PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP Page: [1]
Login
PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 10/9/2009 3:49 AM
rt navi man
Score: 100
Last Login: 4/1/2012
Status: offline
GUY'S I HAVE A EXECUTIVE AIRFRAMES PATRIOT 2M PATTERN SHIP. THE FUSELAGE IS FIBERGLASS ALL OVER, I PLAN TO STIP ALL PAINT FROM FUSE AND REPAINT WITH A DIFFERENT PAINT SCHEME. I WOULD LIKE TO REPAIR THE DAMAGE IN THE COWLING AREA. I AM NOT SURE HOW THICK IS FIBERGLASS IS, I HAVE BEEN LOOKING AROUND THIS FORUM AND ON YOUTUBE FOR ANY TUTORIAL THAT COULD HELP, FOUND KNOWTHING SO FAR.
1. IS THIS A POLYESTER RESIN OR A EPOXY MICRO BALLOON REPAIR ?
2. CAN I USE CARBON FIBERMAT ?
3. WHATS THE BEST WAY TO FILL/COVER THE TUNE PIPE OPENING.
THANK FOR ALL THE HELP.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by rt navi man -- 10/9/2009 4:26 AM >
Hide Signatures
       Post #: 1
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 10/9/2009 9:18 AM
dreadnaut
Score: 110
Last Login: 5/23/2013
Status: offline
Executive Airframes was (is?) a more high end producer of that generation pattern kits, and the odds are good that it is epoxy.
_____________________________
Cali is a city in Colombia
I''m from California.
Hide Signatures
(in reply to rt navi man)
       Post #: 2
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 10/9/2009 9:03 PM
Ed Smith
Score: 113
Status: offline
I do not know about a tutorial but try this.
To determine the resin, sand an area and then smell it. If it has that sweet sickly smell it is Polyester. If practicaly no smell it is Epoxy.
For repairs in this case, Carbon will do nothing for you that glass cloth will not. Just cost you more.
For repairs including the pipe hole, with a sanding drum grind away on the inside everything you do not want. Grind down to the basic skin without breaking through. Lay cloth no heavier than 6oz on the inside of the fuselage. Try and get it to follow the fuselage contour. It is not as difficult as it seems. When this has cured apply resin/micro ballons filler on the outside. Sand the mess to match the outside shape. It may take a number of filling and sanding operations.
If you are really interested then go here. There is a thread that pretty much shows the above procedure.
http://www.rcpro.org/net/ThreadView.aspx?threadid=405
Good luck.
Ed S
Hide Signatures
       Post #: 3
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 10/10/2009 2:12 AM
rt navi man
Score: 100
Status: offline
THANKS GUY'S KEEP THEM COMMING
ANY OTHER'S FOR QUESTION #3.
Hide Signatures
(in reply to Ed Smith)
       Post #: 4
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 10/13/2009 1:23 AM
rt navi man
Score: 100
Status: offline
I am still looking for a way to fill this pipe hole , any more ideas please post any info. This is my plane I am tryiny to upgrade/repair. Thanks
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 10/13/2009 8:45 PM
Ed Smith
Score: 113
Status: offline
I told you how to do it in my post.
Ed S
Hide Signatures
       Post #: 6
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 5/22/2010 7:33 AM
rt navi man
Score: 100
Status: offline
Still Looking for help on this one.....
Hide Signatures
       Post #: 7
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 5/22/2010 2:59 PM
dhal22
Score: 138
Last Login: 5/24/2013
Status: offline
what's wrong with Ed's suggestion? it will work just fine, in fact it's about the only way to do the repair. i didn't want to make fiberglass repairs to my classic pattern plane so i found an rcu member to do it for me (that's another way if you're counting). good luck.
David
Hide Signatures
       Post #: 8
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 5/23/2010 7:05 PM
SCALECRAFT
Score: 119
Status: offline
Whatever you choose to do, use a fine particle dust mask or respirator. And eye protection
Steve
Hide Signatures
(in reply to dhal22)
       Post #: 9
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 5/23/2010 7:49 PM
F3A Unlimited
Score: 123
Status: online
Take a piece of 1/16 or even 1/32 balsa and wet it with water/ammonia and tape it to the bottom of the fuse over the hole. Remove when dry. Take a piece of poster board and hold it inside the opening and trace it then cut it out. Place template over balsa and cut out the piece to match. Tack glue balsa into opening with ca or 5min epoxy. Lay piece of 2-4oz cloth and epoxy resin from inside over balsa repair and overlap about 1" around the repair. Lay piece of 3/4oz cloth and epoxy resin over balsa from outside and sand fill finish.
This is not a structural repair so you can make it light with the balsa sandwich type fix.
F3A Unlimited
Hide Signatures
(in reply to SCALECRAFT)
       Post #: 10
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 5/26/2010 4:46 AM
rt navi man
Score: 100
Status: offline
Thanks again guy's for your input/help. I want to repair this plane and give her a new paint sheme.
Hide Signatures
(in reply to F3A Unlimited)
       Post #: 11
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 6/28/2010 8:00 AM
I-fly-any-and-all
Score: 100
Last Login: 5/20/2013
Status: offline
try youtube.com/user/b1heqh54
Hide Signatures
       Post #: 12
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 5/3/2011 1:15 PM
Mrs R
Score: 100
Last Login: 4/3/2013
Status: offline
PIN HOLES
Easy  First make up your mind what type of paint you are going to use."best is a 2 pot type pollyurethane is best"
Mix up some primer and wipe it over the surfaces to be painted useing a credit card or thiner plastic, this forces the paint into the pin holes.
