY! - 10/8/2009 6:24 AM
MatriX40
Score: 100
Last Login: 4/17/2011
Status: offline
i have an mvvs 58 and its too noisey, i know a canister is the ultimate solution. to be honest i really do not feel like modifying my airplane, it does not have a can tunnel. so im asking jtec if they produce an inverted wrap around muffler that will drastically reduce my engine noise. the snufflers look appealing but i hear they are quite heavy. also how much would one of these mufflers cost for my mvvs 58 thank you in advance
Hide Signatures
       Post #: 1
RE: mvvs 58 TOO NOISEY! - 10/8/2009 4:51 PM
al
Score: 100
Last Login: 6/10/2013
Status: offline
There are several possible solutions. Frist what do you have for a muffler, Do you have to meet any sound issues? What type plane do you have it in.
We have several versions of the wraparound muffflers each quieter than the other. I am sure we can find you a solution.
Please feel free to contact us at the office at 704-799-1658 or sales@jtecrc.com
Al
_____________________________
JTEC/RADIOWAVE
FUTABA
Hide Signatures
(in reply to MatriX40)
       Post #: 2
RE: mvvs 58 TOO NOISEY! - 10/8/2009 5:34 PM
Bdegan
Score: 100
Last Login: 12/1/2012
Status: offline
What size prop are you running ?
If your prop is too small, that will lead to excessive and unnecessary noise.
MVVS 58 is a brute of a motor and likes a bigger prop.
Hide Signatures
(in reply to al)
       Post #: 3
RE: mvvs 58 TOO NOISEY! - 10/9/2009 2:04 AM
MatriX40
Score: 100
Status: offline
right now i believe it is a brisson inverted wrap around. i bought the engine used so im not 100% sure on that. it is on a bme edge 540II. i do not have to meet any noise requirements as of yet but i dont want to stir up anything with my plane. most guys at my field fly 4 stroke glow which are not that noisey and the few guys who fly gas run cans. i was just hoping that i could bolt a wrap around on and reduce noise rather than modifying my airframe to install a canister. the prop that it is turning is a 24/8
Hide Signatures
(in reply to Bdegan)
       Post #: 4
RE: mvvs 58 TOO NOISEY! - 10/9/2009 2:22 AM
Bdegan
Score: 100
Status: offline
Prop seems ok. 24x8 to 24x10 is what the mvvs likes.
Hide Signatures
       Post #: 5
RE: mvvs 58 TOO NOISEY! - 10/9/2009 4:52 PM
al
Score: 100
Status: offline
I would probably suggest one of the large version wraparounds for the MVVS/Evolution 58. Its is a direct bolt on application. Since we make them when ordered we can make any modification if need. The large version gives you more muffler volume good power and it should drop you 3 plus DB over the standard wraparound ( every 3db is half the noise drop)
Prop wise size is porbably ok but different brands are better that others when it comes to noise reduction. Also 3 bladed props will reduce prop noise buy reducing RPM ( tip speed cause the noise) What you won't get with a 3 blade is the snappy spool up like a two blade and it will have a little different type performance. not bad just takes a little getting use too!!
If you can give us a call and we can talk about different options and what you are looking for.
Al Young
JTEC/RADIOWAVE
JTEC/RADIOWAVE
FUTABA
Hide Signatures
       Post #: 6
RE: mvvs 58 TOO NOISEY! - 10/17/2009 4:54 AM
nitro wing
Score: 125
Last Login: 6/20/2013
Status: offline
You'd be amazed what an MSC prop can do for noise reduction. I could hear an instant improvement as soon as it started at idle. The MSC will still give a ton of torque and keep the prop from ripping air uncessarily.
Hide Signatures
(in reply to al)
       Post #: 7
RE: mvvs 58 TOO NOISEY! - 3/18/2010 2:23 AM
ggroyal1
Score: 100
Last Login: 1/28/2013
Status: offline
What were the results?
I have the Evolution 58 with a JTEC wraparound.
Great engine.
Hide Signatures
(in reply to nitro wing)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