Spray a light coat of primer and let it harden,WARNING the next bit must be done within 72 hours. Then look for any pin holes and wipe primer
unthined into any pin holes that show. Lightly sand and shoot a couple of coats of primer,sand back with wet anddry "wet" then paint  your colour scheme on. Keep the paint coats light.
REGARDS EPOXY GLASS CF MATRIX.
Cut a piece of the layup out 1/2" round is big enough,holed it with a pair of long nose plyers light it with a match or propane torch
burn off the epoxy whats left is the glass cloth or CF cloth weave,weight and direction,
Now you know what you need to repair the damage and what direction thecloth goes and which layers go in what sequence.
ALWAYS allow 10mm tapper scarf per layrer that's about 3/8"
If say 3 layers then the scarf taper is about 1" if laying on the outside you put the inner layer 1st, 2nd layer is 3/8" smaller all the way round.
3rd layer is again 3/8" smaller. IF more layers make the scarf 3/8' larger for each layer.
BEST OF WORK
Rachael
                Of
                        R/T AIRCRAFT SERVICES
                              Specalists in Composite Repairs
Sailplane Repairs
Hide Signatures
(in reply to I-fly-any-and-all)
       Post #: 13
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 4/26/2012 3:46 AM
gaRCfield
Score: 156
Status: offline
Reviving this thread. I've got a plane with a cowl I want to fix. Wondering if one of the two suggestions above is the right one (fiberglass backed and filled with resin, or sandwiched wood). I've got 1/32" ply.
Any suggestions? This was a glow plane, any suggestions for prep? Hobby shop cloth and resin OK?
Also, how is Ultracote paint? Any suggestions for an inexpensive, somewhat decent, rattle can paint?
Edit: holy crap, a whole forum on this suject?! *I had no idea, just did a search on google, thought I ended up in the pattern forum). This will be my first glass project, so I'm looking for all the best advice I can find. I'm pretty excited to make this repair!
Click for fullsize
Click for fullsize
Joe Marri
Enjoying all things aviation.
Hide Signatures
(in reply to Mrs R)
       Post #: 14
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 4/26/2012 6:03 PM
Mrs R
Score: 100
Status: offline
RE read the post by me dated the 5/11/2011.
Seeing the photos of your cowl you need to make a backing plate to fit over the hole if you use ply or Balsa get some spray Adhesive and clue a layer of plastic on the inside of the backing plate
I use garbage bags as the plastic is very thin and epoxy won't stick to it.
After the layup hase cured remove the backing plate and wipe bondo over the repair ( a light sanding should be done first ) sand smooth when happy with the finish using a Credit Card or similar wipe some primer over the repair then sand smooth this should fill any pin holes left after the bondo.
If you want to finnish with a pressure Can  use 1 type Pollyurethane which is Methanol and Gas proof.
Rachael
PS if any questions about any on whats written just write in and I will answer.
Sailplane Repairs
Hide Signatures
(in reply to gaRCfield)
       Post #: 15
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 4/26/2012 8:48 PM
gaRCfield
Score: 156
Status: offline
Thanks for the reply.
I don't understand what the "layup" is. Fiberglass and resin? Apply from the inside and press on the backing?
The backing and plastic are just to support material while it cures, and then removed (ply and plastic)?
Joe Marri
Hide Signatures
(in reply to Mrs R)
       Post #: 16
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 4/26/2012 11:10 PM
Mrs R
Score: 100
Status: offline
Yes  the backing is just to support the Glass/Epoxy Layup till it hardens. The better the fit of the backing plate over the Hole the less work there is in finishing the outer surface.
Also the better it is attached to the cowl the easier it is to do the layup. I normally use more resin on the first layer of Glass cloth and I put the next layer of cloth on dry this then soaks up the excess resin.
HOPE THAT HELPS
Rachael
P.S. It is a lot easier to do than it sounds, once  you have the scarf sanded and attached the backing the rest is easy. On full size aircraft we  usually take a mould off another plane of the same make glue the plastic to it (The Mould) fit it over the hole and then squeaze inside and do the layup. So if the cowl was a compound curve I would do the same. Going by your pics it looks like it has only one curve so it should be pretty easy.
Sailplane Repairs
Hide Signatures
       Post #: 17
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 4/26/2012 11:17 PM
Mrs R
Score: 100
Status: offline
ONE MORE THING
If it is a plastic cowl reinforced with Glass/Epoxy you will need to add an extra layer of Glass cloth to make up the differance in thickness of your layup we normally use 2oz cloth for this.
Rachael
Sailplane Repairs
Hide Signatures
(in reply to Mrs R)
       Post #: 18
RE: PATRIOT PATTERN PLANE / NEED FIBERGLASS REPAIR HELP - 5/4/2012 5:58 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: Ed Smith
Ed S
If it isn't too much of a compound curve, try 1/32" balsa. CA in place and then use 1/2 oz glass cloth and epoxy paint clear. After paint cures, fill and finish
Regards,
MattK
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
